    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • PixeroP
      Pixero
      But Instant road isn't interactive like in the link.
        alpro
        @fredo6 said:
        In general, it is better to conceive the terrain before adding decoration, houses, fences, etc...
        But I'll think about what can be done, especially for roads.
        So what I'm doing is recreating our existing conditions surveys so that design can be brought in in 3D for some presentations and renders. When creating surfaces in Civil 3D our spot shots are used for the surface but so is our line work as breaklines for things such as roads, sidewalks, retaining walls. When I bring the contours into SU and create a surface using topo shaper sometimes the differences are pretty significant and just like KrisM I have to manually make adjustments to the surface which is tedious. Toposhaper already is a great plugin but I think having this feature will make it even better.
        • fredo6F
          NEW RELEASE: TopoShaper v2.4a - 19 Dec 18
          Requirement: LibFredo6 8.7a
          TopoShaper 2.4a is a maintenance release with small adjustments.
          Home Page of TopoShaper for information and Download.
          Main post of this TopoShaper thread.
            MelResDes
            Hello,
            I have never used Toposhaper before. I am trying to create a surface from the contour lines and I keep getting an error and the script aborts the operation. Attached is the Error:
            Date: 16-Feb-19 12:25:07
            An error occurred in CLEANSING
            The operation is fully aborted
            undefined local variable or method `colors_init' for #<F6_TopoShaper::TopoShaperCleanser:0x0000017fe1ef9f68>
            toposhapercleanser.rbe: 84 -- initialize
            toposhapertool.rbe: 541 -- new
            toposhapertool.rbe: 541 -- cleansing_processing
            toposhapertool.rbe: 523 -- after_selection
            toposhapertool.rbe: 493 -- notify_edge_picked
            body_lib6edgepicker.rbe: 445 -- call
            body_lib6edgepicker.rbe: 445 -- notify_action
            body_lib6edgepicker.rbe: 496 -- terminate_current_selection
            toposhapertool.rbe: 658 -- execute_validate
            toposhapertool.rbe: 387 -- handle_initial_selection
            toposhapertool.rbe: 319 -- activate
            toposhapertool.rbe: 133 -- select_tool
            toposhapertool.rbe: 133 -- action__mapping
            lib6plugin.rbe: 126 -- call
            lib6plugin.rbe: 126 -- launch_action
            lib6plugin.rbe: 224 -- launch_action
            bootstrap_toposhaper.rbe: 83 -- launch_action
            bootstrap_toposhaper.rbe: 136 -- block in startup
            lib6plugin.rbe: 1271 -- command_invoke
            lib6plugin.rbe: 1253 -- block (2 levels) in build_config_commands
            lib6traductor.rbe: 1361 -- block in add_command
            Please let me know if you need more info from me or if you need the file I am working on.
            • fredo6F
              Can you advise if you use Linux under the cover?
                MelResDes
                I am not really familiar with Linux other than it is an OS that I don't think I use. I'm using a standard Windows 10 OS and Sketchup Pro 2019.
                • fredo6F
                  I found the problem, which seems specific to SU2019.
                  I will publish a fix.
                  • fredo6F
                    NEW RELEASE: TopoShaper v2.5a - 16 Feb 19
                    TopoShaper 2.5a includes a major fix for SU2019, preventing it to launch correctly .
                      MelResDes
                      The update worked! Thank you so much!
                      • fredo6F
                        Thanks for signaling the problem.
                          MelResDes
                          Hello Fredo,
                          Is there a tool I can use to manipulate a mesh created by Toposhaper? I am looking for a way to push or pull the grade around the house model I have placed on the mesh. I tried to use the native smoove tool in Sketchup but it did not want to cooperate with the Toposhaper mesh and it locked up.
                          • fredo6F
                            @melresdes said:
                            Hello Fredo,
                            You can use the native Sketchup Sandbox, or Artisanby Whaat (pay plugin).
                              MelResDes
                              Thank you. I tried to use the native sandbox tools but it locked up SketchUp. I will look into the Artisan plugin.
                              • fredo6F
                                Did you build the terrain from iso-contours (so you get a quadmesh) or from a cloud of points (so you get a triangulated mesh)?
                                • pbacotP
                                  A problem with the native sandbox tool--don't pre-select the mesh. Vertex Tools ($) also helps for some work.
                                    MelResDes
                                    Thanks! That is what I was doing wrong. I appreciate the help.
                                      Rom1br
                                      Hi , I try to figure out how I can create a terrain from a 3D dwg file I'm given.
                                      When you import this in SU and you keep the points and explode the components you see that Entity info confirms that they are Guide Points.
                                      I select them all and try to use the Points cloud fonction of the plugin but it fails or crash my SU ( pro 2018 on Mac btw ).
                                      I upload the dwg file if someone is kind enough to tell me what I'm doing wrong .
                                      Thanks for the good job though , big fan of your work .
                                      Thanks everybody
                                      115145 topo CL 04 03 2019.dwg
                                      • fredo6F
                                        Did you enclose all guide points within a group and then launch TopoShaper on this group?
                                        • fredo6F
                                          NEW RELEASE: TopoShaper v2.5b - 11 Apr 19
                                          TopoShaper 2.5b includes another major fix for SU2019, preventing it to launch correctly .
                                          • pbacotP
                                            Working on a issue here. The main hill in my terrain is coming out deflated. In the screen shot, have selected "Show contours used by each node of the mesh". It looks like a lower contour is coming into play. (is this query relevant?) I have the hilltops set to "rounded". There is no straight line like is highlighted here connecting that contour below. No hidden lines. Maybe the contour file is too rough there are some gaps and big hole as you can see. At least I am reading the manual now.
                                            I can see there is a point where I can see these erroneous closing of contours (the straight lines). At this point in cleansing I can ignore the contour or simplify it. I wonder what steps I should take a that point to correct the straight line connections.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
