    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    715 Posts 166 Posters 871.1k Views 165 Watching
      Anton_S
      Hello swissmountain,
      Thank you for your suggestions. The rotatable gizmo is something that I already added and this is yet to be released. Stay tuned!
      Thanks,
      Anton
      • SwissmountainS Offline
        Swissmountain
        Sweet! Looking forward to it : )
        Cogito ergo dum-di-dum
          Revnika
          Hey Anton_S
          I bought this last year, and I had to reformat my computer. when obtaining my license, it says I have to buy it again. is there a way I can redownload it? Im checking everywhere for my back up, and currently looking still.
          John
            Anton_S
            Hello John,
            I sent you an email with your license attached.
            Thanks,
            Anton
            • peterboodtsP Offline
              peterboodts
              Does clothworks is supposed to work in Sketchup 2019 ?
              I wanted to reenter my serial and got an error :
              SCFlicence not supported : missing Library file
              .../Plugins/Sketchucation/SCFlicence/Mac_25/SUEX_SCFLibrary.bundle
              Thanks !
              Peter
                The current version of Clothworks does work in SU2019. Do you have the latest one?
                Make sure you have the latest version of SCF Tools installed and you are signed in.
                • arqcovaA Offline
                  arqcova
                  +1, any update on new version for skp 2019?
                    The current version of Clothworks works just fine in SketchUp 2019. I did this a few minutes ago with it.
                      Thx Anton! 😉
                        Anton_S
                        Thanks !
                        Peter
                        Yes, ClothWorks 1.5.2 is compatible with SketchUp 2019. As Dave R pointed out, you need to install the latest version of SketchUcation Tools: https://sketchucation.com/resources/plugin-store-download
                        • jo-keJ Offline
                          jo-ke
                          I have problems with su2019pro and clothworks. After every restart of su I have to reinstall clothworks. At the next start of su the plugin is disappeared.
                          What is wrong.
                          http://www.zz7.de
                            When you installed SketchUp 2019, did you right click on the installer file and choose Run as administrator? Or did you do something else?
                            • jo-keJ Offline
                              jo-ke
                              I just ran the exe file and installed it. strange thing...
                              http://www.zz7.de
                                Anton_S
                                @jo-ke Did you use the extension manager to install ClothWorks? If not, install ClothWorks RBZ via the Extension Manager (and also SketchUcationTools if desired for licensing):
                                1. Open SketchUp 2019
                                2. Select (Menu) Window -> Extension Manager
                                3. Click Install Extension button
                                4. Select the downloaded RBZ file
                                5. Restart SketchUp
                                Let me know if this works.
                                • EdsonE Offline
                                  Edson
                                  I wonder if you could help me with a problem I am having. Clothworks is running very slowly and I do not know what to change for it to behave as one sees in the tutorials. Both Outliner and Components dialogues are closed.
                                  By the way, I am trying to create a curtain.
                                  I am attaching a pair of screenshots of the UI for you to see the parameters I have set.
                                  I hope you can help me. Thanks in advance.
                                  http://www.mahfuz.arq.br
                                    Anton_S
                                    Edson,
                                    Try reducing thickness, to 2 mm. This may improve performance. When simulating curtains, you need to apply an equilateral grid and have self-collision turned on.
                                    Also, it looks like gravity is too high. Same could apply to viscosity.
                                    I will create a tutorial for curtains with never CW upon releasing the next version.
                                    Anton
                                    • EdsonE Offline
                                      Edson
                                      Thanks, Anton. All of it helps but I still wish it would move a little faster. Which is the property that controls it?
                                      Best regards.
                                      Edson
                                      • E Offline
                                        efrey1991
                                        hola amigo de ante mano agradezco por tal herramienta que pues le da a nuestros proyectos un mejora extra un realismo impresionante.
                                        tengo un pequeño inconveniente cuando APPLY EQULATERAL GRID. BUENO ESTO ME PIDE QUE por favor active su licencia de clothworks para desbloquear la rejilla adaptable, apreciaría este favor
                                        • EdsonE Offline
                                          Edson
                                          hola efrey,
                                          si no escribes en inglés no te van a contestar. son pocos los que hablan castellano en este forum y es cierto que los que lo dirigen no lo hacen. creo que anton tampoco lo hablará.
                                          saludos.
                                          edson
                                            Anton_S
                                            Best regards.
                                            Edson
                                            Edson, you may be experiencing a performance issue, which can't be fixed due to the limitation of the plugin itself. If you send me private message of your model, I will take a look and see if anything could be done to improve performance.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 35
                                            • 36
                                            • 18 / 36
