    Some tips and tricks from out of the Box
    203 Posts 20 Posters 242.3k Views 20 Watching
    • BoxB
      It's not that important really, I don't think there are that many people interested in the thread.
      • bazB
        baz
        2000+ views, but I wonder how many are following? No way to see that info from this side I presume.
          jljolin
          I’m definitely following this thread and intend to go back and try to recreate the lessons in each gif. I didn’t find the questions and comments distracting, as some of the questions were ones I had myself!
          • BoxB
            I haven't recorded any interesting gifs lately but I did continue to doodle with Truebend.
            So here's a render of a couple of crazy ceramic fruitbowls. Created using a version of the method shown above.
              Magical transformations! I am fan! 😎
              • BoxB
                Here's a simple one, just demoing the basics of building a shape as a solid. No detail in the teeth or accurate dimensions but it was done to show the process.
                https://i.imgur.com/ju4oNdi.gif
                  mrossk
                  same here!
                  https://www.mkaplanfinefurniture.com/
                  • BoxB
                    Sorry, not a tip or trick as such, but an experiment in mostly SUbD and Clothworks for making chain mail.
                      rv1974
                      What size are they?
                      • bazB
                        baz
                        @rv1974 said:
                        What size are they?
                        I would guess a D Cup πŸ˜„
                        • BoxB
                          One of them is a shoulder. But you guys can look at things your own way.
                          • bazB
                            baz
                            Be buggered if I can see a shoulder...
                              rv1974
                              @baz said:
                              @rv1974 said:
                              What size are they?
                              Actually I asked abould mail links diameter. How could you Baz.. 😲
                              • BoxB
                                Ok, enough renders for now.
                                How to make a twisted cable.
                                The plugin off screen is Fredo's Twisting.
                                https://i.imgur.com/MkNif7t.gif
                                • HornOxxH
                                  HornOxx
                                  Prima again ! πŸ‘ πŸ˜„
                                  after you have already twisted all the cables, about in the middle of the gif you delete 5 outer cables to copy the remainig outer one again around the middle axis 5x again - what makes this new copy step necessary?
                                  never trust a skinny cook
                                  • BoxB
                                    It's not technically necessary, but the twist has made them all unique components even though they are identical. By replacing them they become instances of one component rather than 6 separate components, this saves file size and makes it easier to modify them if I need to in future.
                                    • utilerU
                                      utiler
                                      Mmmmm, licorice.
                                      Nice thinking, mate. πŸ‘
                                      Just Curious...
                                      • HornOxxH
                                        HornOxx
                                        @utiler said:
                                        Mmmmm, licorice
                                        πŸ˜„ πŸ˜„ πŸ˜„ πŸ‘
                                        • BoxB
                                          Here's a little demo of making a very smooth tapered spindle. The pitch, length and number of threads is up to you.
                                          This is a single thread using four helices at 90deg. The method creates a large file size, so not for general work, more for 3d printing types of work where you want a very smooth surface.
                                          There is one point where a menu item is off screen, it is just Explode, to put the helices and cylinder into the same context.
                                          https://i.imgur.com/wMsS8L5.gif
                                          • BoxB
                                            Haven't posted anything here for quite a while, so here is my 'Ikea Chess Set' and the basic method for creating them using Thomthom's Truebend.
                                            https://i.imgur.com/AT3Zf8k.gif
                                            • 11
                                            • 4 / 11
