    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • fredo6F
      NEW RELEASE 1.9c - 31 Jul 18
      This release fixes issues related to non-ascii Windows usernames.
      More info at main post
      Download BezierSpline at Sketchucation Plugin Store
      • fredo6F
        NEW RELEASE 2.0a - 01 Aug 18
        This release fixes other issues related to non-ascii Windows usernames.
          delandc
          Just what I was looking for. I'm having some issues with a few of the tools. I'm in Sketchup Make 2017 and the polyline arc corners is acting odd. I click the first couple of points and then the whole line vanishes. Uniform b-spline... same. Thoughts?
            autumnwind
            Hi Fredo, thanks so much for your plugins, they are incredible.
            I particularly like Bezier Spline, but I have a problem: I absolutely cannot control the "control points" when I decide to move them along the axis.
            I'm working on a uniform spline, a press CTRL and then the desired arrow for the axis direction, then when I drag the point with the mouse, even a super small movement makes the point go super far. Moreover, when I move along the axis, in reality the points sticks to other points in the drawing instead of just moving along the axis. Is there any solution to this?
            I hope I was clear. Thanks in advance.
            • fredo6F
              NEW RELEASE 2.1a - 01 Nov 18
              This release fixes issues related to the size of toolbar icons for highDPI screens.
                multitabs
                Hi Fredo, thanks so much for your plugins. Without them it would be very hard.
                Was the idea to reduce the Tool Bar to save space?
                Similar to Fredo Tools.
                • G
                  gr8dane
                  I just downloaded BezierSpline_v2.1a.rbz from the Plugin Store and then installed it from SU's extension manager (I have SU Make 2017 on a PC, by the way). It seems to have installed properly, but when I click on Documentation in the menu, nothing happens. So I downloaded the Quickcard and Tutorial PDFs, as well, but I don't know how to make them available from the menu (assuming they should be, of course). Are these PDFs the only documentation available, or is something missing?
                  • fredo6F
                    This is the only doc I wrote. If you put the PDF file in the Plugins directory, then it will be available from the menu.
                    • G
                      gr8dane
                      I placed Quickcard BezierSpline - English - v1.2.pdf and Tutorial BezierSpline - English - v1.2.pdf in C:\Users<username>\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins, as you said, but still nothing happens when I click on Draw > BezierSpline curves > Documentation... .
                      BTW, your link to Scott Onstott's tutorial leads to a non-existent page.
                      • fredo6F
                        Sorry, you have to put it in the bezierspline subfolder in the Sketchup Plugin directory. I forgot that bezierSpline is not based on LibFredo6
                        Thanks for signaling. not surprising for a site which was around more than 10 years ago. I just removed the link.
                        • G
                          gr8dane
                          Thanks, that did the trick.
                            reza1813
                            Dear Fredo,
                            Hello, I kindly reach you to suggest some feature for the future update of BezierSpline.
                            1. As you know there is a feature in Rhino software which you can change the point easily in 2D and 3D and it is Gumball. BezierSpline in the current version, you can change the point in the 2D position very quickly but when I wonder to change the point in 3D axes, I have some problem(Of course when I want to do it, I definitely push up arrow on my keyboard and also be in Front view). Therefore, I really wonder to ask you, would you add Gumball feature for next Update?
                            Gumball
                             Note: This type of Gumball already exists in the Vertex Tool of @thomthom which can help properly but I thought if this feature will be developed by you in this awesome plugin then it will be more integration.
                            1. The next issue is when I draw a curve in 2D, it is so hard to close automatically the curve and I have to zoom in to close it or use the plugin options(close loop nicely or closed loop with the line) which almost is not so accurate or my desirable shape. would you solve this problem?
                              Have the best wishes to you as one of the most prominent and most successful developers.
                              close loop nicely
                            Sincerely
                            Hamidreza
                              reza1813
                              Dear Fredo,
                              Hello, I am eager to receive your feedback. Thanks in advance.
                              Hamidreza
                              • fredo6F
                                @reza1813 said:
                                Dear Fredo,
                                Hamidreza
                                Closure of Spline will come, but probably in another plugin.
                                  reza1813
                                  @fredo6 said:
                                  @reza1813 said:
                                  Dear Fredo,
                                  Hamidreza
                                  Dear Fredo,
                                  Thank you for all of your efforts. I am looking forward to the result of this plugin which seems to be very functional. Furthermore, concerning to the first request, would you add Gumball feature in order to change the point easily in 2D and 3D for next Update or another plugin. Thanks in advance.
                                  Yours Sincerely,
                                  Hamidreza
                                    RobbieDingemanse
                                    Hello Fredo6, is the bezier spline plugin not ready for SU19? Because I can install it, but when I try to use Polyline Arc corners, it doesn't show the pop-up window for the input.
                                    • fredo6F
                                      Can you open the Ruby console before you launch Polyline Arc Corner and check if there are errors.
                                      • C
                                        Cenosha
                                        Fredo,
                                        I am working together with Robbie, this is the error code we get in the Ruby Console
                                        Error: #<NameError: uninitialized constant BZ__Arc::Traductor>
                                        /Users/cgs/Library/Application Support/SketchUp 2019/SketchUp/Plugins/bezierspline/BZ__Arc.rb:67:in bz_ask_extras' /Users/cgs/Library/Application Support/SketchUp 2019/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call'
                                        /Users/cgs/Library/Application Support/SketchUp 2019/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call_ask_extras' /Users/cgs/Library/Application Support/SketchUp 2019/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2109:in conversion_curve'
                                        /Users/cgs/Library/Application Support/SketchUp 2019/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2411:in `block (2 levels) in compute_contextual_menu'
                                        Richard
                                        • C
                                          Cenosha
                                          Fredo,
                                          Richard
                                          Fredo,
                                          any idea how we can fix this ?
                                            Fredo has yet to reply, but the error message clearly points to line #67 in one of the loading files [ ../Plugins/bezierspline/BZ__Arc.rb], where it can't find the defined code for ' Traductor'.
                                            When it's trying to run:
                                            Traductor::DialogBox.new TTH_Title
                                            This is a shared 'translation' module - it is an Extension created by LibFredo - which is an Extension set up by a separate installation.
                                            So ensure that you also have its RBZ downloaded, installed and its Extension enabled in the Extensions Manager...
                                            It's available from the PluginStore...
                                            https://sketchucation.com/pluginstore?pln=LibFredo6
                                            Restart SketchUp after it is installed/enabled to ensure that everything gets properly synced...
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
