    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 916.9k Views 155 Watching
      theVonZipper
      Thanks Fredo for the fantastic plugins. I use 'Divide faces' often and of course Joint Push Pull. Just wondering, is there a way for Push Pull Interactive to inherit layers from the faces they are affecting as the Classic version did?
        Faces and edges should always be created on and remain on Layer 0. See Controlling Visibility with Layers.
        • E Offline
          Einstein
          Hi!
          I have an idea for a small feature upgrade.
          Actually, two ideas ^^
          1. Possibility to apply positive + negative offset in one go, so you can thicken a surface on both sides immediately
          2. Extrude faces to point, like in Rhino. It would be almost analogic operation to scaling about a point which can be performed via ThomThom's Rotate and Scale. However, you'd then have to manually connect border edges of source and result meshes. Rhino has a tool which does everything in one step. I attach an illustration for it.
          What do you think about it?
          • fredo6F Offline
            This is doable, though not trivial, because I have two generate two faces for each original face. It would also require an additional option, maybe triggered by a modifier; the only left is ALT (on Windows)
            @einstein said:
            1. Extrude faces to point, like in Rhino. It would be almost analogic operation to scaling about a point which can be performed via ThomThom's Rotate and Scale. However, you'd then have to manually connect border edges of source and result meshes. Rhino has a tool which does everything in one step. I attach an illustration for it.
            This would be a new tool actually. I need to think about it, but a priori an interesting idea.
            • E Offline
              Einstein
              Could you please increase extreme angle values for Molding in the next release? Now it's +- 60, which is a serious limitation in some cases. I'd suggest 89 or even 90 - this would practically create a flat offset (nice!). Certainly, faces would overlap but that could be fixed manually.
              • fredo6F Offline
                If the angle is too large, then you are almost sure to get overlaps and mess up the extrusion.
                Here is what I get with the set of letters, each one of width roughly 0.5 m. I had to reduce the offset of extrusion to 0.001 m (that is, 1mm) to get a molding at 85 deg. without overlap.
                With an offset of 1cm, the extrusion gets seriously messy
                I can increase it to 89 degrees. At 90, you reach math limit, since there is NO extrusion, and JPP does not like it. So, I'll probably pick 85 degrees, to make it a multiple of the 5 deg increment in a next release.
                • E Offline
                  Einstein
                  Thank you πŸ˜„
                  • fredo6F Offline
                    NEW RELEASE: JointPushPull Interactive v4.4e - 02 Jun 19
                    JointPushPull Interactive 4.4e is a minor release including an increase of the maximum angle for Molding (now 85 degrees).
                    JointPushPull 4.4e requires LibFredo6 8.7m or above
                    See plugin home page of JointPushPull for Download of JointPushPull.
                    Main Post of the JointPushPull thread on this forum
                    • E Offline
                      Einstein
                      Thank you, for me it's a major release πŸ˜„
                        jonnys777
                        Morning all,
                        I'm getting the follow error trying to thicken some terrain on the z-axis;
                        Date: 20-Jun-19 08:06:15
                        An error occurred in Vector Push Pull
                        Error in generation of the geometry
                        Could not compute valid matrix from points
                        body_lib6g6.rbe: 4568 -- position_material
                        body_lib6g6.rbe: 4568 -- reverse_face_with_uv
                        jointpushpullgeometry.rbe: 556 -- block in geometry_handle_finishing
                        jointpushpullgeometry.rbe: 556 -- each
                        jointpushpullgeometry.rbe: 556 -- geometry_handle_finishing
                        jointpushpullgeometry.rbe: 376 -- geometry_robot_handle_finishing
                        jointpushpullgeometry.rbe: 222 -- robot_call_action
                        jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
                        jointpushpullgeometry.rbe: 166 -- geometry_robot
                        jointpushpullgeometry.rbe: 81 -- block in geometry_execute
                        lib6operation.rbe: 370 -- call
                        lib6operation.rbe: 370 -- step_geometry
                        lib6operation.rbe: 305 -- block in yield?
                        SketchUp: 1 -- call
                          jonnys777
                          @jonnys777 said:
                          Morning all,
                          SketchUp: 1 -- call
                          I'm not having much luck resolving this. I've tried scaling up and inspecting the surface to see if there's anything obviously wrong. It allows Normal Push Pull, but Vector, Joint etc. all fail.
                          Any ideas as to what might be wrong?
                          It's a fairly complex surface - a piece of terrain that is a hill with sections cut out of it (I draped a road onto the surface so that counts as a separate surface, for example). The surface I want to extrude is vegetation and I need it locked to the z-axis otherwise the software I intend to import it into won't work properly.
                          Many thanks
                          • fredo6F Offline
                            @jonnys777 said:
                            I'm not having much luck resolving this. I've tried scaling up and inspecting the surface to see if there's anything obviously wrong. It allows Normal Push Pull, but Vector, Joint etc. all fail. Any ideas as to what might be wrong?
                            I included a fix in LibFredo6 9.0a
                            If you post or PM me the model, I can have a look and advise.
                              jonnys777
                              Hi Fredo, I can confirm the updated version of LibFredo has solved my issues. Many thanks, and keep up the good work.
                                DigitalArena
                                Have a problem with one installation of this set of tools on Pro 2019. We have the latest Fredo6Lib. We have installed the latest JointPushPull plugin. The tools appear in the toolbar. But when you select the surface and then the tool, the tool doesn't become active. You remain with the mouse pointer and it doesn't change to the selected JointPushPull tool.
                                Any idea why this would be happening?
                                We installed the same setup on another computer and everything is fine. Thoughts?
                                  When SketchUp 2019 was installed, did you right click on the installer and choose Run as administrator?
                                  • deaneauD Offline
                                    deaneau
                                    Feature Request in this Plugin
                                    Hi Fredo is this possible to have an offset of faces with the same material?
                                    I need this for a game.
                                    The windows in the night will be the only face that has an offset. this face will save as a separate file (night mesh).
                                    big thank you
                                    https://i.ibb.co/Jvbyv1d/2019-08-22-01h34-49.png
                                    https://i.ibb.co/9rTf66k/2019-08-22-01h46-05day.png
                                    https://i.ibb.co/ThbggvQ/2019-08-22-01h46-25-night.png
                                      Ahmed0007
                                      Getting a bugsplat when trying to change the random push pull values. in sketchup 2019 and 18
                                      any solution?
                                        @ahmed0007 said:
                                        Getting a bugsplat... any solution?
                                        You'd need to provide some useful information to be able to diagnose the problem and find a solution. Share the SKP file and the values you are trying to use.
                                          Ahmed0007
                                          here are:
                                          J.skp
                                            I don't have any problems with your file in SU2019.
                                            Click on the picture to see it move.
                                            Make sure have the current version installed along with the current version of LibFredo6 and make sure you installed SketchUp correctly. That is, you right clicked on the installer and selected Run as administrator from the context menu.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 30
                                            • 31
                                            • 21 / 31
