    [Plugin][$] S4u_Frame
    22 Posts 6 Posters 12.9k Views 6 Watching
      rv1974
      @pilou
      All options you mentioned aren't so suited for grooving.
      The main objection: grooves are supposed to appear only by selected edges- no grooves in the corners!
      And besides lattisizer and lattice maker are pretty buggy, JPP workflow demands 2D grooves to be pre-drawn manually (which is insane in the case of more or less large building).
      • hdpvH Offline
        hdpv
        Need a new plugin Groove-maker and Curtain frame πŸ˜„
        Suforyou
        http://www.sketchupforyou.com
          rv1974
          Is it kinda general observation or you indeed planning to do something in this direction? (keep my fingers crossed)
          • pbacotP Offline
            πŸ‘
            Would have many uses.
            • hdpvH Offline
              hdpv
              i'm not sure .It's difficult.
              Suforyou
                rv1974
                I'd be huge if 'frame material' section could be added AND (most inportant) if material has a texture, it'd be aligned to the longest edges of frame's elements
                  So just something like that
                  Colorize your futur no groove in Green for esay selection
                  Then just used Joint PushPull πŸ˜„
                  https://i.postimg.cc/QtBR1b8L/so_green.gif
                    For the grooves πŸ˜‰
                    Lattice-izer by TIG
                    Select Simple Face BY Selection Toys by Thomthom
                    Joint Push Pull Multiple By Fredo 6
                    Clean Up By ThomThom
                    But maybe pricipal angle edges are no that you want?
                    https://i.postimg.cc/50HmnKQ3/grooves.gif
                      So easy! πŸ˜„
                      https://i.postimg.cc/wvyyjKK2/verre.jpg
                      • hdpvH Offline
                        hdpv
                        I use s4u-Paint to rotate a texture of material.
                        https://extensions.sketchup.com/en/content/s4u-paint
                        https://sketchucation.com/pluginstore?pln=s4u_paint
                        Suforyou
                        • E Offline
                          Einstein
                          How long does the trial work?
                          • E Offline
                            Einstein
                            And one more question - when I make frames by selecting only faces, it nicely closes the angles. But if I have a more complex profile (that contains loose edges too) and select both faces and edges, then create the framing, it won't close gaps that appear where two lines meet.
                            Can it be fixed?
                            See the image:
                            • hdpvH Offline
                              hdpv
                              You need to weld selected edges before making the frame.
                              Suforyou
                              • E Offline
                                Einstein
                                Ok, I'll try this.
                                And how long does the trial period last?
