    Some tips and tricks from out of the Box
    203 Posts 20 Posters 237.6k Views 20 Watching
    • bazB
      baz
      Just repost the gif as a post and give it a name...'How does this Box gif work' would do it...
      • ntxdaveN
        ntxdave
        Good point Baz but how do we clean up the junk I created in this thread so we get it back to the way it should be?
        Press F1...thank me later
        • BoxB
          It's not that important really, I don't think there are that many people interested in the thread.
          • bazB
            baz
            2000+ views, but I wonder how many are following? No way to see that info from this side I presume.
              jljolin
              I’m definitely following this thread and intend to go back and try to recreate the lessons in each gif. I didn’t find the questions and comments distracting, as some of the questions were ones I had myself!
              • BoxB
                I haven't recorded any interesting gifs lately but I did continue to doodle with Truebend.
                So here's a render of a couple of crazy ceramic fruitbowls. Created using a version of the method shown above.
                  Magical transformations! I am fan! 😎
                  • BoxB
                    Here's a simple one, just demoing the basics of building a shape as a solid. No detail in the teeth or accurate dimensions but it was done to show the process.
                    https://i.imgur.com/ju4oNdi.gif
                      mrossk
                      same here!
                      https://www.mkaplanfinefurniture.com/
                      • BoxB
                        Sorry, not a tip or trick as such, but an experiment in mostly SUbD and Clothworks for making chain mail.
                          rv1974
                          What size are they?
                          • bazB
                            baz
                            @rv1974 said:
                            What size are they?
                            I would guess a D Cup πŸ˜„
                            • BoxB
                              One of them is a shoulder. But you guys can look at things your own way.
                              • bazB
                                baz
                                Be buggered if I can see a shoulder...
                                  rv1974
                                  @baz said:
                                  @rv1974 said:
                                  What size are they?
                                  Actually I asked abould mail links diameter. How could you Baz.. 😲
                                  • BoxB
                                    Ok, enough renders for now.
                                    How to make a twisted cable.
                                    The plugin off screen is Fredo's Twisting.
                                    https://i.imgur.com/MkNif7t.gif
                                    • HornOxxH
                                      HornOxx
                                      Prima again ! πŸ‘ πŸ˜„
                                      after you have already twisted all the cables, about in the middle of the gif you delete 5 outer cables to copy the remainig outer one again around the middle axis 5x again - what makes this new copy step necessary?
                                      never trust a skinny cook
                                      • BoxB
                                        It's not technically necessary, but the twist has made them all unique components even though they are identical. By replacing them they become instances of one component rather than 6 separate components, this saves file size and makes it easier to modify them if I need to in future.
                                        • utilerU
                                          utiler
                                          Mmmmm, licorice.
                                          Nice thinking, mate. πŸ‘
                                          Just Curious...
                                          • HornOxxH
                                            HornOxx
                                            @utiler said:
                                            Mmmmm, licorice
                                            πŸ˜„ πŸ˜„ πŸ˜„ πŸ‘
                                            • 11
                                            • 3 / 11
