    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 220.7k Views 57 Watching
    • cottyC
      cotty
      my SketchUp gallery
      • panixiaP
        panixia
        i shared this mini-tutorial in the sub-d section, but i would like to share the link here to, because i also used flowify in the modeling process of this lamp..
        404 Not Found
        (sketchucation.com)
        • cottyC
          cotty
          A XMAS example...
          my SketchUp gallery
            @Cotty
            Happy new year! 😎
            Seems you can use in this last case above only FredoScale! πŸ˜‰
            Use Twice the radial Bending!
              shahrishabh126
              it is showing error.please help Sir.
              • G
                gnome_mo
                Do I need to make quad from regular sketchup triangulated model? If so, how?
                I don't get any errors, just my projection plane gets divided and extruded for the width of my group, but it never gets projected on a needed surface.
                • V
                  Vizan
                  Hello! How can I apply top geometry to bottom using your plugin?
                    It's not an "Apply" it's a "Deformation" πŸ˜‰
                    So maybe the result can be that you want...
                    https://sketchucation.com/forums/download/file.php?id=129748
                    • B
                      bhuta_n
                      I cant use flowify in sketchup 8. Is is compatibele with SK 8?
                      • N
                        Nan Htet Htet Aye Mon
                        Hello...
                        I am using the sketchup 2020 and cannot use it in mine.
                        Is it not support for 2020 version yet?
                        • cottyC
                          cotty
                          Flowify do work in 2020...
                          my SketchUp gallery
                          • alvisA
                            alvis
                            [attachment=0:zcrmklbm]<!-- ia0 -->img_15112019_181118.jpg<!-- ia0 -->[/attachment:zcrmklbm]
                            403 Forbidden
                            (sketchucation.com)
                            • N
                              Hi Caul...
                              Thank you so much for the amazing plug in.
                              I want to use Flowify in Sketchup 2020.
                              Any update for it.
                              Thank you
                              • cottyC
                                cotty
                                @nan htet htet aye mon said:
                                Hi Caul...
                                Any update for it.
                                Thank you
                                Did you read my answer to your last question?
                                my SketchUp gallery
                                • E
                                  emygarbanzo
                                  Hi, I have tried to use flowify a lot of times and it just doesnt work, i dont know if its because of my sketchup or something else. I have folowed every step there is so I dont know what to do.
                                  I would aprreciate so much if someone could help me.
                                  flowify 3d.skp
                                  • cottyC
                                    cotty
                                    You need a "Group with [only] target surface" here too...
                                    my SketchUp gallery
                                    • H
                                      hrachid
                                      I'm facing a problem with the extension,,,,
                                      I'm using ketchup 2018,, and when i reopen the file the extension disappears !!!!
                                      anyone can help?
                                        silbedia
                                        I'm having an issue imposing a grid on a curved 3D surface. I have the projection plane group, target surface group, and connection edge group, all in one group. When I select the entire group and do extensions > flowify > impose grid, in order to check to see if it all works right, I dont get a grid. I adjusted the target surface so that there isnt overlapping geometry (which is barely present at the bottom of the cone) but that still didn't make a difference.
                                        My target surface group uses a radial grid and not a rectangular grid in its hidden geometry, is this the problem? When I try it using a target surface with simpler rectangular geometry it works fine.
                                          Jamie1407
                                          it doesnt appear and error so i guess now everything is ok. but when i click on flowify it doesnt do anything i keep waiting and nothing not even an error. Nothing.
                                          thanks for your help. any help will be useful.
                                          here is the file
                                            @ Jamie If you want some help post your file in V6 or Maxi 2017 Make ! πŸ˜„
                                            https://i.postimg.cc/FzgQ2pTb/v6.jpg
                                            • 4 / 7
