    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 938.1k Views 155 Watching
      Ahmed0007
      @dave r said:
      You never answered my question about proper installation of SketchUp. Did you install SketchUp 2018 and 2019 correctly?
      i have done proper installation of SketchUp.
      and i have still same issue.
      • fredo6F
        Since the bugsplat is reproducible on your environment and is not on Dave's or mine, there must be something on your side, possibly a conflict with another plugin (maybe a redefinition of random methods).
        If you have time, could you remove suspicious plugins, in general not mainstream, and check if you get the bug splat.
        Many thanks
          Ahmed0007
          Many thanks
          i already tried with only JPP and fredoLib installed. but this also not work.
          but you're right there is something wrong with my pc.
          today i tested JPP on my brother pc and it's working fine there.
          i don't know what i should do to fix this issue.
          reinstall windows?
          any suggestion?
          and Thanks for your time.
          • fredo6F
            No need to reinstall Windows...
            Did you try with another model file?
            Also, can you confirm that
            • you get the bugsplat only when using the Random feature of JPP
            • whether this happens for both Normal and Joint tools (since both have a random option)
              Ahmed0007
              with all JPP tools and with any model
              Video : https://streamable.com/upjw5
                When you get the Bug Splats are you sending them in with your e-mail address attached? As a licensed SketchUp Pro user with up-to-date Maintenance and Support, you could file a ticket with their Technical Support folks and ask them to look at the Bug Splat reports and decipher what is happening to cause the splat. At this point, since you seem to be the only one having a problem and we can't reproduce the Bug Splats even with your file, more information is needed.
                  Ahmed0007
                  @ahmed0007 said:
                  Getting a bugsplat when trying to change the random push pull values. in sketchup 2019 and 18
                  any solution?
                  problem fixed after doing following steps:
                  Uninstall sketchup (2019 and 18) with revo uninstall (also delete Leftovers items and registry files)
                  Reinstall only su19
                  after opening first time this give me this error "mfc140u.dll" Missing
                  install Visual C++ Redistributable for Visual Studio 2015
                  and
                  uninstall Visual C++ Redistributable for Visual Studio 2017
                  Done!
                  Thank you Fredo6 and Dave R for response.
                  • fredo6F
                    Glad to see that it now works for you.
                    Still, this is puzzling, and I don't really see why JointPushPull would specifically crash in relation to the version of C++, since it is pure Ruby.
                    • BoxB
                      Hi Fredo,
                      I was just doing a gif to show something in JPP and noticed it breaks the dimension connection.
                      Checked 2018,19,20.
                      FredoScale for example doesn't break the connection.
                      Not sure if it has always been that way and I just don't remember it being like that.
                        Breaking also in the 2017! ๐Ÿ˜‰
                        • fredo6F
                          JointPushPull technically creates faces (and thus new vertices), whereas FredoScale just uses a scaling transformation and therefore keeps the faces and vertices homologous.
                          JointPushPull does not use native pushpull methods, due to the fact that it is multi-face tool.
                          So it is normal that JPP loses the dimension connections.
                          Reconstructing them is maybe possible, but probably some work due to the variety of topological situations, and also the poor support of the API for dimensions. I have to check if the connections are exposed in the API and can be reconstructed.
                          EDIT: just checked that for linear dimensions, there is a possibility to manage the attachment, but as of SU2019.
                          • BoxB
                            Thanks for letting me know, I was just pointing it out incase it was a bug, just one of those things I hadn't noticed before.
                            • H
                              hugoakio
                              I need a help. I'm trying to export an object and experimenting the folling error at the "erase coplanar edges":
                              An error occurred in Round Push Pull
                              Error in generation of the geometry
                              reference to deleted Entity
                              jointpushpullgeometry.rbe: 1023 -- entityID
                              jointpushpullgeometry.rbe: 1023 -- block in geometry_coplanar_edges
                              jointpushpullgeometry.rbe: 1020 -- each
                              jointpushpullgeometry.rbe: 1020 -- geometry_coplanar_edges
                              jointpushpullgeometry.rbe: 366 -- block in geometry_robot_erase_coplanar_edges
                              jointpushpullgeometry.rbe: 362 -- each
                              jointpushpullgeometry.rbe: 362 -- geometry_robot_erase_coplanar_edges
                              jointpushpullgeometry.rbe: 220 -- robot_call_action
                              jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
                              jointpushpullgeometry.rbe: 166 -- geometry_robot
                              jointpushpullgeometry.rbe: 81 -- block in geometry_execute
                              lib6operation.rbe: 370 -- step_geometry
                              lib6operation.rbe: 305 -- block in yield?
                              What i'm doing wrong?
                              • fredo6F
                                Nothing a priori.
                                I have fixed the problem itself (to go in a next version of JPP), but that does not mean you will get a correct result, because you must likely be in a special situation of topology (which RoundPushPull is very sensitive to).
                                It would help if you posted the model and indicate which operation you were trying to perform.
                                  daniabreu1
                                  Hi, I am having a problem with this plugin SU2020 - Trying to use the jointpushpull= and a little grade surface keep showing up and the tool doesn't work. Any solutions?
                                    You've given no useful information making it impossible to help. Share your SketchUp file and give a clear description of what you are trying to accomplish. Also show us what settings you are using with the extension.
                                      daniabreu1
                                      Thanks Dave. Somehow I uninstall it and installed again and it works. Thank you for trying to help tho! ๐Ÿ˜„
                                        daniabreu1
                                        Good evening everybody,
                                        Again I am having problem ith the thickener.
                                        Date: 15-Apr-20 20:31:28
                                        An error occurred in Thickener
                                        Cannot convert argument to Geom::Point3d
                                        jointpushpullgeometry.rbe:: 531 -- vector_to
                                        jointpushpullgeometry.rbe:: 531 -- geometry_block_reversal
                                        jointpushpullgeometry.rbe:: 243 -- geometry_robot_prepare_mesh
                                        jointpushpullgeometry.rbe:: 212 -- robot_call_action
                                        jointpushpullgeometry.rbe:: 183 -- geometry_robot_exec
                                        jointpushpullgeometry.rbe:: 166 -- geometry_robot
                                        jointpushpullgeometry.rbe:: 81 -- block in geometry_execute
                                        lib6operation.rbe:: 370 -- step_geometry
                                        lib6operation.rbe:: 419 -- start_execution
                                        jointpushpullgeometry.rbe:: 81 -- geometry_execute
                                        jointpushpulltool.rbe:: 1118 -- go_preview_or_geom
                                        jointpushpulltool.rbe:: 844 -- dragging_stop
                                        jointpushpulltool.rbe:: 1399 -- execute_validate
                                        jointpushpulltool.rbe:: 1590 -- onReturn
                                        I have LibFredo6v9.5k and using SU2020. There is a post describing almost the same thing:
                                        "It's a fairly complex surface - a piece of terrain that is a hill with sections cut out of it (I draped a road onto the surface so that counts as a separate surface, for example)."
                                        It was solve with Libfredo 9.0 but I have 9.5 version.
                                        Any idea?
                                        Thank you all.
                                        • fredo6F
                                          I fixed the error in the code, but somehow this reflects a problem or complexity in the generated geometry. It may be helpful to get the model where it happens.
                                          I am no longer able to publish updates to my plugins, pending Sketchup changes to their releasing process for developers.
                                          So the fix will go in the next version whenever I can resume publishing.
                                            rv1974
                                            Hi Fredo,
                                            Say I have a surface cut to non-coplanar patches by visible edges.
                                            I can't find a proper combination of Borders+Surface selection settings to perform a global JPP so every patch would get an independent border by contour (BTW there's some negative molding).
                                            I'm able to JJP manually patch-by-patch (demonstrated in attached gif) but there's no way to process all surface en-masse instantly.
                                            Would it be possible to implement please?
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 30
                                            • 31
                                            • 22 / 31
