    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 938.1k Views 155 Watching
      Ahmed0007
      @fredo6 said:
      I am unable to reproduce the problem either....
      Do you get it always?
      Thanks for reply
      i haven't used random push pull a lot.
      i found an old version of JPP (v3.6a) this also give me bugsplat screen. in su19
      watch here : http://bit.ly/31SyEk5
      Edit ; and latest version of JPP is working fine with SU2017
        You never answered my question about proper installation of SketchUp. Did you install SketchUp 2018 and 2019 correctly?
          Ahmed0007
          sorry i don't remember that how i had installed.
          but give main an hour to reinstall as you said.
            You do not need to 'reinstall'.
            Login as your normal Windows user-account.
            Ensure SketchUp is closed.
            Find the SketchUp installer file's exe icon - it's probably in your Downloads folder.
            Then select it, right-click > context-menu > "Run as administrator"
            When prompted choose "Repair"
            Done.
            It will not harm your existing set up - just 'repair' it, if that is necessary
              Ahmed0007
              Done.
              oh! Thanks πŸ‘
                Ahmed0007
                i have done proper installation of SketchUp.
                and i have still same issue.
                • fredo6F
                  Since the bugsplat is reproducible on your environment and is not on Dave's or mine, there must be something on your side, possibly a conflict with another plugin (maybe a redefinition of random methods).
                  If you have time, could you remove suspicious plugins, in general not mainstream, and check if you get the bug splat.
                  Many thanks
                    Ahmed0007
                    Many thanks
                    i already tried with only JPP and fredoLib installed. but this also not work.
                    but you're right there is something wrong with my pc.
                    today i tested JPP on my brother pc and it's working fine there.
                    i don't know what i should do to fix this issue.
                    reinstall windows?
                    any suggestion?
                    and Thanks for your time.
                    • fredo6F
                      No need to reinstall Windows...
                      Did you try with another model file?
                      Also, can you confirm that
                      • you get the bugsplat only when using the Random feature of JPP
                      • whether this happens for both Normal and Joint tools (since both have a random option)
                        Ahmed0007
                        with all JPP tools and with any model
                        Video : https://streamable.com/upjw5
                          When you get the Bug Splats are you sending them in with your e-mail address attached? As a licensed SketchUp Pro user with up-to-date Maintenance and Support, you could file a ticket with their Technical Support folks and ask them to look at the Bug Splat reports and decipher what is happening to cause the splat. At this point, since you seem to be the only one having a problem and we can't reproduce the Bug Splats even with your file, more information is needed.
                            Ahmed0007
                            @ahmed0007 said:
                            Getting a bugsplat when trying to change the random push pull values. in sketchup 2019 and 18
                            any solution?
                            problem fixed after doing following steps:
                            Uninstall sketchup (2019 and 18) with revo uninstall (also delete Leftovers items and registry files)
                            Reinstall only su19
                            after opening first time this give me this error "mfc140u.dll" Missing
                            install Visual C++ Redistributable for Visual Studio 2015
                            and
                            uninstall Visual C++ Redistributable for Visual Studio 2017
                            Done!
                            Thank you Fredo6 and Dave R for response.
                            • fredo6F
                              Glad to see that it now works for you.
                              Still, this is puzzling, and I don't really see why JointPushPull would specifically crash in relation to the version of C++, since it is pure Ruby.
                              • BoxB
                                Hi Fredo,
                                I was just doing a gif to show something in JPP and noticed it breaks the dimension connection.
                                Checked 2018,19,20.
                                FredoScale for example doesn't break the connection.
                                Not sure if it has always been that way and I just don't remember it being like that.
                                  Breaking also in the 2017! πŸ˜‰
                                  • fredo6F
                                    JointPushPull technically creates faces (and thus new vertices), whereas FredoScale just uses a scaling transformation and therefore keeps the faces and vertices homologous.
                                    JointPushPull does not use native pushpull methods, due to the fact that it is multi-face tool.
                                    So it is normal that JPP loses the dimension connections.
                                    Reconstructing them is maybe possible, but probably some work due to the variety of topological situations, and also the poor support of the API for dimensions. I have to check if the connections are exposed in the API and can be reconstructed.
                                    EDIT: just checked that for linear dimensions, there is a possibility to manage the attachment, but as of SU2019.
                                    • BoxB
                                      Thanks for letting me know, I was just pointing it out incase it was a bug, just one of those things I hadn't noticed before.
                                      • H
                                        hugoakio
                                        I need a help. I'm trying to export an object and experimenting the folling error at the "erase coplanar edges":
                                        An error occurred in Round Push Pull
                                        Error in generation of the geometry
                                        reference to deleted Entity
                                        jointpushpullgeometry.rbe: 1023 -- entityID
                                        jointpushpullgeometry.rbe: 1023 -- block in geometry_coplanar_edges
                                        jointpushpullgeometry.rbe: 1020 -- each
                                        jointpushpullgeometry.rbe: 1020 -- geometry_coplanar_edges
                                        jointpushpullgeometry.rbe: 366 -- block in geometry_robot_erase_coplanar_edges
                                        jointpushpullgeometry.rbe: 362 -- each
                                        jointpushpullgeometry.rbe: 362 -- geometry_robot_erase_coplanar_edges
                                        jointpushpullgeometry.rbe: 220 -- robot_call_action
                                        jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
                                        jointpushpullgeometry.rbe: 166 -- geometry_robot
                                        jointpushpullgeometry.rbe: 81 -- block in geometry_execute
                                        lib6operation.rbe: 370 -- step_geometry
                                        lib6operation.rbe: 305 -- block in yield?
                                        What i'm doing wrong?
                                        • fredo6F
                                          Nothing a priori.
                                          I have fixed the problem itself (to go in a next version of JPP), but that does not mean you will get a correct result, because you must likely be in a special situation of topology (which RoundPushPull is very sensitive to).
                                          It would help if you posted the model and indicate which operation you were trying to perform.
                                            daniabreu1
                                            Hi, I am having a problem with this plugin SU2020 - Trying to use the jointpushpull= and a little grade surface keep showing up and the tool doesn't work. Any solutions?
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 30
                                            • 31
                                            • 22 / 31
