    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 161 Posters 668.8k Views 161 Watching
    • peterboodtsP Offline
      peterboodts
      Does clothworks is supposed to work in Sketchup 2019 ?
      I wanted to reenter my serial and got an error :
      SCFlicence not supported : missing Library file
      .../Plugins/Sketchucation/SCFlicence/Mac_25/SUEX_SCFLibrary.bundle
      Thanks !
      Peter
        The current version of Clothworks does work in SU2019. Do you have the latest one?
        Make sure you have the latest version of SCF Tools installed and you are signed in.
        • arqcovaA Offline
          arqcova
          +1, any update on new version for skp 2019?
            The current version of Clothworks works just fine in SketchUp 2019. I did this a few minutes ago with it.
              Thx Anton! 😉
                Anton_S
                Thanks !
                Peter
                Yes, ClothWorks 1.5.2 is compatible with SketchUp 2019. As Dave R pointed out, you need to install the latest version of SketchUcation Tools: https://sketchucation.com/resources/plugin-store-download
                • jo-keJ Offline
                  jo-ke
                  I have problems with su2019pro and clothworks. After every restart of su I have to reinstall clothworks. At the next start of su the plugin is disappeared.
                  What is wrong.
                  http://www.zz7.de
                    When you installed SketchUp 2019, did you right click on the installer file and choose Run as administrator? Or did you do something else?
                    • jo-keJ Offline
                      jo-ke
                      I just ran the exe file and installed it. strange thing...
                      http://www.zz7.de
                        Anton_S
                        @jo-ke Did you use the extension manager to install ClothWorks? If not, install ClothWorks RBZ via the Extension Manager (and also SketchUcationTools if desired for licensing):
                        1. Open SketchUp 2019
                        2. Select (Menu) Window -> Extension Manager
                        3. Click Install Extension button
                        4. Select the downloaded RBZ file
                        5. Restart SketchUp
                        Let me know if this works.
                        • EdsonE Offline
                          Edson
                          I wonder if you could help me with a problem I am having. Clothworks is running very slowly and I do not know what to change for it to behave as one sees in the tutorials. Both Outliner and Components dialogues are closed.
                          By the way, I am trying to create a curtain.
                          I am attaching a pair of screenshots of the UI for you to see the parameters I have set.
                          I hope you can help me. Thanks in advance.
                          http://www.mahfuz.arq.br
                            Anton_S
                            Edson,
                            Try reducing thickness, to 2 mm. This may improve performance. When simulating curtains, you need to apply an equilateral grid and have self-collision turned on.
                            Also, it looks like gravity is too high. Same could apply to viscosity.
                            I will create a tutorial for curtains with never CW upon releasing the next version.
                            Anton
                            • EdsonE Offline
                              Edson
                              Thanks, Anton. All of it helps but I still wish it would move a little faster. Which is the property that controls it?
                              Best regards.
                              Edson
                              • E Offline
                                efrey1991
                                hola amigo de ante mano agradezco por tal herramienta que pues le da a nuestros proyectos un mejora extra un realismo impresionante.
                                tengo un pequeño inconveniente cuando APPLY EQULATERAL GRID. BUENO ESTO ME PIDE QUE por favor active su licencia de clothworks para desbloquear la rejilla adaptable, apreciaría este favor
                                • EdsonE Offline
                                  Edson
                                  hola efrey,
                                  si no escribes en inglés no te van a contestar. son pocos los que hablan castellano en este forum y es cierto que los que lo dirigen no lo hacen. creo que anton tampoco lo hablará.
                                  saludos.
                                  edson
                                    Anton_S
                                    Best regards.
                                    Edson
                                    Edson, you may be experiencing a performance issue, which can't be fixed due to the limitation of the plugin itself. If you send me private message of your model, I will take a look and see if anything could be done to improve performance.
                                    • EdsonE Offline
                                      Edson
                                      Thanks. I will do that shortly.
                                        Anton_S
                                        Equilateral and quadrilateral grids work without licensing. The adjustable grid only works with licensing. If you desire to use equilateral grid, you do not need to license the plugin.
                                        • jo-keJ Offline
                                          jo-ke
                                          1. Select (Menu) Window -> Extension Manager
                                          2. Click Install Extension button
                                          3. Select the downloaded RBZ file
                                          4. Restart SketchUp
                                          Still not able to reinstall.
                                          Installing via Scetchucationtool I am getting the error: "UnZIP error: Could not unzip archive"
                                          Strange...
                                          http://www.zz7.de
                                          • jo-keJ Offline
                                            jo-ke
                                            Now I used a different library to save the extension.
                                            I relicensed the product and it worked well.
                                            After restarting SU everything disappered. 😞
                                            What did I wrong?
                                            http://www.zz7.de
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 32 / 35
