    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.6k Views 171 Watching
    • EdsonE
      Edson
      I wonder if you could help me with a problem I am having. Clothworks is running very slowly and I do not know what to change for it to behave as one sees in the tutorials. Both Outliner and Components dialogues are closed.
      By the way, I am trying to create a curtain.
      I am attaching a pair of screenshots of the UI for you to see the parameters I have set.
      I hope you can help me. Thanks in advance.
      http://www.mahfuz.arq.br
        Anton_S
        Edson,
        Try reducing thickness, to 2 mm. This may improve performance. When simulating curtains, you need to apply an equilateral grid and have self-collision turned on.
        Also, it looks like gravity is too high. Same could apply to viscosity.
        I will create a tutorial for curtains with never CW upon releasing the next version.
        Anton
        • EdsonE
          Edson
          Thanks, Anton. All of it helps but I still wish it would move a little faster. Which is the property that controls it?
          Best regards.
          Edson
          • E
            efrey1991
            hola amigo de ante mano agradezco por tal herramienta que pues le da a nuestros proyectos un mejora extra un realismo impresionante.
            tengo un pequeño inconveniente cuando APPLY EQULATERAL GRID. BUENO ESTO ME PIDE QUE por favor active su licencia de clothworks para desbloquear la rejilla adaptable, apreciaría este favor
            • EdsonE
              Edson
              hola efrey,
              si no escribes en inglés no te van a contestar. son pocos los que hablan castellano en este forum y es cierto que los que lo dirigen no lo hacen. creo que anton tampoco lo hablará.
              saludos.
              edson
                Anton_S
                Best regards.
                Edson
                Edson, you may be experiencing a performance issue, which can't be fixed due to the limitation of the plugin itself. If you send me private message of your model, I will take a look and see if anything could be done to improve performance.
                • EdsonE
                  Edson
                  Thanks. I will do that shortly.
                    Anton_S
                    Equilateral and quadrilateral grids work without licensing. The adjustable grid only works with licensing. If you desire to use equilateral grid, you do not need to license the plugin.
                    • jo-keJ
                      jo-ke
                      @anton_s said:
                      @jo-ke Did you use the extension manager to install ClothWorks? If not, install ClothWorks RBZ via the Extension Manager (and also SketchUcationTools if desired for licensing):
                      1. Open SketchUp 2019
                      1. Select (Menu) Window -> Extension Manager
                      2. Click Install Extension button
                      3. Select the downloaded RBZ file
                      4. Restart SketchUp
                      Let me know if this works.
                      Still not able to reinstall.
                      Installing via Scetchucationtool I am getting the error: "UnZIP error: Could not unzip archive"
                      Strange...
                      http://www.zz7.de
                      • jo-keJ
                        jo-ke
                        Now I used a different library to save the extension.
                        I relicensed the product and it worked well.
                        After restarting SU everything disappered. 😞
                        What did I wrong?
                        http://www.zz7.de
                          This sounds like a problem typical of incorrect installation of SketchUp. When you installed SketchUp 2018 (I assume that's the version you are using as indicated in your profile), did you right click on the downloaded installer file and select Run as administrator from the context menu?
                          • jo-keJ
                            jo-ke
                            Oh since a few months I am using SU2019.
                            I just started the exe file and installed SU and followed the instructions.
                            http://www.zz7.de
                              So does that mean that you did not install SketchUp 2019 by right clicking and selecting Run as administrator? If you didn't, close SketchUp and repair the installation. Find the downloaded installer file, right click on it. Choose Run as administrator and when presented with the options, select Repair.
                              • jo-keJ
                                jo-ke
                                OK Thank you. I will try it and report....
                                http://www.zz7.de
                                • jo-keJ
                                  jo-ke
                                  I hate it... Where can I find the current download of SU2019pro.
                                  Can't find it at the homepage of SU....
                                  http://www.zz7.de
                                  • jujuJ
                                    juju
                                    https://www.sketchup.com/download/all
                                    • jo-keJ
                                      jo-ke
                                      Thank you juju. OK, found the installation file, downloaded it, ran as admin, repaired su and restarted my pc. Started su and: clothworks dissappeared again. 😞
                                      http://www.zz7.de
                                        Anton_S
                                        Does this occur to all your plugins or just ClothWorks?
                                        • jo-keJ
                                          jo-ke
                                          It affects only clothworks
                                          http://www.zz7.de
                                          • jo-keJ
                                            jo-ke
                                            somebody any idea?
                                            http://www.zz7.de
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 36
                                            • 37
                                            • 19 / 37
