πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin][$] S4u_Frame
22 Posts 6 Posters 11.9k Views 6 Watching
  • H Offline
    hdpv
    S4u Frame 3.0.2 (June 12, 2015)
    -Make frame by Faces (Edges,Curves)
    Trial and Purchase:
    http://extensions.sketchup.com/en/content/s4u-frame
    http://sketchucation.com/pluginstore?pln=s4u_frame
    French of Pilou: fr.zip
    Suforyou
    http://www.sketchupforyou.com
      Very funny! 😎
        cadmunkey
        Does this create solids? (i.e. give a backface to your frames?) The video doesn't show the back.
          I don't believe : when you right click on one of the Groups result : Entity infos the group is not described as a solid !
          • H Offline
            hdpv
            I just outer_shell border and frames,not sure solid.
            Suforyou
              cadmunkey
              I just tried the demo and it does create a solid. Going to purchase now, thanks for the great plugin.
              • R Do not disturb
                rv1974
                hdpv, this is very solid and useful (better then any other competitors IMO) plug-in, thank you developing!
                I wish this tool could merge the outer frames from different sides into one.
                there is also minor glitch in the corners of island-like elements.
                Thank you in advance!
                P.S. Offtopically, May I request 'Groove-maker' plugin fro you?
                • R Do not disturb
                  rv1974
                  Groove-maker,
                  something like this:
                  • R Do not disturb
                    rv1974
                    @pilou
                    All options you mentioned aren't so suited for grooving.
                    The main objection: grooves are supposed to appear only by selected edges- no grooves in the corners!
                    And besides lattisizer and lattice maker are pretty buggy, JPP workflow demands 2D grooves to be pre-drawn manually (which is insane in the case of more or less large building).
                    • H Offline
                      hdpv
                      Need a new plugin Groove-maker and Curtain frame πŸ˜„
                      Suforyou
                      • R Do not disturb
                        rv1974
                        Is it kinda general observation or you indeed planning to do something in this direction? (keep my fingers crossed)
                          πŸ‘
                          Would have many uses.
                          • H Offline
                            hdpv
                            i'm not sure .It's difficult.
                            Suforyou
                            • topic:timeago-later,4 years
                            • R Do not disturb
                              rv1974
                              I'd be huge if 'frame material' section could be added AND (most inportant) if material has a texture, it'd be aligned to the longest edges of frame's elements
                                So just something like that
                                Colorize your futur no groove in Green for esay selection
                                Then just used Joint PushPull πŸ˜„
                                https://i.postimg.cc/QtBR1b8L/so_green.gif
                                  For the grooves πŸ˜‰
                                  Lattice-izer by TIG
                                  Select Simple Face BY Selection Toys by Thomthom
                                  Joint Push Pull Multiple By Fredo 6
                                  Clean Up By ThomThom
                                  But maybe pricipal angle edges are no that you want?
                                  https://i.postimg.cc/50HmnKQ3/grooves.gif
                                    So easy! πŸ˜„
                                    https://i.postimg.cc/wvyyjKK2/verre.jpg
                                    • topic:timeago-later,8 days
                                    • H Offline
                                      hdpv
                                      I use s4u-Paint to rotate a texture of material.
                                      https://extensions.sketchup.com/en/content/s4u-paint
                                      https://sketchucation.com/pluginstore?pln=s4u_paint
                                      Suforyou
                                      • topic:timeago-later,2 years
                                      • E Offline
                                        Einstein
                                        How long does the trial work?
                                        • E Offline
                                          Einstein
                                          And one more question - when I make frames by selecting only faces, it nicely closes the angles. But if I have a more complex profile (that contains loose edges too) and select both faces and edges, then create the framing, it won't close gaps that appear where two lines meet.
                                          Can it be fixed?
                                          See the image:
                                          1 / 2
