MSPhysics 1.0.3 (16 October 2017)
Seems very low intensity of Stiffness faraway element!
In case of concave surface maybe other joints can oblige the element to rotate more...? (universal...)
(not yet tested)Here 0.1 stiffness
Hello,
I am trying to model a buoyant house simulation- However am having problems keeping the buoyancy in one plane. This is what the pontoon posts are for in real life. If anyone could please help me simulate this that would be great- thank youhttps://drive.google.com/file/d/1KIIGwubTON0ZTzp4-RmG5sE0V_yiC_-F/view?usp=sharing
Hello I am looking to model buoyancy, is there a way to stop an object falling over only buoyancy straight up and down
Hello philhumphrey ! I have uploaded your file with some modifications. You have to play with density on the house and the buoyant material. and look how joint connection tool works or better you have to play a little with MSPhysics to understand how it works.For this you can download some file on 3dwarehouse searching "MSPhysics".
A cool site for tuto about MS Physics!
It's been so long when started using Ms physics tool and I have learned so many things from developers but the thing is found on YouTube or over here , is flying an object like helicopter and air plane,
J have downloaded a model of an air plane, the plane can fly yeah, sketchyphysics is used in that model, the I want to ask is, how can do that in Ms physics? -
Hi, I installed the new SketchUp 2019 (Trial) to test it and I have obtain one error message in Ruby Console:
Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb Error; #<IOError; The required, staged c extension file, "/Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/osx64/2.5/msp_lib.bundle", is missing!> /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb;204;in `block in require_all' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb;201;in `each' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb;201;in `require_all' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb;70;in `<top (required)>' /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb;59;in `require' /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb;59;in `require' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb;15;in `<top (required)>' /Applications/SketchUp 2019/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require' /Applications/SketchUp 2019/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb;21;in `register_extension' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb;21;in `<module;MSPhysics>' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb;5;in `<top (required)>'MSPhysics v1.0.3 & AMS Library v3.6.0h
SU2019 (Trial) & macOS 10.13.6 -
Thanks for letting me know. I sort of intend to rewrite MSPhysics over simply recompiling the libraries, which should take a while.
Thanks for the info.
Hi there,
Im trying to apply breaking forces's to scaffold components to simulate when it will fail under a set load.
It looks to be possible by setting a breaking force to the fixed joint. the problem im having is the numbers are not making sense, e.g. when i rest a mass of 4kg on a joint with breaking force of 1962N (equal to 200kg of force) it breaks.
Am i messing up the settings?
Hello Ash Henderson,
You are not messing anything up. Forces from the fixed joints are indeed incorrect. This is a bug in MSPhysics and I will fix it on the next release.
Thanks,
Anton -
Thanks Anton, im looking forward to it!
MS Physics has been great in simulating the failure in overloading or over extending cantilever scaffolds.
Keep up the good work, You are doing a fantastic job!
este plugin me presenta error en skp ya cargue las librerias y todo pero no me arranca
this plugin presents me with an error in skp and I load the libraries and everything but it does not start
Please post the error messages.
Also ensure that your profile's details are up to date.Por favor, publique los mensajes de error.
También asegúrese de que los detalles de su perfil están actualizados. -
it's not working for SketchUp 2019
Error when loading file C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb Error: #<IOError: The required, staged c extension file, "C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!> C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:inblock in require_all'
C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:ineach' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:inrequire_all'
C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in<top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:inrequire'
C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:inrequire' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in<top (required)>'
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:inrequire' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:inload'
C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:inregister_extension' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:inmodule:MSPhysics'
C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in<top (required)>' -
If you look at the posts a few earlier you'll see that it's not compiled for the newer SketchUp version...
Hence the error messages ? -
Hence the error messages ?oh, i am sorry! thanks for your reply.
Dang, just paid $300 so I could use this one extension, but it doesn't work with version 2019. Does anyone have any similar suggestions, or a way to create hinge points in a drawing? Thanks
I'm sure a v2019 compatible version is under development...
In the meanwhile you could get v2017 [Make?] and try using it with that for your hinging work...
You can always use 'SaveAs' in a newer version model to get a v2017 SKP that's compatible...
https://www.sketchup.com/download/all -
i'm trying to simulate gears and linkages and all my components just fall apart. it's like the joints are weak, and things gradually just start to wobble and fall apart. anyone know if there's a way to stop this? i dont want the joints to break. cheers
