    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 657.2k Views 155 Watching
    • E Offline
      Einstein
      Thank you πŸ˜„
      • fredo6F Offline
        NEW RELEASE: JointPushPull Interactive v4.4e - 02 Jun 19
        JointPushPull Interactive 4.4e is a minor release including an increase of the maximum angle for Molding (now 85 degrees).
        JointPushPull 4.4e requires LibFredo6 8.7m or above
        See plugin home page of JointPushPull for Download of JointPushPull.
        Main Post of the JointPushPull thread on this forum
        • E Offline
          Einstein
          Thank you, for me it's a major release πŸ˜„
            jonnys777
            Morning all,
            I'm getting the follow error trying to thicken some terrain on the z-axis;
            Date: 20-Jun-19 08:06:15
            An error occurred in Vector Push Pull
            Error in generation of the geometry
            Could not compute valid matrix from points
            body_lib6g6.rbe: 4568 -- position_material
            body_lib6g6.rbe: 4568 -- reverse_face_with_uv
            jointpushpullgeometry.rbe: 556 -- block in geometry_handle_finishing
            jointpushpullgeometry.rbe: 556 -- each
            jointpushpullgeometry.rbe: 556 -- geometry_handle_finishing
            jointpushpullgeometry.rbe: 376 -- geometry_robot_handle_finishing
            jointpushpullgeometry.rbe: 222 -- robot_call_action
            jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
            jointpushpullgeometry.rbe: 166 -- geometry_robot
            jointpushpullgeometry.rbe: 81 -- block in geometry_execute
            lib6operation.rbe: 370 -- call
            lib6operation.rbe: 370 -- step_geometry
            lib6operation.rbe: 305 -- block in yield?
            SketchUp: 1 -- call
              jonnys777
              @jonnys777 said:
              Morning all,
              SketchUp: 1 -- call
              I'm not having much luck resolving this. I've tried scaling up and inspecting the surface to see if there's anything obviously wrong. It allows Normal Push Pull, but Vector, Joint etc. all fail.
              Any ideas as to what might be wrong?
              It's a fairly complex surface - a piece of terrain that is a hill with sections cut out of it (I draped a road onto the surface so that counts as a separate surface, for example). The surface I want to extrude is vegetation and I need it locked to the z-axis otherwise the software I intend to import it into won't work properly.
              Many thanks
              • fredo6F Offline
                @jonnys777 said:
                I'm not having much luck resolving this. I've tried scaling up and inspecting the surface to see if there's anything obviously wrong. It allows Normal Push Pull, but Vector, Joint etc. all fail. Any ideas as to what might be wrong?
                I included a fix in LibFredo6 9.0a
                If you post or PM me the model, I can have a look and advise.
                  jonnys777
                  Hi Fredo, I can confirm the updated version of LibFredo has solved my issues. Many thanks, and keep up the good work.
                    DigitalArena
                    Have a problem with one installation of this set of tools on Pro 2019. We have the latest Fredo6Lib. We have installed the latest JointPushPull plugin. The tools appear in the toolbar. But when you select the surface and then the tool, the tool doesn't become active. You remain with the mouse pointer and it doesn't change to the selected JointPushPull tool.
                    Any idea why this would be happening?
                    We installed the same setup on another computer and everything is fine. Thoughts?
                      When SketchUp 2019 was installed, did you right click on the installer and choose Run as administrator?
                      • deaneauD Offline
                        deaneau
                        Feature Request in this Plugin
                        Hi Fredo is this possible to have an offset of faces with the same material?
                        I need this for a game.
                        The windows in the night will be the only face that has an offset. this face will save as a separate file (night mesh).
                        big thank you
                        https://i.ibb.co/Jvbyv1d/2019-08-22-01h34-49.png
                        https://i.ibb.co/9rTf66k/2019-08-22-01h46-05day.png
                        https://i.ibb.co/ThbggvQ/2019-08-22-01h46-25-night.png
                          Ahmed0007
                          Getting a bugsplat when trying to change the random push pull values. in sketchup 2019 and 18
                          any solution?
                            @ahmed0007 said:
                            Getting a bugsplat... any solution?
                            You'd need to provide some useful information to be able to diagnose the problem and find a solution. Share the SKP file and the values you are trying to use.
                              Ahmed0007
                              here are:
                              J.skp
                                I don't have any problems with your file in SU2019.
                                Click on the picture to see it move.
                                Make sure have the current version installed along with the current version of LibFredo6 and make sure you installed SketchUp correctly. That is, you right clicked on the installer and selected Run as administrator from the context menu.
                                  Ahmed0007
                                  [attachment=0:22w16jj0]<!-- ia0 -->Random PushPull.gif<!-- ia0 -->[/attachment:22w16jj0]
                                  yesterday i installed both JPP and Fredo6lib
                                  everything is up to date
                                  watch this https://streamable.com/oqz8g
                                  • fredo6F Offline
                                    I am unable to reproduce the problem either....
                                    Do you get it always?
                                      Ahmed0007
                                      and latest version of JPP is working fine with SU2017
                                        Ahmed0007
                                        Thanks for reply
                                        i haven't used random push pull a lot.
                                        i found an old version of JPP (v3.6a) this also give me bugsplat screen. in su19
                                        watch here : http://bit.ly/31SyEk5
                                        Edit ; and latest version of JPP is working fine with SU2017
                                          You never answered my question about proper installation of SketchUp. Did you install SketchUp 2018 and 2019 correctly?
                                            Ahmed0007
                                            sorry i don't remember that how i had installed.
                                            but give main an hour to reinstall as you said.
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 28 / 31
