    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      raguenther56
      I did some additional experiments. Drew a simple curve with Cubic Bezier Curve that I was able to edit. From there I added control points one at a time while editing. Once I got to 24 control points (not counting the two end points), I could no longer edit the curve. A right-click gave me the standard menu selections.
      The attached file has two curves. The one on the right can be edited. The one on the left is a copy of the right curve, but one more control point has been added. It is no longer editable.
      Sample 2.skp
      • fredo6F Offline
        Thanks for signaling.
        Actually, it is not related to the number of control points but to the number of edges of the curve.
        For whatever reasons, there was a limitation to 500.
        I will republish without the limitation.
        • fredo6F Offline
          NEW RELEASE 1.9b - 25 Feb 18
          This release increases the maximum number of points in curves, even if it is not advised to have too many points in a curve.
          Download new release at main post
            raguenther56
            Thanks! The update works great. I love this tool as I would not be able to do what I want without it.
            • E Offline
              Einstein
              Please, in the next release, make "Redo last change" to quickly compare changes when editing control points.
                sashagas
                Hello!! Tell me why I can not install the plugin
                BezierSpline 1.9a. It does not appear on the toolbar, although it is installed. I can not understand what's the matter, the side plugins work.[img][img][img][img][/img][/img][/img][/img]
                • cottyC Offline
                  cotty
                  LibFredo is installed too?
                  my SketchUp gallery
                  • E Offline
                    Einstein
                    Right-click on free space in your toolbar and check if there's BezierSpline in the drop-down list. If so, check it. If not, restart SketchUp or even your computer and check again. If it still doesn't work then I don't know.
                    • fredo6F Offline
                      NEW RELEASE 1.9c - 31 Jul 18
                      This release fixes issues related to non-ascii Windows usernames.
                      More info at main post
                      Download BezierSpline at Sketchucation Plugin Store
                      • fredo6F Offline
                        NEW RELEASE 2.0a - 01 Aug 18
                        This release fixes other issues related to non-ascii Windows usernames.
                          delandc
                          Just what I was looking for. I'm having some issues with a few of the tools. I'm in Sketchup Make 2017 and the polyline arc corners is acting odd. I click the first couple of points and then the whole line vanishes. Uniform b-spline... same. Thoughts?
                            autumnwind
                            Hi Fredo, thanks so much for your plugins, they are incredible.
                            I particularly like Bezier Spline, but I have a problem: I absolutely cannot control the "control points" when I decide to move them along the axis.
                            I'm working on a uniform spline, a press CTRL and then the desired arrow for the axis direction, then when I drag the point with the mouse, even a super small movement makes the point go super far. Moreover, when I move along the axis, in reality the points sticks to other points in the drawing instead of just moving along the axis. Is there any solution to this?
                            I hope I was clear. Thanks in advance.
                            • fredo6F Offline
                              NEW RELEASE 2.1a - 01 Nov 18
                              This release fixes issues related to the size of toolbar icons for highDPI screens.
                                multitabs
                                Hi Fredo, thanks so much for your plugins. Without them it would be very hard.
                                Was the idea to reduce the Tool Bar to save space?
                                Similar to Fredo Tools.
                                  gr8dane
                                  I just downloaded BezierSpline_v2.1a.rbz from the Plugin Store and then installed it from SU's extension manager (I have SU Make 2017 on a PC, by the way). It seems to have installed properly, but when I click on Documentation in the menu, nothing happens. So I downloaded the Quickcard and Tutorial PDFs, as well, but I don't know how to make them available from the menu (assuming they should be, of course). Are these PDFs the only documentation available, or is something missing?
                                  • fredo6F Offline
                                    This is the only doc I wrote. If you put the PDF file in the Plugins directory, then it will be available from the menu.
                                      gr8dane
                                      I placed Quickcard BezierSpline - English - v1.2.pdf and Tutorial BezierSpline - English - v1.2.pdf in C:\Users<username>\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins, as you said, but still nothing happens when I click on Draw > BezierSpline curves > Documentation... .
                                      BTW, your link to Scott Onstott's tutorial leads to a non-existent page.
                                      • fredo6F Offline
                                        Sorry, you have to put it in the bezierspline subfolder in the Sketchup Plugin directory. I forgot that bezierSpline is not based on LibFredo6
                                        Thanks for signaling. not surprising for a site which was around more than 10 years ago. I just removed the link.
                                          gr8dane
                                          Thanks, that did the trick.
                                            reza1813
                                            Dear Fredo,
                                            Hello, I kindly reach you to suggest some feature for the future update of BezierSpline.
                                            1. As you know there is a feature in Rhino software which you can change the point easily in 2D and 3D and it is Gumball. BezierSpline in the current version, you can change the point in the 2D position very quickly but when I wonder to change the point in 3D axes, I have some problem(Of course when I want to do it, I definitely push up arrow on my keyboard and also be in Front view). Therefore, I really wonder to ask you, would you add Gumball feature for next Update?
                                            Gumball
                                            ď‚§ Note: This type of Gumball already exists in the Vertex Tool of @thomthom which can help properly but I thought if this feature will be developed by you in this awesome plugin then it will be more integration.
                                            1. The next issue is when I draw a curve in 2D, it is so hard to close automatically the curve and I have to zoom in to close it or use the plugin options(close loop nicely or closed loop with the line) which almost is not so accurate or my desirable shape. would you solve this problem?
                                              Have the best wishes to you as one of the most prominent and most successful developers.
                                              close loop nicely
                                            Sincerely
                                            Hamidreza
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
