    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 227.1k Views 57 Watching
    • cottyC
      cotty
      A XMAS example...
      my SketchUp gallery
        @Cotty
        Happy new year! 😎
        Seems you can use in this last case above only FredoScale! πŸ˜‰
        Use Twice the radial Bending!
          shahrishabh126
          it is showing error.please help Sir.
          • G
            gnome_mo
            Do I need to make quad from regular sketchup triangulated model? If so, how?
            I don't get any errors, just my projection plane gets divided and extruded for the width of my group, but it never gets projected on a needed surface.
            • V
              Vizan
              Hello! How can I apply top geometry to bottom using your plugin?
                It's not an "Apply" it's a "Deformation" πŸ˜‰
                So maybe the result can be that you want...
                https://sketchucation.com/forums/download/file.php?id=129748
                • B
                  bhuta_n
                  I cant use flowify in sketchup 8. Is is compatibele with SK 8?
                  • N
                    Nan Htet Htet Aye Mon
                    Hello...
                    I am using the sketchup 2020 and cannot use it in mine.
                    Is it not support for 2020 version yet?
                    • cottyC
                      cotty
                      Flowify do work in 2020...
                      my SketchUp gallery
                      • alvisA
                        alvis
                        [attachment=0:zcrmklbm]<!-- ia0 -->img_15112019_181118.jpg<!-- ia0 -->[/attachment:zcrmklbm]
                        403 Forbidden
                        (sketchucation.com)
                        • N
                          Hi Caul...
                          Thank you so much for the amazing plug in.
                          I want to use Flowify in Sketchup 2020.
                          Any update for it.
                          Thank you
                          • cottyC
                            cotty
                            @nan htet htet aye mon said:
                            Hi Caul...
                            Any update for it.
                            Thank you
                            Did you read my answer to your last question?
                            my SketchUp gallery
                            • E
                              emygarbanzo
                              Hi, I have tried to use flowify a lot of times and it just doesnt work, i dont know if its because of my sketchup or something else. I have folowed every step there is so I dont know what to do.
                              I would aprreciate so much if someone could help me.
                              flowify 3d.skp
                              • cottyC
                                cotty
                                You need a "Group with [only] target surface" here too...
                                my SketchUp gallery
                                • H
                                  hrachid
                                  I'm facing a problem with the extension,,,,
                                  I'm using ketchup 2018,, and when i reopen the file the extension disappears !!!!
                                  anyone can help?
                                    silbedia
                                    I'm having an issue imposing a grid on a curved 3D surface. I have the projection plane group, target surface group, and connection edge group, all in one group. When I select the entire group and do extensions > flowify > impose grid, in order to check to see if it all works right, I dont get a grid. I adjusted the target surface so that there isnt overlapping geometry (which is barely present at the bottom of the cone) but that still didn't make a difference.
                                    My target surface group uses a radial grid and not a rectangular grid in its hidden geometry, is this the problem? When I try it using a target surface with simpler rectangular geometry it works fine.
                                      Jamie1407
                                      it doesnt appear and error so i guess now everything is ok. but when i click on flowify it doesnt do anything i keep waiting and nothing not even an error. Nothing.
                                      thanks for your help. any help will be useful.
                                      here is the file
                                        @ Jamie If you want some help post your file in V6 or Maxi 2017 Make ! πŸ˜„
                                        https://i.postimg.cc/FzgQ2pTb/v6.jpg
                                        • N
                                          nlipovac
                                          On destination mesh:
                                          You have two group levels inside that mesh group so I exploded that one.
                                          I removed the rim around that mesh since it is not needed to wrap that Voronoi mesh.
                                          Run Solid inspector and removed stay edges.
                                          Removed line group and created it again.
                                          On Voronoi mesh I removed thickness, you can add it after you create a new one using the JointPushPull plugin.
                                          There are some weird spikes after I run Flowify but you can move them to their position manually.
                                          flowifyy help.skp
                                            Jamie1407
                                            Omg thank so much!
                                            • 5 / 7
