    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 222.6k Views 57 Watching
    • cottyC
      cotty
      Another example model...
      flowify_cotty_07.skp
      my SketchUp gallery
      • cottyC
        cotty
        Another example...
        my SketchUp gallery
        • cottyC
          cotty
          And another one...
          my SketchUp gallery
            Funny use results! 😎
            • cottyC
              cotty
              And... another one:
              my SketchUp gallery
              • panixiaP
                panixia
                i love the last one, cotty!
                • cottyC
                  cotty
                  my SketchUp gallery
                  • panixiaP
                    panixia
                    i shared this mini-tutorial in the sub-d section, but i would like to share the link here to, because i also used flowify in the modeling process of this lamp..
                    404 Not Found
                    (sketchucation.com)
                    • cottyC
                      cotty
                      A XMAS example...
                      my SketchUp gallery
                        @Cotty
                        Happy new year! 😎
                        Seems you can use in this last case above only FredoScale! πŸ˜‰
                        Use Twice the radial Bending!
                          shahrishabh126
                          it is showing error.please help Sir.
                          • G
                            gnome_mo
                            Do I need to make quad from regular sketchup triangulated model? If so, how?
                            I don't get any errors, just my projection plane gets divided and extruded for the width of my group, but it never gets projected on a needed surface.
                            • V
                              Vizan
                              Hello! How can I apply top geometry to bottom using your plugin?
                                It's not an "Apply" it's a "Deformation" πŸ˜‰
                                So maybe the result can be that you want...
                                https://sketchucation.com/forums/download/file.php?id=129748
                                • B
                                  bhuta_n
                                  I cant use flowify in sketchup 8. Is is compatibele with SK 8?
                                  • N
                                    Nan Htet Htet Aye Mon
                                    Hello...
                                    I am using the sketchup 2020 and cannot use it in mine.
                                    Is it not support for 2020 version yet?
                                    • cottyC
                                      cotty
                                      Flowify do work in 2020...
                                      my SketchUp gallery
                                      • alvisA
                                        alvis
                                        [attachment=0:zcrmklbm]<!-- ia0 -->img_15112019_181118.jpg<!-- ia0 -->[/attachment:zcrmklbm]
                                        403 Forbidden
                                        (sketchucation.com)
                                        • N
                                          Hi Caul...
                                          Thank you so much for the amazing plug in.
                                          I want to use Flowify in Sketchup 2020.
                                          Any update for it.
                                          Thank you
                                          • cottyC
                                            cotty
                                            @nan htet htet aye mon said:
                                            Hi Caul...
                                            Any update for it.
                                            Thank you
                                            Did you read my answer to your last question?
                                            my SketchUp gallery
                                            • 4 / 7
