    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 631.5k Views 155 Watching
    • fredo6F Offline
      @jonnys777 said:
      I'm not having much luck resolving this. I've tried scaling up and inspecting the surface to see if there's anything obviously wrong. It allows Normal Push Pull, but Vector, Joint etc. all fail. Any ideas as to what might be wrong?
      I included a fix in LibFredo6 9.0a
      @jonnys777 said:
      It's a fairly complex surface - a piece of terrain that is a hill with sections cut out of it (I draped a road onto the surface so that counts as a separate surface, for example). The surface I want to extrude is vegetation and I need it locked to the z-axis otherwise the software I intend to import it into won't work properly.
      If you post or PM me the model, I can have a look and advise.
        jonnys777
        Hi Fredo, I can confirm the updated version of LibFredo has solved my issues. Many thanks, and keep up the good work.
          DigitalArena
          Have a problem with one installation of this set of tools on Pro 2019. We have the latest Fredo6Lib. We have installed the latest JointPushPull plugin. The tools appear in the toolbar. But when you select the surface and then the tool, the tool doesn't become active. You remain with the mouse pointer and it doesn't change to the selected JointPushPull tool.
          Any idea why this would be happening?
          We installed the same setup on another computer and everything is fine. Thoughts?
            When SketchUp 2019 was installed, did you right click on the installer and choose Run as administrator?
            • deaneauD Offline
              deaneau
              Feature Request in this Plugin
              Hi Fredo is this possible to have an offset of faces with the same material?
              I need this for a game.
              The windows in the night will be the only face that has an offset. this face will save as a separate file (night mesh).
              big thank you
              https://i.ibb.co/Jvbyv1d/2019-08-22-01h34-49.png
              https://i.ibb.co/9rTf66k/2019-08-22-01h46-05day.png
              https://i.ibb.co/ThbggvQ/2019-08-22-01h46-25-night.png
                Ahmed0007
                Getting a bugsplat when trying to change the random push pull values. in sketchup 2019 and 18
                any solution?
                  @ahmed0007 said:
                  Getting a bugsplat... any solution?
                  You'd need to provide some useful information to be able to diagnose the problem and find a solution. Share the SKP file and the values you are trying to use.
                    Ahmed0007
                    here are:
                    J.skp
                      I don't have any problems with your file in SU2019.
                      Click on the picture to see it move.
                      Make sure have the current version installed along with the current version of LibFredo6 and make sure you installed SketchUp correctly. That is, you right clicked on the installer and selected Run as administrator from the context menu.
                        Ahmed0007
                        [attachment=0:22w16jj0]<!-- ia0 -->Random PushPull.gif<!-- ia0 -->[/attachment:22w16jj0]
                        yesterday i installed both JPP and Fredo6lib
                        everything is up to date
                        watch this https://streamable.com/oqz8g
                        • fredo6F Offline
                          I am unable to reproduce the problem either....
                          Do you get it always?
                            Ahmed0007
                            and latest version of JPP is working fine with SU2017
                              Ahmed0007
                              Thanks for reply
                              i haven't used random push pull a lot.
                              i found an old version of JPP (v3.6a) this also give me bugsplat screen. in su19
                              watch here : http://bit.ly/31SyEk5
                              Edit ; and latest version of JPP is working fine with SU2017
                                You never answered my question about proper installation of SketchUp. Did you install SketchUp 2018 and 2019 correctly?
                                  Ahmed0007
                                  sorry i don't remember that how i had installed.
                                  but give main an hour to reinstall as you said.
                                    You do not need to 'reinstall'.
                                    Login as your normal Windows user-account.
                                    Ensure SketchUp is closed.
                                    Find the SketchUp installer file's exe icon - it's probably in your Downloads folder.
                                    Then select it, right-click > context-menu > "Run as administrator"
                                    When prompted choose "Repair"
                                    Done.
                                    It will not harm your existing set up - just 'repair' it, if that is necessary
                                      Ahmed0007
                                      Done.
                                      oh! Thanks πŸ‘
                                        Ahmed0007
                                        i have done proper installation of SketchUp.
                                        and i have still same issue.
                                        • fredo6F Offline
                                          Since the bugsplat is reproducible on your environment and is not on Dave's or mine, there must be something on your side, possibly a conflict with another plugin (maybe a redefinition of random methods).
                                          If you have time, could you remove suspicious plugins, in general not mainstream, and check if you get the bug splat.
                                          Many thanks
                                            Ahmed0007
                                            Many thanks
                                            i already tried with only JPP and fredoLib installed. but this also not work.
                                            but you're right there is something wrong with my pc.
                                            today i tested JPP on my brother pc and it's working fine there.
                                            i don't know what i should do to fix this issue.
                                            reinstall windows?
                                            any suggestion?
                                            and Thanks for your time.
                                            • 30
                                            • 31
                                            • 4 / 31
