    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    456 Posts 144 Posters 830.9k Views 143 Watching
    • fredo6F Offline
      I found the problem, which seems specific to SU2019.
      I will publish a fix.
      • fredo6F Offline
        NEW RELEASE: TopoShaper v2.5a - 16 Feb 19
        Requirement: LibFredo6 8.7a
        TopoShaper 2.5a includes a major fix for SU2019, preventing it to launch correctly .
        Home Page of TopoShaper for information and Download.
        Main post of this TopoShaper thread.
          MelResDes
          The update worked! Thank you so much!
          • fredo6F Offline
            Thanks for signaling the problem.
              MelResDes
              Hello Fredo,
              Is there a tool I can use to manipulate a mesh created by Toposhaper? I am looking for a way to push or pull the grade around the house model I have placed on the mesh. I tried to use the native smoove tool in Sketchup but it did not want to cooperate with the Toposhaper mesh and it locked up.
              • fredo6F Offline
                @melresdes said:
                Hello Fredo,
                You can use the native Sketchup Sandbox, or Artisanby Whaat (pay plugin).
                  MelResDes
                  Thank you. I tried to use the native sandbox tools but it locked up SketchUp. I will look into the Artisan plugin.
                  • fredo6F Offline
                    Did you build the terrain from iso-contours (so you get a quadmesh) or from a cloud of points (so you get a triangulated mesh)?
                    • pbacotP Offline
                      A problem with the native sandbox tool--don't pre-select the mesh. Vertex Tools ($) also helps for some work.
                        MelResDes
                        Thanks! That is what I was doing wrong. I appreciate the help.
                          Rom1br
                          Hi , I try to figure out how I can create a terrain from a 3D dwg file I'm given.
                          When you import this in SU and you keep the points and explode the components you see that Entity info confirms that they are Guide Points.
                          I select them all and try to use the Points cloud fonction of the plugin but it fails or crash my SU ( pro 2018 on Mac btw ).
                          I upload the dwg file if someone is kind enough to tell me what I'm doing wrong .
                          Thanks for the good job though , big fan of your work .
                          Thanks everybody
                          115145 topo CL 04 03 2019.dwg
                          • fredo6F Offline
                            Did you enclose all guide points within a group and then launch TopoShaper on this group?
                            • fredo6F Offline
                              NEW RELEASE: TopoShaper v2.5b - 11 Apr 19
                              TopoShaper 2.5b includes another major fix for SU2019, preventing it to launch correctly .
                              • pbacotP Offline
                                Working on a issue here. The main hill in my terrain is coming out deflated. In the screen shot, have selected "Show contours used by each node of the mesh". It looks like a lower contour is coming into play. (is this query relevant?) I have the hilltops set to "rounded". There is no straight line like is highlighted here connecting that contour below. No hidden lines. Maybe the contour file is too rough there are some gaps and big hole as you can see. At least I am reading the manual now.
                                I can see there is a point where I can see these erroneous closing of contours (the straight lines). At this point in cleansing I can ignore the contour or simplify it. I wonder what steps I should take a that point to correct the straight line connections.
                                • pbacotP Offline
                                  I think I am really pushing it here. Two large a sample. Everything with this file is super slow. But it appears that I can find these troublesome contours and have TopoShaper ignore them--it doesn't hurt the outcome.I just seem to have quite a few of these contours trying to close from far away.
                                  The bad contour did not show until after "Calculating Contours" I selected it and noted the elevation. Went back to "Cleansing"and right-click: exclude the contour from calculation of mesh(sorry I can't remember exactly what the contextual menu called it). I also just have to run smaller chunks of contours at a time.
                                  • fredo6F Offline
                                    @pbacot,
                                    Would you have the model so that I have a close look at the issue.
                                    • pbacotP Offline
                                      I'll pm you, Fredo. Thanks!
                                        clairem
                                        Hi everyone. I'm came to this community to use the seemingly wonderful TopoShaper but nothing happens on my end... I followed the simple instructions and i get this lines in Ruby :
                                        Error: #<Errno::ENOENT: No such file or directory @ rb_file_s_mtime - /Users/claire/Library/Application Support/.LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                                        /users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:113:in mtime' /users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:113:in need_reload?'
                                        /users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:118:in init' /users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:141:in store'
                                        /users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1281:in usage_use' /users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1269:in command_invoke'
                                        /users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1252:in block (2 levels) in build_config_commands' /users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1361:in block in add_command'
                                        I'm not code savvy and im new to Point clouds too.
                                        Can anyone offer assistance here?
                                        I'm using Sketchup Pro 2019 on a MacBook Pro...
                                        • fredo6F Offline
                                          @clairem
                                          Could you try with this version LibFredo6 8.9b.
                                          It might come from your installation, but I made theis portion of the code more resilient.
                                            clairem
                                            Thanks a lot!! Un gros merci @fredo6, ça marche 😄
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
