Some tips and tricks from out of the Box
@box said:
It's not that important really, I don't think there are that many people interested in the thread.
2000+ views, but I wonder how many are following? No way to see that info from this side I presume.
I’m definitely following this thread and intend to go back and try to recreate the lessons in each gif. I didn’t find the questions and comments distracting, as some of the questions were ones I had myself!
I haven't recorded any interesting gifs lately but I did continue to doodle with Truebend.
So here's a render of a couple of crazy ceramic fruitbowls. Created using a version of the method shown above.
Magical transformations! I am fan!
Here's a simple one, just demoing the basics of building a shape as a solid. No detail in the teeth or accurate dimensions but it was done to show the process.
same here!
Sorry, not a tip or trick as such, but an experiment in mostly SUbD and Clothworks for making chain mail.
What size are they?
One of them is a shoulder. But you guys can look at things your own way.
Be buggered if I can see a shoulder...
Ok, enough renders for now.
How to make a twisted cable.
The plugin off screen is Fredo's Twisting. -
Prima again !
after you have already twisted all the cables, about in the middle of the gif you delete 5 outer cables to copy the remainig outer one again around the middle axis 5x again - what makes this new copy step necessary? -
It's not technically necessary, but the twist has made them all unique components even though they are identical. By replacing them they become instances of one component rather than 6 separate components, this saves file size and makes it easier to modify them if I need to in future.
The plugin off screen is Fredo's Twisting.Mmmmm, licorice.
Nice thinking, mate.
@utiler said:
Mmmmm, licorice
Here's a little demo of making a very smooth tapered spindle. The pitch, length and number of threads is up to you.
This is a single thread using four helices at 90deg. The method creates a large file size, so not for general work, more for 3d printing types of work where you want a very smooth surface.
There is one point where a menu item is off screen, it is just Explode, to put the helices and cylinder into the same context. -
Haven't posted anything here for quite a while, so here is my 'Ikea Chess Set' and the basic method for creating them using Thomthom's Truebend.
I like the way you think, Box.!
