    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • pbacotP
      What I wonder how this could be input to the plugin. I'd like to see an example and how it might be implemented on UI level. I suppose edges that are horizontal can be introduced which are defined as firm intersections with the surface and not interpolated with the rest of the terrain. Working-in grades along retaining walls or building walls (rarely level) might be done be definition of point elevations.
      My approach is usually working with existing terrain so after TopoShaper I massage it to new work as needed, sometimes cutting the surface where needed, sometimes moving points of the cut portions to fit to new walls or edges of pavement (e.g.). I see that where a vertical face is actually included in the original contours, weird results happen, but I generally rebuild that part or cover it in other geometry (like a model of the retaining wall it represents).
      • fredo6F
        In general, it is better to conceive the terrain before adding decoration, houses, fences, etc...
        But I'll think about what can be done, especially for roads.
        • K
          KrisM
          This would be GREAT addition to this plugin. I do this work manually at present and it is tedious to say the least. This would be a great time saver.
          KrisM
          • PixeroP
            Pixero
            Something interactive like this for roads would be superb.
            https://www.youtube.com/embed/APuVx7Wdvk4?ecver=1
            And here is a open source road editor solution: https://gupea.ub.gu.se/bitstream/2077/23047/1/gupea_2077_23047_1.pdf
            • fredo6F
              I think there is already a Plugin, InstantRoad by ValiArchitect.
              Anyway, building such a plugin is independent from TopoShaper, as it should apply to any terrain, whatever method has been used to generate it.
              • PixeroP
                Pixero
                But Instant road isn't interactive like in the link.
                  alpro
                  So what I'm doing is recreating our existing conditions surveys so that design can be brought in in 3D for some presentations and renders. When creating surfaces in Civil 3D our spot shots are used for the surface but so is our line work as breaklines for things such as roads, sidewalks, retaining walls. When I bring the contours into SU and create a surface using topo shaper sometimes the differences are pretty significant and just like KrisM I have to manually make adjustments to the surface which is tedious. Toposhaper already is a great plugin but I think having this feature will make it even better.
                  • fredo6F
                    NEW RELEASE: TopoShaper v2.4a - 19 Dec 18
                    Requirement: LibFredo6 8.7a
                    TopoShaper 2.4a is a maintenance release with small adjustments.
                    Home Page of TopoShaper for information and Download.
                    Main post of this TopoShaper thread.
                      MelResDes
                      Hello,
                      I have never used Toposhaper before. I am trying to create a surface from the contour lines and I keep getting an error and the script aborts the operation. Attached is the Error:
                      Date: 16-Feb-19 12:25:07
                      An error occurred in CLEANSING
                      The operation is fully aborted
                      undefined local variable or method `colors_init' for #<F6_TopoShaper::TopoShaperCleanser:0x0000017fe1ef9f68>
                      toposhapercleanser.rbe: 84 -- initialize
                      toposhapertool.rbe: 541 -- new
                      toposhapertool.rbe: 541 -- cleansing_processing
                      toposhapertool.rbe: 523 -- after_selection
                      toposhapertool.rbe: 493 -- notify_edge_picked
                      body_lib6edgepicker.rbe: 445 -- call
                      body_lib6edgepicker.rbe: 445 -- notify_action
                      body_lib6edgepicker.rbe: 496 -- terminate_current_selection
                      toposhapertool.rbe: 658 -- execute_validate
                      toposhapertool.rbe: 387 -- handle_initial_selection
                      toposhapertool.rbe: 319 -- activate
                      toposhapertool.rbe: 133 -- select_tool
                      toposhapertool.rbe: 133 -- action__mapping
                      lib6plugin.rbe: 126 -- call
                      lib6plugin.rbe: 126 -- launch_action
                      lib6plugin.rbe: 224 -- launch_action
                      bootstrap_toposhaper.rbe: 83 -- launch_action
                      bootstrap_toposhaper.rbe: 136 -- block in startup
                      lib6plugin.rbe: 1271 -- command_invoke
                      lib6plugin.rbe: 1253 -- block (2 levels) in build_config_commands
                      lib6traductor.rbe: 1361 -- block in add_command
                      Please let me know if you need more info from me or if you need the file I am working on.
                      • fredo6F
                        Can you advise if you use Linux under the cover?
                          MelResDes
                          I am not really familiar with Linux other than it is an OS that I don't think I use. I'm using a standard Windows 10 OS and Sketchup Pro 2019.
                          • fredo6F
                            I found the problem, which seems specific to SU2019.
                            I will publish a fix.
                            • fredo6F
                              NEW RELEASE: TopoShaper v2.5a - 16 Feb 19
                              TopoShaper 2.5a includes a major fix for SU2019, preventing it to launch correctly .
                                MelResDes
                                The update worked! Thank you so much!
                                • fredo6F
                                  Thanks for signaling the problem.
                                    MelResDes
                                    Hello Fredo,
                                    Is there a tool I can use to manipulate a mesh created by Toposhaper? I am looking for a way to push or pull the grade around the house model I have placed on the mesh. I tried to use the native smoove tool in Sketchup but it did not want to cooperate with the Toposhaper mesh and it locked up.
                                    • fredo6F
                                      @melresdes said:
                                      Hello Fredo,
                                      You can use the native Sketchup Sandbox, or Artisanby Whaat (pay plugin).
                                        MelResDes
                                        Thank you. I tried to use the native sandbox tools but it locked up SketchUp. I will look into the Artisan plugin.
                                        • fredo6F
                                          Did you build the terrain from iso-contours (so you get a quadmesh) or from a cloud of points (so you get a triangulated mesh)?
                                          • pbacotP
                                            A problem with the native sandbox tool--don't pre-select the mesh. Vertex Tools ($) also helps for some work.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
