    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
    • jeff hammondJ
      @wind-borne said:
      following john's scenario, I can replicate.
      Maybe a new tool on the horizon πŸ˜† πŸ‘
      oh wait, if i give the toolbar a horizontal orientation then i do in fact get the extra button.. i keep all of my tool bars vertically on the left side and when done like that, it's always 4 buttons.
      if i move the 5 button bar to vertical prior to restarting , only 4 will show up after the relaunch.
        driven
        so it is a Mac thing, but quite harmless it seems, and I already asked TIG if it was a new tool pending (sorry no), I also stripped out all my rubies and then did a clean-instal of SU just to see if it would go-away, all to no avail. So I'm quite please it can be replicated... sort of.
        I'll try the vertical tip from Jeff and then forget all about.
          There MIGHT be a new tool coming... BUT it's nothing to do with that extra button !
          • ken28875K
            ken28875
            Awesome tools, TIG.
            I have been using it a lot lately and love it. But I run into a problem each time. After using it, whenever I right click on an object, most of the functions are not working and i have to restart Sketchup. I wonder if it's a bug and if anyone else has experienced it.
            http://i593.photobucket.com/albums/tt12/ken28875/right_click_not_working.jpg
            Thanks,
            _KN
            Follow Your Dreams.
              Rip Tanion
              I've only really tried EEBR so far, but it's really cool and has a multitude of uses.
              Personally, I find a tutorial for EEBR unnecessary. I find the plug-in pretty straightforward and easy to use. Still, Arc did a good job with his vid.
                @ken28875 said:
                Awesome tools, TIG.
                _KN
                This is a known problem - BUT not related directly to any particular Plugin. The latest versions of SUp have a bug where the context-menu items can get 'grayed-out' after a number of repeated 'clicks' on objects; it might also be related to the number of plugins that you have installed.
                I also have the problem - the Edit menu last item repeats the context-menu without a glitch - but it is still annoying having to save and restart to fix it...
                The SUp team are onto it - hopefully a maintenance release will fix back it as it was... πŸ˜’
                • ken28875K
                  ken28875
                  Thanks, TIG.
                  Follow Your Dreams.
                  • JClementsJ
                    JClements
                    And I thought I was the only one having this problem! Thanks for mentioning it.
                      d12dozr
                      Thanks TIG, Just dl'd and played a bit. I like the zipped set...makes it so much easier. Cheers!
                      http://goo.gl/f7ooYh
                      • H
                        haynesc
                        will the zipped set be updated along with each update of each individual plugin ?
                          The individual EEby.. tools will no longer be updated.
                          Any new or updated EEby tool[s] will be issued in this zipped set...
                          However, the 'notes' will remain in each individual tool's thread, and I shall also remove the downloads from each at the next update... [which might be next week].
                          • H
                            haynesc
                            cool ... much easier
                            • majidM
                              majid
                              Thnak you again dear Tig πŸ˜„
                                remus
                                I downloaded this a while ago and forgot to say thanks, so thanks! These are those most sacred of tools that bring entirely new functionality to SU.
                                  Here's today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                  Contains two new tools:
                                  EEbyFace (followme-like tool using a preselected 'flat' face with multiple paths if desired)
                                  EEbyRailsByFace (uses EEbyFace across a mesh picked by Profile/Rail1/Rail2/Melding-Profile just like EEbyRails to form a 'rib-cage')
                                  Links to their threads are in the main page... πŸ€“
                                    dedmin
                                      driven
                                      Hi Tig, more toys,,, excellent
                                      EEbyRailsbyFace isn't working on my Mac, and when I looked at the code, line 632 comments out all lines through to 693 which look important to me.
                                      might this be my issue?
                                      cheers
                                        driven
                                        That code is legacy stiff from EEbyRails that I found I didn't ever need [yet] but I left it in but 'commented' out just in case - so that's not the problem...
                                        When you try it on your Mac what errors do you get in the in the Ruby Console ? πŸ˜•
                                          driven
                                          Error: #<NoMethodError: undefined method db' for #<Object:0x3f319f4>> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/extrudeEdgesByFace.rb:359:in extrudeEdgesByFace'
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/extrudeEdgesByFace.rb:463
                                            Here's an updated zip file http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                            It's issued because the EEbyFace tool had a simple typo in it that meant that whilst it didn't affect my testing of it, it did mess up some of you - it's been fixed in the latest zip file... Sorry for any inconvenience 😳
                                            • 31
                                            • 32
                                            • 3 / 32
