    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 911.4k Views 166 Watching
      Thx Anton! 😉
        Anton_S
        @peterboodts said:
        Does clothworks is supposed to work in Sketchup 2019 ?
        I wanted to reenter my serial and got an error :
        SCFlicence not supported : missing Library file
        .../Plugins/Sketchucation/SCFlicence/Mac_25/SUEX_SCFLibrary.bundle
        Thanks !
        Peter
        Yes, ClothWorks 1.5.2 is compatible with SketchUp 2019. As Dave R pointed out, you need to install the latest version of SketchUcation Tools: https://sketchucation.com/resources/plugin-store-download
        • jo-keJ
          jo-ke
          I have problems with su2019pro and clothworks. After every restart of su I have to reinstall clothworks. At the next start of su the plugin is disappeared.
          What is wrong.
          http://www.zz7.de
            When you installed SketchUp 2019, did you right click on the installer file and choose Run as administrator? Or did you do something else?
            • jo-keJ
              jo-ke
              I just ran the exe file and installed it. strange thing...
              http://www.zz7.de
                Anton_S
                @jo-ke Did you use the extension manager to install ClothWorks? If not, install ClothWorks RBZ via the Extension Manager (and also SketchUcationTools if desired for licensing):
                1. Open SketchUp 2019
                2. Select (Menu) Window -> Extension Manager
                3. Click Install Extension button
                4. Select the downloaded RBZ file
                5. Restart SketchUp
                Let me know if this works.
                • EdsonE
                  Edson
                  I wonder if you could help me with a problem I am having. Clothworks is running very slowly and I do not know what to change for it to behave as one sees in the tutorials. Both Outliner and Components dialogues are closed.
                  By the way, I am trying to create a curtain.
                  I am attaching a pair of screenshots of the UI for you to see the parameters I have set.
                  I hope you can help me. Thanks in advance.
                  http://www.mahfuz.arq.br
                    Anton_S
                    Edson,
                    Try reducing thickness, to 2 mm. This may improve performance. When simulating curtains, you need to apply an equilateral grid and have self-collision turned on.
                    Also, it looks like gravity is too high. Same could apply to viscosity.
                    I will create a tutorial for curtains with never CW upon releasing the next version.
                    Anton
                    • EdsonE
                      Edson
                      Thanks, Anton. All of it helps but I still wish it would move a little faster. Which is the property that controls it?
                      Best regards.
                      Edson
                      • E
                        efrey1991
                        hola amigo de ante mano agradezco por tal herramienta que pues le da a nuestros proyectos un mejora extra un realismo impresionante.
                        tengo un pequeño inconveniente cuando APPLY EQULATERAL GRID. BUENO ESTO ME PIDE QUE por favor active su licencia de clothworks para desbloquear la rejilla adaptable, apreciaría este favor
                        • EdsonE
                          Edson
                          hola efrey,
                          si no escribes en inglés no te van a contestar. son pocos los que hablan castellano en este forum y es cierto que los que lo dirigen no lo hacen. creo que anton tampoco lo hablará.
                          saludos.
                          edson
                            Anton_S
                            Best regards.
                            Edson
                            Edson, you may be experiencing a performance issue, which can't be fixed due to the limitation of the plugin itself. If you send me private message of your model, I will take a look and see if anything could be done to improve performance.
                            • EdsonE
                              Edson
                              Thanks. I will do that shortly.
                                Anton_S
                                Equilateral and quadrilateral grids work without licensing. The adjustable grid only works with licensing. If you desire to use equilateral grid, you do not need to license the plugin.
                                • jo-keJ
                                  jo-ke
                                  1. Select (Menu) Window -> Extension Manager
                                  2. Click Install Extension button
                                  3. Select the downloaded RBZ file
                                  4. Restart SketchUp
                                  Still not able to reinstall.
                                  Installing via Scetchucationtool I am getting the error: "UnZIP error: Could not unzip archive"
                                  Strange...
                                  http://www.zz7.de
                                  • jo-keJ
                                    jo-ke
                                    Now I used a different library to save the extension.
                                    I relicensed the product and it worked well.
                                    After restarting SU everything disappered. 😞
                                    What did I wrong?
                                    http://www.zz7.de
                                      This sounds like a problem typical of incorrect installation of SketchUp. When you installed SketchUp 2018 (I assume that's the version you are using as indicated in your profile), did you right click on the downloaded installer file and select Run as administrator from the context menu?
                                      • jo-keJ
                                        jo-ke
                                        Oh since a few months I am using SU2019.
                                        I just started the exe file and installed SU and followed the instructions.
                                        http://www.zz7.de
                                          So does that mean that you did not install SketchUp 2019 by right clicking and selecting Run as administrator? If you didn't, close SketchUp and repair the installation. Find the downloaded installer file, right click on it. Choose Run as administrator and when presented with the options, select Repair.
                                          • jo-keJ
                                            jo-ke
                                            OK Thank you. I will try it and report....
                                            http://www.zz7.de
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 35
                                            • 36
                                            • 19 / 36
