    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 222.6k Views 57 Watching
      It's not an "Apply" it's a "Deformation" πŸ˜‰
      So maybe the result can be that you want...
      https://sketchucation.com/forums/download/file.php?id=129748
      • B
        bhuta_n
        I cant use flowify in sketchup 8. Is is compatibele with SK 8?
        • N
          Nan Htet Htet Aye Mon
          Hello...
          I am using the sketchup 2020 and cannot use it in mine.
          Is it not support for 2020 version yet?
          • cottyC
            cotty
            Flowify do work in 2020...
            my SketchUp gallery
            • alvisA
              alvis
              @vizan said:
              Hello! How can I apply top geometry to bottom using your plugin?
              [attachment=0:zcrmklbm]<!-- ia0 -->img_15112019_181118.jpg<!-- ia0 -->[/attachment:zcrmklbm]
              403 Forbidden
              (sketchucation.com)
              • N
                Hi Caul...
                Thank you so much for the amazing plug in.
                I want to use Flowify in Sketchup 2020.
                Any update for it.
                Thank you
                • cottyC
                  cotty
                  @nan htet htet aye mon said:
                  Hi Caul...
                  Any update for it.
                  Thank you
                  Did you read my answer to your last question?
                  my SketchUp gallery
                  • E
                    emygarbanzo
                    Hi, I have tried to use flowify a lot of times and it just doesnt work, i dont know if its because of my sketchup or something else. I have folowed every step there is so I dont know what to do.
                    I would aprreciate so much if someone could help me.
                    flowify 3d.skp
                    • cottyC
                      cotty
                      You need a "Group with [only] target surface" here too...
                      my SketchUp gallery
                      • H
                        hrachid
                        I'm facing a problem with the extension,,,,
                        I'm using ketchup 2018,, and when i reopen the file the extension disappears !!!!
                        anyone can help?
                          silbedia
                          I'm having an issue imposing a grid on a curved 3D surface. I have the projection plane group, target surface group, and connection edge group, all in one group. When I select the entire group and do extensions > flowify > impose grid, in order to check to see if it all works right, I dont get a grid. I adjusted the target surface so that there isnt overlapping geometry (which is barely present at the bottom of the cone) but that still didn't make a difference.
                          My target surface group uses a radial grid and not a rectangular grid in its hidden geometry, is this the problem? When I try it using a target surface with simpler rectangular geometry it works fine.
                            Jamie1407
                            it doesnt appear and error so i guess now everything is ok. but when i click on flowify it doesnt do anything i keep waiting and nothing not even an error. Nothing.
                            thanks for your help. any help will be useful.
                            here is the file
                              @ Jamie If you want some help post your file in V6 or Maxi 2017 Make ! πŸ˜„
                              https://i.postimg.cc/FzgQ2pTb/v6.jpg
                              • N
                                nlipovac
                                On destination mesh:
                                You have two group levels inside that mesh group so I exploded that one.
                                I removed the rim around that mesh since it is not needed to wrap that Voronoi mesh.
                                Run Solid inspector and removed stay edges.
                                Removed line group and created it again.
                                On Voronoi mesh I removed thickness, you can add it after you create a new one using the JointPushPull plugin.
                                There are some weird spikes after I run Flowify but you can move them to their position manually.
                                flowifyy help.skp
                                  Jamie1407
                                  Omg thank so much!
                                    junie1111
                                    Hi there, can I ask one thing?
                                    I tried to use plugin but I guess doesn't work when file is huge....
                                    Clicked plugin and nothing happened. No alarm.....
                                    Is there any method without divide geometry?
                                    Any help will be helpful
                                    Many thanks.
                                    sketchup.skp
                                      amycreech
                                      Hello!
                                      I'm trying to use the Flowify extension to apply tufting to a curved sofa, but it looks like Flowify is only compatible with Sketchup 2019 and under. I was wondering if there is a similar extension I can use to do the same effect of bending the geometry?
                                      Thank you in advance,
                                      Amy
                                      • N
                                        nlipovac
                                        @amycreech said:
                                        Hello!
                                        Amy
                                        I use Flowify for that purpose also and it works in SU 2021 just fine.
                                        Can you post pictures or a file so we can see what is the problem?
                                        • N
                                          nlipovac
                                          Many thanks.
                                          So I deleted some of your model because I do not have time to do it all.
                                          You should try and do a portion at a time to have more control and to not stall your computer.
                                          I used just the Flowify method and not Flowify without cut
                                          Here is my try on curved baluster:
                                          https://1drv.ms/u/s!AkMAr9Me_-ODgY4pxDlGCkxKzsr4nQ?e=Fc6HRZ
                                          Few notes:
                                          • You can not use components, only groups
                                          • Clean your model of unnecessary geometry, like internal geometry.
                                          • Clean your model of unnecessary lines, if you do not have any use for them.
                                            MalGaming
                                            Hello Caul ,
                                            Can You Update For Sketchup Pro 2020 ??
                                            • 5 / 7
