    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • pbacotP Offline
      hmm... check for updates doesn't work either.
      • fredo6F Offline
        Same problem as Oxer. You are on Mac, and there seems to be a problem with Web dialog boxes.
        Since you have FredoTools installed, could you check if
        • the Quick Launcher works
        • if Solid Volume displays a dialog box
        • pbacotP Offline
          Ok updating several Fredo6 plugins allows me to open without prompts and FredoTools and Fredo Collection seem to be in place as before!
          Still when I choose "View Trace Log Files..." sometimes a window flashes on and off but nothing else happens.
          FredoTools Launcher doesn't do anything.
          Solid Volume flashes a window briefly.
          • fredo6F Offline
            @oxer, @pbacot,
            Can you tell me which version of Safari you run on your Mac.
            It seems that Safari does not like a change I made in my code related to dialog boxes.
            • OxerO Offline
              Oxer
              Yes, have you probe anther options like Defaults Options..., Translate Language.., etc?
              To me, with all these options the popup window appear and disappear immediately.
              macOS High Sierra 10.13.6 & SU2017
              • pbacotP Offline
                I have Safari 12.0.2 (13606.3.4.1.4)
                • OxerO Offline
                  Oxer
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
                    LibFredo6 8.7d fixes a major bug preventing dialog boxes to display on MAC
                    • Z Offline
                      ztoundas
                      [quote="fredo6"]NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
                      ...Just installed an on windows, the dialog box for Convexify refused to show. :[
                      • Z Offline
                        ztoundas
                        Can we have access to 8.7a again? I've searched absolutely every where I can't find it, 8.7d broke Windows dialog boxes. Thanks!
                        • pbacotP Offline
                          Thanks Fredo for the help! (I just haven't got back to checking this last one.)
                            alirezakharazmi
                            Fredo,
                            I can not install Cruviloft! This is the error:
                            Curviloft: This plugin requires LibFredo6 version greater than 68.
                            Current version is 75.
                            I couldn't find a higher version of LibFredo. What should I do?
                            Thank you so much.
                            Alireza
                            • fredo6F Offline
                              @alirezakharazmi said:
                              Fredo,
                              I think the message is that you require LibFredo6 v8.6, and you have an old version (v7.5).
                              So just upgrade LibFredo6.
                              • fredo6F Offline
                                I fixed it with LibFredo6 v8.7e.
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v8.7e - 01 Jan 19
                                  LibFredo6 8.7e fixes a major bug preventing some dialog boxes to display
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v8.7f - 10 Jan 19
                                    LibFredo6 8.7f fixes a major bug preventing Animator to generate videos with recent versions of FFmpeg
                                      tonyliu
                                      θΌ‰ε…₯ζͺ”ζ‘ˆ Fredo6_!LibFredo6.rb ζ™‚η™Όη”ŸιŒ―θͺ€
                                      Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                      c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:50:in gsub' c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:50:in get_dir_from_ENV'
                                      c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:413:in dir_appdata' c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:211:in startup'
                                      C:/Users/εŠ‰η₯ζˆ/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/εŠ‰η₯ζˆ/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                      C:/Users/εŠ‰η₯ζˆ/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                                      window10
                                        @tonyliu
                                        Your Windows user-name in Chinese [εŠ‰ η₯ 成] "LiΓΊ yΓ²u chΓ©ng" seems to be causing the issue.
                                        Ruby is having difficulty encoding it into UTF-8 format...
                                        Having non-ASCII characters in user-names used to be a recipe for an error in Ruby; however, more recent versions are much better in forcing UTF-8 from such strings.
                                        Typically using this in the Ruby Console:
                                        ENV['USERNAME'].encoding
                                        or
                                        ENV['HOME'].encoding
                                        Returns this:
                                        Windows-1252
                                        Which is then converted to the required encoding of UTF-8 in the Ruby processing.
                                        What do you get returned for those ENV tests ?
                                        Perhaps Fredo can strengthen his code to force that encoding ??
                                          modoleinad
                                          Error Loading File Fredo6_!LibFredo6.rb
                                          c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in match' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in block (2 levels) in load_from_config'
                                          c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in each' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in block in load_from_config'
                                          c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in foreach' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in load_from_config'
                                          c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in block in load_all_plugins' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in each'
                                          c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in load_all_plugins' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:252:in startup'
                                          C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                          C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_FredoScale.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                          C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                                          C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:47:in module:Fredo6'
                                          C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:26:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                          C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                                          C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Error Loading File Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                          C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in module:Fredo6'
                                          C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>'
                                          Can anyone help me understand what this error means?
                                          • fredo6F Offline
                                            @modoleinad
                                            Usually, this problem comes when you installed Sketchup without Administrator rights.
                                            So I am afraid you need to uninstall SU2018 and reinstall.
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 105 / 109
