    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • fredo6F
      NEW RELEASE 1.9b - 25 Feb 18
      This release increases the maximum number of points in curves, even if it is not advised to have too many points in a curve.
      Download new release at main post
        raguenther56
        Thanks! The update works great. I love this tool as I would not be able to do what I want without it.
        • E
          Einstein
          Please, in the next release, make "Redo last change" to quickly compare changes when editing control points.
            sashagas
            Hello!! Tell me why I can not install the plugin
            BezierSpline 1.9a. It does not appear on the toolbar, although it is installed. I can not understand what's the matter, the side plugins work.[img][img][img][img][/img][/img][/img][/img]
            • cottyC
              cotty
              LibFredo is installed too?
              my SketchUp gallery
              • E
                Einstein
                Right-click on free space in your toolbar and check if there's BezierSpline in the drop-down list. If so, check it. If not, restart SketchUp or even your computer and check again. If it still doesn't work then I don't know.
                • fredo6F
                  NEW RELEASE 1.9c - 31 Jul 18
                  This release fixes issues related to non-ascii Windows usernames.
                  More info at main post
                  Download BezierSpline at Sketchucation Plugin Store
                  • fredo6F
                    NEW RELEASE 2.0a - 01 Aug 18
                    This release fixes other issues related to non-ascii Windows usernames.
                      delandc
                      Just what I was looking for. I'm having some issues with a few of the tools. I'm in Sketchup Make 2017 and the polyline arc corners is acting odd. I click the first couple of points and then the whole line vanishes. Uniform b-spline... same. Thoughts?
                        autumnwind
                        Hi Fredo, thanks so much for your plugins, they are incredible.
                        I particularly like Bezier Spline, but I have a problem: I absolutely cannot control the "control points" when I decide to move them along the axis.
                        I'm working on a uniform spline, a press CTRL and then the desired arrow for the axis direction, then when I drag the point with the mouse, even a super small movement makes the point go super far. Moreover, when I move along the axis, in reality the points sticks to other points in the drawing instead of just moving along the axis. Is there any solution to this?
                        I hope I was clear. Thanks in advance.
                        • fredo6F
                          NEW RELEASE 2.1a - 01 Nov 18
                          This release fixes issues related to the size of toolbar icons for highDPI screens.
                            multitabs
                            Hi Fredo, thanks so much for your plugins. Without them it would be very hard.
                            Was the idea to reduce the Tool Bar to save space?
                            Similar to Fredo Tools.
                            • G
                              gr8dane
                              I just downloaded BezierSpline_v2.1a.rbz from the Plugin Store and then installed it from SU's extension manager (I have SU Make 2017 on a PC, by the way). It seems to have installed properly, but when I click on Documentation in the menu, nothing happens. So I downloaded the Quickcard and Tutorial PDFs, as well, but I don't know how to make them available from the menu (assuming they should be, of course). Are these PDFs the only documentation available, or is something missing?
                              • fredo6F
                                This is the only doc I wrote. If you put the PDF file in the Plugins directory, then it will be available from the menu.
                                • G
                                  gr8dane
                                  I placed Quickcard BezierSpline - English - v1.2.pdf and Tutorial BezierSpline - English - v1.2.pdf in C:\Users<username>\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins, as you said, but still nothing happens when I click on Draw > BezierSpline curves > Documentation... .
                                  BTW, your link to Scott Onstott's tutorial leads to a non-existent page.
                                  • fredo6F
                                    Sorry, you have to put it in the bezierspline subfolder in the Sketchup Plugin directory. I forgot that bezierSpline is not based on LibFredo6
                                    Thanks for signaling. not surprising for a site which was around more than 10 years ago. I just removed the link.
                                    • G
                                      gr8dane
                                      Thanks, that did the trick.
                                        reza1813
                                        Dear Fredo,
                                        Hello, I kindly reach you to suggest some feature for the future update of BezierSpline.
                                        1. As you know there is a feature in Rhino software which you can change the point easily in 2D and 3D and it is Gumball. BezierSpline in the current version, you can change the point in the 2D position very quickly but when I wonder to change the point in 3D axes, I have some problem(Of course when I want to do it, I definitely push up arrow on my keyboard and also be in Front view). Therefore, I really wonder to ask you, would you add Gumball feature for next Update?
                                        Gumball
                                        ď‚§ Note: This type of Gumball already exists in the Vertex Tool of @thomthom which can help properly but I thought if this feature will be developed by you in this awesome plugin then it will be more integration.
                                        1. The next issue is when I draw a curve in 2D, it is so hard to close automatically the curve and I have to zoom in to close it or use the plugin options(close loop nicely or closed loop with the line) which almost is not so accurate or my desirable shape. would you solve this problem?
                                          Have the best wishes to you as one of the most prominent and most successful developers.
                                          close loop nicely
                                        Sincerely
                                        Hamidreza
                                          reza1813
                                          Dear Fredo,
                                          Hello, I am eager to receive your feedback. Thanks in advance.
                                          Hamidreza
                                          • fredo6F
                                            @reza1813 said:
                                            Dear Fredo,
                                            Hamidreza
                                            Closure of Spline will come, but probably in another plugin.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
