    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • PixeroP
      Pixero
      Something interactive like this for roads would be superb.
      https://www.youtube.com/embed/APuVx7Wdvk4?ecver=1
      And here is a open source road editor solution: https://gupea.ub.gu.se/bitstream/2077/23047/1/gupea_2077_23047_1.pdf
      • fredo6F
        I think there is already a Plugin, InstantRoad by ValiArchitect.
        Anyway, building such a plugin is independent from TopoShaper, as it should apply to any terrain, whatever method has been used to generate it.
        • PixeroP
          Pixero
          But Instant road isn't interactive like in the link.
            alpro
            @fredo6 said:
            In general, it is better to conceive the terrain before adding decoration, houses, fences, etc...
            But I'll think about what can be done, especially for roads.
            So what I'm doing is recreating our existing conditions surveys so that design can be brought in in 3D for some presentations and renders. When creating surfaces in Civil 3D our spot shots are used for the surface but so is our line work as breaklines for things such as roads, sidewalks, retaining walls. When I bring the contours into SU and create a surface using topo shaper sometimes the differences are pretty significant and just like KrisM I have to manually make adjustments to the surface which is tedious. Toposhaper already is a great plugin but I think having this feature will make it even better.
            • fredo6F
              NEW RELEASE: TopoShaper v2.4a - 19 Dec 18
              Requirement: LibFredo6 8.7a
              TopoShaper 2.4a is a maintenance release with small adjustments.
              Home Page of TopoShaper for information and Download.
              Main post of this TopoShaper thread.
                MelResDes
                Hello,
                I have never used Toposhaper before. I am trying to create a surface from the contour lines and I keep getting an error and the script aborts the operation. Attached is the Error:
                Date: 16-Feb-19 12:25:07
                An error occurred in CLEANSING
                The operation is fully aborted
                undefined local variable or method `colors_init' for #<F6_TopoShaper::TopoShaperCleanser:0x0000017fe1ef9f68>
                toposhapercleanser.rbe: 84 -- initialize
                toposhapertool.rbe: 541 -- new
                toposhapertool.rbe: 541 -- cleansing_processing
                toposhapertool.rbe: 523 -- after_selection
                toposhapertool.rbe: 493 -- notify_edge_picked
                body_lib6edgepicker.rbe: 445 -- call
                body_lib6edgepicker.rbe: 445 -- notify_action
                body_lib6edgepicker.rbe: 496 -- terminate_current_selection
                toposhapertool.rbe: 658 -- execute_validate
                toposhapertool.rbe: 387 -- handle_initial_selection
                toposhapertool.rbe: 319 -- activate
                toposhapertool.rbe: 133 -- select_tool
                toposhapertool.rbe: 133 -- action__mapping
                lib6plugin.rbe: 126 -- call
                lib6plugin.rbe: 126 -- launch_action
                lib6plugin.rbe: 224 -- launch_action
                bootstrap_toposhaper.rbe: 83 -- launch_action
                bootstrap_toposhaper.rbe: 136 -- block in startup
                lib6plugin.rbe: 1271 -- command_invoke
                lib6plugin.rbe: 1253 -- block (2 levels) in build_config_commands
                lib6traductor.rbe: 1361 -- block in add_command
                Please let me know if you need more info from me or if you need the file I am working on.
                • fredo6F
                  Can you advise if you use Linux under the cover?
                    MelResDes
                    I am not really familiar with Linux other than it is an OS that I don't think I use. I'm using a standard Windows 10 OS and Sketchup Pro 2019.
                    • fredo6F
                      I found the problem, which seems specific to SU2019.
                      I will publish a fix.
                      • fredo6F
                        NEW RELEASE: TopoShaper v2.5a - 16 Feb 19
                        TopoShaper 2.5a includes a major fix for SU2019, preventing it to launch correctly .
                          MelResDes
                          The update worked! Thank you so much!
                          • fredo6F
                            Thanks for signaling the problem.
                              MelResDes
                              Hello Fredo,
                              Is there a tool I can use to manipulate a mesh created by Toposhaper? I am looking for a way to push or pull the grade around the house model I have placed on the mesh. I tried to use the native smoove tool in Sketchup but it did not want to cooperate with the Toposhaper mesh and it locked up.
                              • fredo6F
                                @melresdes said:
                                Hello Fredo,
                                You can use the native Sketchup Sandbox, or Artisanby Whaat (pay plugin).
                                  MelResDes
                                  Thank you. I tried to use the native sandbox tools but it locked up SketchUp. I will look into the Artisan plugin.
                                  • fredo6F
                                    Did you build the terrain from iso-contours (so you get a quadmesh) or from a cloud of points (so you get a triangulated mesh)?
                                    • pbacotP
                                      A problem with the native sandbox tool--don't pre-select the mesh. Vertex Tools ($) also helps for some work.
                                        MelResDes
                                        Thanks! That is what I was doing wrong. I appreciate the help.
                                          Rom1br
                                          Hi , I try to figure out how I can create a terrain from a 3D dwg file I'm given.
                                          When you import this in SU and you keep the points and explode the components you see that Entity info confirms that they are Guide Points.
                                          I select them all and try to use the Points cloud fonction of the plugin but it fails or crash my SU ( pro 2018 on Mac btw ).
                                          I upload the dwg file if someone is kind enough to tell me what I'm doing wrong .
                                          Thanks for the good job though , big fan of your work .
                                          Thanks everybody
                                          115145 topo CL 04 03 2019.dwg
                                          • fredo6F
                                            Did you enclose all guide points within a group and then launch TopoShaper on this group?
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
