    Some tips and tricks from out of the Box
    203 Posts 20 Posters 242.3k Views 20 Watching
    • BoxB
      That makes perfect sense Cotty, what ucs is is still beyond my limited language skills.
        rv1974
        ucs=axes
        (Acad heritage)
        • BoxB
          Here's a simple one, no plugins, no fancy tricks, just vanilla follow me. This shows why it is useful that follow me on a face removes the face. If it didn't there would be an internal face after the second follow me and it wouldn't form a solid.
          https://i.imgur.com/BliF6zZ.gif
          • bazB
            baz
            Keep going Box, great stuff...
            • BoxB
              Another simple no plugin one.
              https://i.imgur.com/0kURsML.gif
                Great suspense till the end! ๐Ÿ‘
                • BoxB
                  Here's a very short one, straight to the point.
                  To create a radius corner of a specific size, start with the two point arc at any size, move along the edge till you get the magenta inference, click once, move back along that edge until you get the magenta a second time, don't click, let go of the mouse and type the radius you want and hit enter.
                  • HornOxxH
                    HornOxx
                    ๐Ÿ˜ฎ ๐Ÿ˜ฎ always I have derived the desired radius with parallel guide lines - ok, it doesn't hurt to have a certain repertoir of geometry skills ๐Ÿ˜„ but hey, what would I/you have saved on time - so thanks to show this "hidden" secret !!!!! ๐Ÿ˜„
                    never trust a skinny cook
                    • BoxB
                      I'm pretty sure Cotty taught me that one.
                      • gillesG
                        gilles
                        ...and since it's arc you can modify the radius in entity info.
                        • BoxB
                          Or modify it via the cardinal points.
                          • BoxB
                            Here's one from a while back.
                            Follow me in Groups/Components. Follow me can be used with the 'path' separated from the 'profile'. This is a great way to build a structure of separate solids. The 'path' needs to be raw geometry but the 'profile' can be a group or component. The trick to it is to select the path, then activate the Follow me tool, then right click on the 'Profile' group and choose Edit Group, then click the profile.
                            • cottyC
                              cotty
                              I've tried to teach this to my last SketchUp class, I'm sure some days after the lesson they even don't remember to have seen the "trick". ๐Ÿ˜‰
                              my SketchUp gallery
                              • ntxdaveN
                                ntxdave
                                The concept of this one is a really great learning tool. I had some problems getting the sizes of everything to work out correctly. I also had some problems getting the delete tool to work out like in your video. But again, this is a GREAT learning exercise.
                                I wish there was a way to pause a gif. I had to watch several times to make sure I was catching all of the little tricks you were using.
                                Press F1...thank me later
                                • BoxB
                                  That is just triple click, shift double click.
                                  Triple click selects all, shift double click deselects the face and it's edges leaving the faces of the holes selected.
                                  • bazB
                                    baz
                                    I am learning something from every one of these posts.
                                    SketchUp is a bit like sailing. You know that you will never know it all and that you will never stop learning.
                                    Cheers Box.
                                    Baz.
                                    • BoxB
                                      Cheers Baz, glad some people are getting something out of them.
                                      • HornOxxH
                                        HornOxx
                                        I don't get tired of repeating me - yes, every time there is something new to learn here and BAZยดs comparison with sailing is great chosen. Especially this obvious concept of putting a model "on the left" like an untidy sock (which annoys my wife so much in real life) is so good and finally has flowed into my active repertoire - I wouldn't have come up with this idea on my own anyway ๐Ÿ˜‰ ๐Ÿ˜„
                                        also Cheers Box!
                                        • ntxdaveN
                                          ntxdave
                                          Thanks a bunch @Box. It was driving me nuts trying to figure out what I was doing wrong. I deleted each of the faces of the circles independently. Is this stuff documented anywhere, especially the shift double click?
                                          I also had a problem replicating the first circle the way you did. Wound up with a problem with the orientation of it so I just drew it. A second time.
                                          I do not use Sketchup very often anymore so replicating your video is both a good learning exercise as well as a good refresher.
                                          Once again, thanks a ton for this thread. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                          • BoxB
                                            Which do you mean by the first circle, the very first is drawn on the blue axis and is orientated that way as the camera is looking more down than horizontal. The second is the beginning of the array and is drawn on the green, once again due to the camera angle.
                                            Both could be forced on axis by the arrow keys, up for blue, left for green, right for red.
                                            • 11
                                            • 2 / 11
