    [Plugin][$] S4u_Frame
    22 Posts 6 Posters 13.4k Views 6 Watching
      Very funny! 😎
      • C
        cadmunkey
        Does this create solids? (i.e. give a backface to your frames?) The video doesn't show the back.
          I don't believe : when you right click on one of the Groups result : Entity infos the group is not described as a solid !
          • hdpvH
            hdpv
            I just outer_shell border and frames,not sure solid.
            Suforyou
            http://www.sketchupforyou.com
            • C
              cadmunkey
              I just tried the demo and it does create a solid. Going to purchase now, thanks for the great plugin.
                rv1974
                hdpv, this is very solid and useful (better then any other competitors IMO) plug-in, thank you developing!
                I wish this tool could merge the outer frames from different sides into one.
                there is also minor glitch in the corners of island-like elements.
                Thank you in advance!
                P.S. Offtopically, May I request 'Groove-maker' plugin fro you?
                  rv1974
                  Groove-maker,
                  something like this:
                    rv1974
                    @pilou
                    All options you mentioned aren't so suited for grooving.
                    The main objection: grooves are supposed to appear only by selected edges- no grooves in the corners!
                    And besides lattisizer and lattice maker are pretty buggy, JPP workflow demands 2D grooves to be pre-drawn manually (which is insane in the case of more or less large building).
                    • hdpvH
                      hdpv
                      Need a new plugin Groove-maker and Curtain frame πŸ˜„
                      Suforyou
                        rv1974
                        Is it kinda general observation or you indeed planning to do something in this direction? (keep my fingers crossed)
                        • pbacotP
                          πŸ‘
                          Would have many uses.
                          • hdpvH
                            hdpv
                            i'm not sure .It's difficult.
                            Suforyou
                              rv1974
                              I'd be huge if 'frame material' section could be added AND (most inportant) if material has a texture, it'd be aligned to the longest edges of frame's elements
                                So just something like that
                                Colorize your futur no groove in Green for esay selection
                                Then just used Joint PushPull πŸ˜„
                                https://i.postimg.cc/QtBR1b8L/so_green.gif
                                  For the grooves πŸ˜‰
                                  Lattice-izer by TIG
                                  Select Simple Face BY Selection Toys by Thomthom
                                  Joint Push Pull Multiple By Fredo 6
                                  Clean Up By ThomThom
                                  But maybe pricipal angle edges are no that you want?
                                  https://i.postimg.cc/50HmnKQ3/grooves.gif
                                    So easy! πŸ˜„
                                    https://i.postimg.cc/wvyyjKK2/verre.jpg
                                    • hdpvH
                                      hdpv
                                      I use s4u-Paint to rotate a texture of material.
                                      https://extensions.sketchup.com/en/content/s4u-paint
                                      https://sketchucation.com/pluginstore?pln=s4u_paint
                                      Suforyou
                                      • E
                                        Einstein
                                        How long does the trial work?
                                        • E
                                          Einstein
                                          And one more question - when I make frames by selecting only faces, it nicely closes the angles. But if I have a more complex profile (that contains loose edges too) and select both faces and edges, then create the framing, it won't close gaps that appear where two lines meet.
                                          Can it be fixed?
                                          See the image:
                                          • hdpvH
                                            hdpv
                                            You need to weld selected edges before making the frame.
                                            Suforyou
