    Some tips and tricks from out of the Box
    203 Posts 20 Posters 242.3k Views 20 Watching
    • BoxB
      I haven't recorded any interesting gifs lately but I did continue to doodle with Truebend.
      So here's a render of a couple of crazy ceramic fruitbowls. Created using a version of the method shown above.
        Magical transformations! I am fan! 😎
        • BoxB
          Here's a simple one, just demoing the basics of building a shape as a solid. No detail in the teeth or accurate dimensions but it was done to show the process.
          https://i.imgur.com/ju4oNdi.gif
            mrossk
            @jljolin said:
            I’m definitely following this thread and intend to go back and try to recreate the lessons in each gif. I didn’t find the questions and comments distracting, as some of the questions were ones I had myself!
            same here!
            https://www.mkaplanfinefurniture.com/
            • BoxB
              Sorry, not a tip or trick as such, but an experiment in mostly SUbD and Clothworks for making chain mail.
                rv1974
                What size are they?
                • bazB
                  baz
                  @rv1974 said:
                  What size are they?
                  I would guess a D Cup πŸ˜„
                  • BoxB
                    One of them is a shoulder. But you guys can look at things your own way.
                    • bazB
                      baz
                      Be buggered if I can see a shoulder...
                        rv1974
                        @baz said:
                        @rv1974 said:
                        What size are they?
                        Actually I asked abould mail links diameter. How could you Baz.. 😲
                        • BoxB
                          Ok, enough renders for now.
                          How to make a twisted cable.
                          The plugin off screen is Fredo's Twisting.
                          https://i.imgur.com/MkNif7t.gif
                          • HornOxxH
                            HornOxx
                            Prima again ! πŸ‘ πŸ˜„
                            after you have already twisted all the cables, about in the middle of the gif you delete 5 outer cables to copy the remainig outer one again around the middle axis 5x again - what makes this new copy step necessary?
                            never trust a skinny cook
                            • BoxB
                              It's not technically necessary, but the twist has made them all unique components even though they are identical. By replacing them they become instances of one component rather than 6 separate components, this saves file size and makes it easier to modify them if I need to in future.
                              • utilerU
                                utiler
                                Mmmmm, licorice.
                                Nice thinking, mate. πŸ‘
                                Just Curious...
                                • HornOxxH
                                  HornOxx
                                  @utiler said:
                                  Mmmmm, licorice
                                  πŸ˜„ πŸ˜„ πŸ˜„ πŸ‘
                                  • BoxB
                                    Here's a little demo of making a very smooth tapered spindle. The pitch, length and number of threads is up to you.
                                    This is a single thread using four helices at 90deg. The method creates a large file size, so not for general work, more for 3d printing types of work where you want a very smooth surface.
                                    There is one point where a menu item is off screen, it is just Explode, to put the helices and cylinder into the same context.
                                    https://i.imgur.com/wMsS8L5.gif
                                    • BoxB
                                      Haven't posted anything here for quite a while, so here is my 'Ikea Chess Set' and the basic method for creating them using Thomthom's Truebend.
                                      https://i.imgur.com/AT3Zf8k.gif
                                      • utilerU
                                        utiler
                                        I like the way you think, Box.!
                                        Just Curious...
                                        • BoxB
                                          I don't think the rest of the voices would agree with you.
                                          • HornOxxH
                                            HornOxx
                                            I agree !! (sorry Box πŸ˜„ )
                                            • 11
                                            • 4 / 11
