    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 768.7k Views 175 Watching
    • H Offline
      haynesc
      will the zipped set be updated along with each update of each individual plugin ?
        The individual EEby.. tools will no longer be updated.
        Any new or updated EEby tool[s] will be issued in this zipped set...
        However, the 'notes' will remain in each individual tool's thread, and I shall also remove the downloads from each at the next update... [which might be next week].
        • H Offline
          haynesc
          cool ... much easier
          • majidM Offline
            majid
            Thnak you again dear Tig πŸ˜„
              remus
              I downloaded this a while ago and forgot to say thanks, so thanks! These are those most sacred of tools that bring entirely new functionality to SU.
                Here's today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                Contains two new tools:
                EEbyFace (followme-like tool using a preselected 'flat' face with multiple paths if desired)
                EEbyRailsByFace (uses EEbyFace across a mesh picked by Profile/Rail1/Rail2/Melding-Profile just like EEbyRails to form a 'rib-cage')
                Links to their threads are in the main page... πŸ€“
                  dedmin
                    driven
                    Hi Tig, more toys,,, excellent
                    EEbyRailsbyFace isn't working on my Mac, and when I looked at the code, line 632 comments out all lines through to 693 which look important to me.
                    might this be my issue?
                    cheers
                      driven
                      That code is legacy stiff from EEbyRails that I found I didn't ever need [yet] but I left it in but 'commented' out just in case - so that's not the problem...
                      When you try it on your Mac what errors do you get in the in the Ruby Console ? πŸ˜•
                        driven
                        Error: #<NoMethodError: undefined method db' for #<Object:0x3f319f4>> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/extrudeEdgesByFace.rb:359:in extrudeEdgesByFace'
                        /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/extrudeEdgesByFace.rb:463
                          Here's an updated zip file http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                          It's issued because the EEbyFace tool had a simple typo in it that meant that whilst it didn't affect my testing of it, it did mess up some of you - it's been fixed in the latest zip file... Sorry for any inconvenience 😳
                            driven
                            no problem,
                            I EExRxF is working although it does crash out if you do it wrong, and it is that one that wasn't even starting.
                            I was looking at the code for both (to see what I was doing wrong) when I saw the comment-out bit, then I got mixed up which was in error...
                              driven
                              Working a treat..... cheers again
                                Thanks - that points to a typo in the file that doesn't cause me a problem while checking it... but does you !
                                I'll fix it and reissue a new zip... πŸ˜’
                                  Here's an updated version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                  Main changes are in EEbyFace and the related EEbyFaceByRails - their extruded form is now consistently oriented.
                                  Also minor speed improvements and the lingvo files updates.
                                  Minor tweaks to some other tools db setups etc - these will probably go unnoticed by most of you...
                                  Feedback please πŸ€“
                                    jessemorton24
                                    Feedback....I noticed the uniform spline of Fredo's makes the sexest railed surfaces. I do think the bezier command shrinks these curves..But Thank you!! I will be donating on your behalf soon. Like the day I can actually put money in my pocket, sweariingly.. I use your tools the most!! lately. Much THANKS and donation soon!!!!
                                    Cheers!
                                    Parkways, Driveways, Gateways, Pathways...
                                    • H Offline
                                      haynesc
                                      http://i.imagehost.org/t/0301/extrude_tools_menu.jpg
                                      Hi TIG would you be able to place your tools in a sub-menu like iv shown above ?
                                      ... would help keep our plugins list smaller ...
                                        Good idea - watch for next update....
                                          Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                          It now loads all of the available Extrusion Tools into one 'Extrusion Tools...' sub-menu in the Plugins menu...
                                          πŸ€“
                                            Ruturaj
                                            Thank you TIG
                                            GooD πŸ˜‰
                                            Thanks,
                                            RuturaJ
                                            • 31
                                            • 32
                                            • 3 / 32
