    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 222.6k Views 57 Watching
    • cottyC
      cotty
      And... another one:
      my SketchUp gallery
      • panixiaP
        panixia
        i love the last one, cotty!
        • cottyC
          cotty
          my SketchUp gallery
          • panixiaP
            panixia
            i shared this mini-tutorial in the sub-d section, but i would like to share the link here to, because i also used flowify in the modeling process of this lamp..
            404 Not Found
            (sketchucation.com)
            • cottyC
              cotty
              A XMAS example...
              my SketchUp gallery
                @Cotty
                Happy new year! 😎
                Seems you can use in this last case above only FredoScale! πŸ˜‰
                Use Twice the radial Bending!
                  shahrishabh126
                  it is showing error.please help Sir.
                  • G
                    gnome_mo
                    Do I need to make quad from regular sketchup triangulated model? If so, how?
                    I don't get any errors, just my projection plane gets divided and extruded for the width of my group, but it never gets projected on a needed surface.
                    • V
                      Vizan
                      Hello! How can I apply top geometry to bottom using your plugin?
                        It's not an "Apply" it's a "Deformation" πŸ˜‰
                        So maybe the result can be that you want...
                        https://sketchucation.com/forums/download/file.php?id=129748
                        • B
                          bhuta_n
                          I cant use flowify in sketchup 8. Is is compatibele with SK 8?
                          • N
                            Nan Htet Htet Aye Mon
                            Hello...
                            I am using the sketchup 2020 and cannot use it in mine.
                            Is it not support for 2020 version yet?
                            • cottyC
                              cotty
                              Flowify do work in 2020...
                              my SketchUp gallery
                              • alvisA
                                alvis
                                [attachment=0:zcrmklbm]<!-- ia0 -->img_15112019_181118.jpg<!-- ia0 -->[/attachment:zcrmklbm]
                                403 Forbidden
                                (sketchucation.com)
                                • N
                                  Hi Caul...
                                  Thank you so much for the amazing plug in.
                                  I want to use Flowify in Sketchup 2020.
                                  Any update for it.
                                  Thank you
                                  • cottyC
                                    cotty
                                    @nan htet htet aye mon said:
                                    Hi Caul...
                                    Any update for it.
                                    Thank you
                                    Did you read my answer to your last question?
                                    my SketchUp gallery
                                    • E
                                      emygarbanzo
                                      Hi, I have tried to use flowify a lot of times and it just doesnt work, i dont know if its because of my sketchup or something else. I have folowed every step there is so I dont know what to do.
                                      I would aprreciate so much if someone could help me.
                                      flowify 3d.skp
                                      • cottyC
                                        cotty
                                        You need a "Group with [only] target surface" here too...
                                        my SketchUp gallery
                                        • H
                                          hrachid
                                          I'm facing a problem with the extension,,,,
                                          I'm using ketchup 2018,, and when i reopen the file the extension disappears !!!!
                                          anyone can help?
                                            silbedia
                                            I'm having an issue imposing a grid on a curved 3D surface. I have the projection plane group, target surface group, and connection edge group, all in one group. When I select the entire group and do extensions > flowify > impose grid, in order to check to see if it all works right, I dont get a grid. I adjusted the target surface so that there isnt overlapping geometry (which is barely present at the bottom of the cone) but that still didn't make a difference.
                                            My target surface group uses a radial grid and not a rectangular grid in its hidden geometry, is this the problem? When I try it using a target surface with simpler rectangular geometry it works fine.
                                            • 4 / 7
