    SketchUp 2019 release
    430 Posts 94 Posters 299.0k Views 94 Watching
    • jujuJ Offline
      juju
      @masterpaul said:
      Is there something that is essentially stopping us from developing our own opensource SketchUp "clone"? Except for time and money?
      copyrights and patent infringements
      • masterpaulM Offline
        masterpaul
        What is copyrighted? Don't software patents expire after a while? Copyright doesn't really apply as we wouldn't be calling to SketchUp! All icons would be different too. LibreOffice doesn't get sued into oblivion, gimp exists too.
        The style of SketchUp UI has been around since paint, so I think we could have a very similar UI too.
        https://patents.google.com/patent/US6628279 The only thing that is tricky is the push-pull, but I've seen other software try and attempt that and plugins on other programs (I think).
        If it's possible we could actually get a lot of things built in from the start, a built-in curviloft feature, features like fredoscale a built skatter like feature for exporting images and rendering etc. So we would have the standard toolbar which would have a very similar feature set as the large toolbar as in Sketchup and an advance toolbar with all those more "complicated" commands. Eventually, a simple to use built-in render and most important actual, support for large heavy models.
          rv1974
          It'd be more efficient to develop a-la SketchUp mesh building mode inside Blender
            masterpaul
            Edit:
            There's a destructive push pull in development:
            https://www.youtube.com/watch?v=beZau_wpR-U
            https://blenderartists.org/t/destructive-extrude-beta/678275
            It seemingly has components like in SketchUp that can be edited all at once. It's lacking the UI, and perhaps with the upcoming blender, it will be possible to clone SketchUp's UI layout to help out with people wanting to migrate. Perhaps that could be done with a separate install exe so that beginners don't have to mess around with preferences or anything. I'm not sure how much more work would be needed to get everything sorted. I never used blender before. So I don't know what else would have to be done/coded in.
            • andybotA Offline
              andybot
              I don't believe there are any tools in SU that are not available in Blender (inclusive of SU extensions.) IMO, the big difference/special sauce is the inference engine in SU. You can already push-pull with the extrude command. Manipulation inside meshes is not a whole lot different than SU, it's just a very a different workflow and shortcuts. The 2.8 UI changes make Blender miles more accessible coming from other software. Do take some time and explore Blender. πŸ˜„
              • monsterzeroM Offline
                monsterzero
                Oops. I just lost my lengthy post. So I'll keep this "version" short πŸ˜„
                Looks like I won't be using Sketchup anymore. For some time it was meditative to build in SU. But now with the SU 2019 release, the writing is on the "proverbial" wall. For the VR/AR and other art projects I am doing, I can no longer justify using SU. Nothing against SU, it isn't robust enough for me anymore.
                So Blender it is.
                I do know I'll be diving into Chipp Walter's videos like mad. I'm already digging into them and I'm fully invested and excited for 2.8.
                (I will be modifying my setup in Blender to feel as much like SU and my build style as much as possible)
                monsterzero
                I live stream my work on my graphic novel:
                https://www.youtube.com/@monsterz3r0
                http://infinitemachine.tv/
                https://www.aaatitle.xyz/
                • pbacotP Offline
                  I wonder if another difference in the interface is the ease of drawing in dimension. Haven't done much in Blender yet, but from comments I gather it is not as straightforward to draw dimension-ally as you want to do in architecture.
                    rv1974
                    My eyes are bleeding when I see Blender archviz tutorials. They use raster blueprints as reference, move mesh subobjects without exact input, just eyeballing. The lack of fast and exact input on the fly is my biggest concern.
                      I wondered about that myself but keyboard entry is do-able in blender and apparently 2.80 also has an improved tape measure.
                      I think that it is metric units only.
                      • O Offline
                        optimaforever
                        A bit late to the party but I agree with most here... SU isn't innovative anymore.
                        I fondly remember the anticipation when AtLast software brought v3 with the introduction of curves and v4 with transparent materials, and then eventually, the ruby scripting allowing the writing of plugins. Direct mesh/imagery import from Google Earth was nice plus too.
                        Nowadays I only use move, rotate, measure and pushpull (and sometimes section planes) as standard tools. All the rest is handled thanks to addon plugins.
                        So, I think all the tools I use in Sketchup date from v4 or v5. Everything that Google and Trimble brought on the table after that was not really needed. Which is a shame because I feel basically I pay every year for compatibility issues (clients keep updating and send us latest ver Skp models, or latest DWG files for instance)...
                        For several years now, SU's power is basically its plugins potential.
                        • sketch3d.deS Offline
                          sketch3d.de
                          lightyears of knowledge in highly complex development of a 3D kernel as well as an accelerated OpenGL display output, glueing a programming API and last but not least connecting/developing vector-based 2D/3D data exchange interfaces for multiple platforms... just to name the most difficult stuff.
                            masterpaul
                            I think I would rather pay developers to create an opensource alternative than to pay that yearly for pro every year that brings nothing new to the table.
                              Thing is, there are already open source alternatives. Why Trimble are behaving as they are suggests they do not care about migration. I shall leave it to others to work out why.
                                monsterzero
                                I still miss the way I can build in Sketchup and have yet to really dive into modeling in Blender. There are some Skethup-like "tools" and plugins for Blender but I've yet to really get into those. It still might be that I have to use Sketchup for modeling quickly and then importing into Blender. Not a bad trade off given Blender is free. I've realized a lot of my work is still really embedded in the "walled-garden" of Sketchup for now.
                                Nothing against Sketchup, but I need a little more power. Lighting, rendering and rigging. And now that I see Blender can really do some great edge outline looks, I can really stay in that platform for most of my work.
                                If anyone wants to tackle Blender mods for instance, push and pull, and sketch modeling for 2.8, I'd love-love to see that.
                                monsterzero
                                  sketch3d.de
                                  yawn πŸ˜›
                                  • PixeroP Offline
                                    Pixero
                                    I think that to have any success in convincing the Blender team to add SketchUp like features it needs to be done both in mass and in detail.
                                    It's easier to understand how to implement something if it is described in detail and broken down into digestable chunks.
                                    • GD3DesignG Offline
                                      GD3Design
                                      Two months in and they fixed a few bugs.... See folks, the subscription model really works for you! πŸ˜„
                                      https://help.sketchup.com/en/release-notes-0
                                      (I miss reading the daily rants on this thread...so felt I had to resurrect it) (also wanted to hear how all the new blender users were faring) πŸ˜‰ πŸ˜‰
                                      • rempageR Offline
                                        rempage
                                        Sorry if it's slightly off topic. Does anyone know who designed the SketchUp 2019 cover building?
                                        https://www.cadpoint.co.uk/wp-content/uploads/2019/02/sketchup-pro-header2.jpg
                                          sketch3d.de
                                          better ask this in the offic. forum.
                                          • PixeroP Offline
                                            Pixero
                                            I think I read it was Peter Guthrie and his company The Boundary.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 20 / 22
