    MSPhysics 1.0.3 (16 October 2017)
    928 Posts 171 Posters 1.1m Views 172 Watching
    • OxerO Offline
      Oxer
      Thanks for the info.
        ashhenderson
        Hi there,
        Im trying to apply breaking forces's to scaffold components to simulate when it will fail under a set load.
        It looks to be possible by setting a breaking force to the fixed joint. the problem im having is the numbers are not making sense, e.g. when i rest a mass of 4kg on a joint with breaking force of 1962N (equal to 200kg of force) it breaks.
        Am i messing up the settings?
        Mass info
        Joint info
        Failed test
          Anton_S
          Hello Ash Henderson,
          You are not messing anything up. Forces from the fixed joints are indeed incorrect. This is a bug in MSPhysics and I will fix it on the next release.
          Thanks,
          Anton
            ashhenderson
            Thanks Anton, im looking forward to it!
            MS Physics has been great in simulating the failure in overloading or over extending cantilever scaffolds.
            Keep up the good work, You are doing a fantastic job!
              alvin meza
              este plugin me presenta error en skp ya cargue las librerias y todo pero no me arranca
                this plugin presents me with an error in skp and I load the libraries and everything but it does not start
                Please post the error messages.
                Also ensure that your profile's details are up to date.
                Por favor, publique los mensajes de error.
                También asegúrese de que los detalles de su perfil están actualizados.
                  RalfHannes
                  it's not working for SketchUp 2019 😕
                  Error when loading file C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb Error: #<IOError: The required, staged c extension file, "C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!> C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:inblock in require_all'
                  C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all'
                  C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
                  C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>'
                  C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
                  C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in register_extension' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in module:MSPhysics'
                  C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'
                    If you look at the posts a few earlier you'll see that it's not compiled for the newer SketchUp version...
                    Hence the error messages ?
                      RalfHannes
                      oh, i am sorry! thanks for your reply.
                        ripvansparky
                        Dang, just paid $300 so I could use this one extension, but it doesn't work with version 2019. Does anyone have any similar suggestions, or a way to create hinge points in a drawing? Thanks
                          I'm sure a v2019 compatible version is under development...
                          In the meanwhile you could get v2017 [Make?] and try using it with that for your hinging work...
                          You can always use 'SaveAs' in a newer version model to get a v2017 SKP that's compatible...
                          https://www.sketchup.com/download/all
                            thedemoriliza
                            i'm trying to simulate gears and linkages and all my components just fall apart. it's like the joints are weak, and things gradually just start to wobble and fall apart. anyone know if there's a way to stop this? i dont want the joints to break. cheers 😃
                            • ecatiE Offline
                              ecati
                              If you share the .skp file, we may have better information about the problem you are talking about and we can help you.
                              • F Offline
                                Fokys
                                Please tell me how to configure the plugin
                                How to stabilize objects moving in a closed circle ?
If there are a lot of objects (ball, cylinder, cube) on a closed line, they move not strictly along the center of the line, but slightly coming off in different directions from it
                                Sometimes objects are collected in one pile
                                Changed settings, but little helps
                                  diogobr
                                  My sketchup is hiding the objects, when I press start emulation (about 10 seconds). What is happening?
                                    Ahmed0007
                                    please update for SU2019
                                      Anton_S
                                      This happens because some objects, like hidden objects fall too far down to the point where your view is clipped. Ensure to assign an Ignore state to the that objects that should not be a part of simulation.
                                        Anton_S
                                        I will try to make the slider joint more useful by the next release. Thank you for your report!
                                          Anton_S
                                          I am on it!
                                            Ahmed0007
                                            @anton_s said:
                                            I am on it!
                                            Thank you so much
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 42 / 47
