    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • fredo6F
      NEW RELEASE: LibFredo6 v8.6k - 03 Nov 18
      LibFredo6 8.6k provides new instructions for downloading FFmeg on Mac-OS platforms.
      IMPORTANT: the previous documentations included a link that is no longer supported and, worse, may have been hacked. So if you use Animator, please use the new link,
      https://www.ffmpeg.org/download.html
      Attached are the new PDF instructions
      Instructions_ffmpeg_Mac.pdf
      • Seatales45S
        Seatales45
        How does one update LibFredo6? Do I have to delete and reinstall?
        • fredo6F
          NEW RELEASE: LibFredo6 v8.6m - 18 Nov 18
          LibFredo6 8.6m is for Animator 2.3c (transparent background) and for the size of icons on hi-res screens.
          • fredo6F
            NEW RELEASE: LibFredo6 v8.6n - 05 Dec 18
            LibFredo6 8.6n fixes occasional problems in Orbiting, in FredoTools::ThruPaint and possibly in some others of my plugins.
            • fredo6F
              NEW RELEASE: LibFredo6 v8.6p - 05 Dec 18
              LibFredo6 8.6p fixes a random bug in Animator when using Movement Along Path.
              • fredo6F
                NEW RELEASE: LibFredo6 v8.7a - 18 Dec 18
                LibFredo6 8.7a is a maintenance release providing adjustments to several of my plugins.
                • OxerO
                  Oxer
                  Hi Fredo,
                  I installed the last version of LibFredo v8.7a, there is an issue, I can't access to your plugins through the icons, it appears the options window and it disappears immediately. When I access through plugins Menu or Contextual Menu they work.
                  When the tool (ex. JointPushPull) is running and I push the Tool Settings icon it happens the same, the settings window appears and it disappears immediately.
                  macOS 10.13.6 & SU2017
                  • fredo6F
                    @oxer said:
                    Hi Fredo,
                    Can you open the Ruby Console.
                    • fredo6F
                      Do you have the problem with the button palette of my plugins (like JointPushPull or FredoCorner) or is it just for the dialog boxes?
                      • OxerO
                        Oxer
                        Nothing in Ruby Console. 😲
                        I open for example Window Menu> LibFredo Options> Check Updates for Plugins and the window appears but it closes immediately.
                        EDIT: After that I can use another Skechup Tools but if I press Cmd+Q (exit SU on Mac) SketchUp doesn't close, I have to force the exit.
                        • OxerO
                          Oxer
                          It's with the dialogs (popup windows) only, the palletes works fine.
                          How I said you before to access to yours plugins I can do this through the Tool & Extensions Menu or Contextual Menu only.
                          • fredo6F
                            Is it for all popup dialog boxes ?
                            • pbacotP
                              I have loaded this plugin but my Fredo tools don't work. I get several prompts on opening SketchUp. According to the Plugin Manager I have the latest plugin.
                              • fredo6F
                                Seems to be something quite old, because there is no longer a reference to LibFredo6 6.3 in the latest version of my plugins. Can you check for TopoShaper.
                                Also, ff you run LibFredo6 8.7a, could you send me the trace file (Windows > Library Settings > Trace Log File...
                                Another user has signaled me an anomaly with popup messages.
                                • pbacotP
                                  I choose "View Trace Log Files..." and nothing happens. Let me try updating. I know most plugins are recent updates, but some like TopoShaper may not be.
                                  • pbacotP
                                    hmm... check for updates doesn't work either.
                                    • fredo6F
                                      Same problem as Oxer. You are on Mac, and there seems to be a problem with Web dialog boxes.
                                      Since you have FredoTools installed, could you check if
                                      • the Quick Launcher works
                                      • if Solid Volume displays a dialog box
                                      • pbacotP
                                        Ok updating several Fredo6 plugins allows me to open without prompts and FredoTools and Fredo Collection seem to be in place as before!
                                        Still when I choose "View Trace Log Files..." sometimes a window flashes on and off but nothing else happens.
                                        FredoTools Launcher doesn't do anything.
                                        Solid Volume flashes a window briefly.
                                        • fredo6F
                                          @oxer, @pbacot,
                                          Can you tell me which version of Safari you run on your Mac.
                                          It seems that Safari does not like a change I made in my code related to dialog boxes.
                                          • OxerO
                                            Oxer
                                            Yes, have you probe anther options like Defaults Options..., Translate Language.., etc?
                                            To me, with all these options the popup window appear and disappear immediately.
                                            macOS High Sierra 10.13.6 & SU2017
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 115
                                            • 116
                                            • 69 / 116
