    [Plugin][$] S4u_Frame
    22 Posts 6 Posters 13.3k Views 6 Watching
    • hdpvH Offline
      hdpv
      I just outer_shell border and frames,not sure solid.
      Suforyou
      http://www.sketchupforyou.com
        cadmunkey
        I just tried the demo and it does create a solid. Going to purchase now, thanks for the great plugin.
          rv1974
          hdpv, this is very solid and useful (better then any other competitors IMO) plug-in, thank you developing!
          I wish this tool could merge the outer frames from different sides into one.
          there is also minor glitch in the corners of island-like elements.
          Thank you in advance!
          P.S. Offtopically, May I request 'Groove-maker' plugin fro you?
            rv1974
            Groove-maker,
            something like this:
              rv1974
              @pilou
              All options you mentioned aren't so suited for grooving.
              The main objection: grooves are supposed to appear only by selected edges- no grooves in the corners!
              And besides lattisizer and lattice maker are pretty buggy, JPP workflow demands 2D grooves to be pre-drawn manually (which is insane in the case of more or less large building).
              • hdpvH Offline
                hdpv
                Need a new plugin Groove-maker and Curtain frame πŸ˜„
                Suforyou
                  rv1974
                  Is it kinda general observation or you indeed planning to do something in this direction? (keep my fingers crossed)
                  • pbacotP Offline
                    πŸ‘
                    Would have many uses.
                    • hdpvH Offline
                      hdpv
                      i'm not sure .It's difficult.
                      Suforyou
                        rv1974
                        I'd be huge if 'frame material' section could be added AND (most inportant) if material has a texture, it'd be aligned to the longest edges of frame's elements
                          So just something like that
                          Colorize your futur no groove in Green for esay selection
                          Then just used Joint PushPull πŸ˜„
                          https://i.postimg.cc/QtBR1b8L/so_green.gif
                            For the grooves πŸ˜‰
                            Lattice-izer by TIG
                            Select Simple Face BY Selection Toys by Thomthom
                            Joint Push Pull Multiple By Fredo 6
                            Clean Up By ThomThom
                            But maybe pricipal angle edges are no that you want?
                            https://i.postimg.cc/50HmnKQ3/grooves.gif
                              So easy! πŸ˜„
                              https://i.postimg.cc/wvyyjKK2/verre.jpg
                              • hdpvH Offline
                                hdpv
                                I use s4u-Paint to rotate a texture of material.
                                https://extensions.sketchup.com/en/content/s4u-paint
                                https://sketchucation.com/pluginstore?pln=s4u_paint
                                Suforyou
                                • E Offline
                                  Einstein
                                  How long does the trial work?
                                  • E Offline
                                    Einstein
                                    And one more question - when I make frames by selecting only faces, it nicely closes the angles. But if I have a more complex profile (that contains loose edges too) and select both faces and edges, then create the framing, it won't close gaps that appear where two lines meet.
                                    Can it be fixed?
                                    See the image:
                                    • hdpvH Offline
                                      hdpv
                                      You need to weld selected edges before making the frame.
                                      Suforyou
                                      • E Offline
                                        Einstein
                                        Ok, I'll try this.
                                        And how long does the trial period last?
