[Plugin Library] LibFredo6 - v14.4c - 18 May 24
NEW RELEASE: LibFredo6 v8.6n - 05 Dec 18
LibFredo6 8.6n fixes occasional problems in Orbiting, in FredoTools::ThruPaint and possibly in some others of my plugins.
NEW RELEASE: LibFredo6 v8.6p - 05 Dec 18
LibFredo6 8.6p fixes a random bug in Animator when using Movement Along Path.
NEW RELEASE: LibFredo6 v8.7a - 18 Dec 18
LibFredo6 8.7a is a maintenance release providing adjustments to several of my plugins.
Hi Fredo,
I installed the last version of LibFredo v8.7a, there is an issue, I can't access to your plugins through the icons, it appears the options window and it disappears immediately. When I access through plugins Menu or Contextual Menu they work.
When the tool (ex. JointPushPull) is running and I push the Tool Settings icon it happens the same, the settings window appears and it disappears immediately.macOS 10.13.6 & SU2017
@oxer said:
Hi Fredo,
Can you open the Ruby Console.
Do you have the problem with the button palette of my plugins (like JointPushPull or FredoCorner) or is it just for the dialog boxes?
Nothing in Ruby Console.
I open for example Window Menu> LibFredo Options> Check Updates for Plugins and the window appears but it closes immediately.EDIT: After that I can use another Skechup Tools but if I press Cmd+Q (exit SU on Mac) SketchUp doesn't close, I have to force the exit.
It's with the dialogs (popup windows) only, the palletes works fine.
How I said you before to access to yours plugins I can do this through the Tool & Extensions Menu or Contextual Menu only. -
Is it for all popup dialog boxes ?
I have loaded this plugin but my Fredo tools don't work. I get several prompts on opening SketchUp. According to the Plugin Manager I have the latest plugin.
Seems to be something quite old, because there is no longer a reference to LibFredo6 6.3 in the latest version of my plugins. Can you check for TopoShaper.
Also, ff you run LibFredo6 8.7a, could you send me the trace file (Windows > Library Settings > Trace Log File...
Another user has signaled me an anomaly with popup messages.Thanks
I choose "View Trace Log Files..." and nothing happens. Let me try updating. I know most plugins are recent updates, but some like TopoShaper may not be.
hmm... check for updates doesn't work either.
Same problem as Oxer. You are on Mac, and there seems to be a problem with Web dialog boxes.
Since you have FredoTools installed, could you check if
- the Quick Launcher works
- if Solid Volume displays a dialog box
Ok updating several Fredo6 plugins allows me to open without prompts and FredoTools and Fredo Collection seem to be in place as before!
Still when I choose "View Trace Log Files..." sometimes a window flashes on and off but nothing else happens.
FredoTools Launcher doesn't do anything.
Solid Volume flashes a window briefly. -
Yes, have you probe anther options like Defaults Options..., Translate Language.., etc?
To me, with all these options the popup window appear and disappear immediately.macOS High Sierra 10.13.6 & SU2017
I have Safari 12.0.2 (13606.3.4.1.4)
NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
LibFredo6 8.7d fixes a major bug preventing dialog boxes to display on MAC
