    Some tips and tricks from out of the Box
    203 Posts 20 Posters 208.0k Views 20 Watching
    • bazB Offline
      baz
      @ntxdave said:
      All I can say is WOW! πŸ‘ πŸ‘
      That one will really take some studying and a WHOLE LOT of practice.
      Good. And hopefully you recognise that this thread is not meant to be a one on one tutorial.
      What I think it is, is Box putting his slightly insane sketchup imagination out there.
      And you are bogging him down.
      But. About your questions...How about a new post.EG: 'Boxions No1'?
      I"ll follow...
      not a trump fan. xx
      • ntxdaveN Offline
        ntxdave
        I"ll follow...
        not a trump fan. xx
        SORRY!
        Maybe someone can remove my posts or move them to a discussion thread.
        Perhaps we could get Box to add a tip numer or name to each and then we could have a discussion thread for exact of the tip names/numbers. If that is done, maybe a monitor can move my posts/questions to the appropriate thread.
        Press F1...thank me later
        • bazB Offline
          baz
          Just repost the gif as a post and give it a name...'How does this Box gif work' would do it...
          • ntxdaveN Offline
            ntxdave
            Good point Baz but how do we clean up the junk I created in this thread so we get it back to the way it should be?
            • BoxB Offline
              It's not that important really, I don't think there are that many people interested in the thread.
              • bazB Offline
                baz
                2000+ views, but I wonder how many are following? No way to see that info from this side I presume.
                  jljolin
                  I’m definitely following this thread and intend to go back and try to recreate the lessons in each gif. I didn’t find the questions and comments distracting, as some of the questions were ones I had myself!
                  • BoxB Offline
                    I haven't recorded any interesting gifs lately but I did continue to doodle with Truebend.
                    So here's a render of a couple of crazy ceramic fruitbowls. Created using a version of the method shown above.
                      Magical transformations! I am fan! 😎
                      • BoxB Offline
                        Here's a simple one, just demoing the basics of building a shape as a solid. No detail in the teeth or accurate dimensions but it was done to show the process.
                        https://i.imgur.com/ju4oNdi.gif
                          mrossk
                          same here!
                          https://www.mkaplanfinefurniture.com/
                          • BoxB Offline
                            Sorry, not a tip or trick as such, but an experiment in mostly SUbD and Clothworks for making chain mail.
                              rv1974
                              What size are they?
                              • bazB Offline
                                baz
                                @rv1974 said:
                                What size are they?
                                I would guess a D Cup πŸ˜„
                                • BoxB Offline
                                  One of them is a shoulder. But you guys can look at things your own way.
                                  • bazB Offline
                                    baz
                                    Be buggered if I can see a shoulder...
                                      rv1974
                                      @baz said:
                                      @rv1974 said:
                                      What size are they?
                                      Actually I asked abould mail links diameter. How could you Baz.. 😲
                                      • BoxB Offline
                                        Ok, enough renders for now.
                                        How to make a twisted cable.
                                        The plugin off screen is Fredo's Twisting.
                                        https://i.imgur.com/MkNif7t.gif
                                        • HornOxxH Offline
                                          HornOxx
                                          Prima again ! πŸ‘ πŸ˜„
                                          after you have already twisted all the cables, about in the middle of the gif you delete 5 outer cables to copy the remainig outer one again around the middle axis 5x again - what makes this new copy step necessary?
                                          never trust a skinny cook
                                          • BoxB Offline
                                            It's not technically necessary, but the twist has made them all unique components even though they are identical. By replacing them they become instances of one component rather than 6 separate components, this saves file size and makes it easier to modify them if I need to in future.
                                            • 11
                                            • 3 / 11
