    [Plugin][$] S4u_Frame
    22 Posts 6 Posters 12.5k Views 6 Watching
      rv1974
      Groove-maker,
      something like this:
        rv1974
        @pilou
        All options you mentioned aren't so suited for grooving.
        The main objection: grooves are supposed to appear only by selected edges- no grooves in the corners!
        And besides lattisizer and lattice maker are pretty buggy, JPP workflow demands 2D grooves to be pre-drawn manually (which is insane in the case of more or less large building).
        • hdpvH Offline
          hdpv
          Need a new plugin Groove-maker and Curtain frame πŸ˜„
          Suforyou
          http://www.sketchupforyou.com
            rv1974
            Is it kinda general observation or you indeed planning to do something in this direction? (keep my fingers crossed)
            • pbacotP Offline
              πŸ‘
              Would have many uses.
              • hdpvH Offline
                hdpv
                i'm not sure .It's difficult.
                Suforyou
                  rv1974
                  I'd be huge if 'frame material' section could be added AND (most inportant) if material has a texture, it'd be aligned to the longest edges of frame's elements
                    So just something like that
                    Colorize your futur no groove in Green for esay selection
                    Then just used Joint PushPull πŸ˜„
                    https://i.postimg.cc/QtBR1b8L/so_green.gif
                      For the grooves πŸ˜‰
                      Lattice-izer by TIG
                      Select Simple Face BY Selection Toys by Thomthom
                      Joint Push Pull Multiple By Fredo 6
                      Clean Up By ThomThom
                      But maybe pricipal angle edges are no that you want?
                      https://i.postimg.cc/50HmnKQ3/grooves.gif
                        So easy! πŸ˜„
                        https://i.postimg.cc/wvyyjKK2/verre.jpg
                        • hdpvH Offline
                          hdpv
                          I use s4u-Paint to rotate a texture of material.
                          https://extensions.sketchup.com/en/content/s4u-paint
                          https://sketchucation.com/pluginstore?pln=s4u_paint
                          Suforyou
                          • E Offline
                            Einstein
                            How long does the trial work?
                            • E Offline
                              Einstein
                              And one more question - when I make frames by selecting only faces, it nicely closes the angles. But if I have a more complex profile (that contains loose edges too) and select both faces and edges, then create the framing, it won't close gaps that appear where two lines meet.
                              Can it be fixed?
                              See the image:
                              • hdpvH Offline
                                hdpv
                                You need to weld selected edges before making the frame.
                                Suforyou
                                • E Offline
                                  Einstein
                                  Ok, I'll try this.
                                  And how long does the trial period last?
