    Some tips and tricks from out of the Box
    203 Posts 20 Posters 242.3k Views 20 Watching
    • BoxB
      I'll throw this one in as one of the fundamentals.
      So many people have trouble rotating to a specific axis.
      Try adding a plane on the axis you want to guide your rotations.
      Done correctly 3 rotations should be the maximum needed from any position.
        rv1974
        you are the hero of rotating!
        Always nice to see alternative ways of doing things
        What I'd instead:
        1. align UCS to face
        2. copy face
        3. align UCS to world
        4. paste
        • BoxB
          You lost me just before 1.
          but I caught up at 4.
          In other words, what on earth are you talking about.
          • cottyC
            cotty
            The mentioned 4 steps in moving pictures...
            ("Copy" and "Paste" with shortcuts...)
            klick to view
            my SketchUp gallery
            • BoxB
              That makes perfect sense Cotty, what ucs is is still beyond my limited language skills.
                rv1974
                ucs=axes
                (Acad heritage)
                • BoxB
                  Here's a simple one, no plugins, no fancy tricks, just vanilla follow me. This shows why it is useful that follow me on a face removes the face. If it didn't there would be an internal face after the second follow me and it wouldn't form a solid.
                  https://i.imgur.com/BliF6zZ.gif
                  • bazB
                    baz
                    Keep going Box, great stuff...
                    • BoxB
                      Another simple no plugin one.
                      https://i.imgur.com/0kURsML.gif
                        Great suspense till the end! ๐Ÿ‘
                        • BoxB
                          Here's a very short one, straight to the point.
                          To create a radius corner of a specific size, start with the two point arc at any size, move along the edge till you get the magenta inference, click once, move back along that edge until you get the magenta a second time, don't click, let go of the mouse and type the radius you want and hit enter.
                          • HornOxxH
                            HornOxx
                            ๐Ÿ˜ฎ ๐Ÿ˜ฎ always I have derived the desired radius with parallel guide lines - ok, it doesn't hurt to have a certain repertoir of geometry skills ๐Ÿ˜„ but hey, what would I/you have saved on time - so thanks to show this "hidden" secret !!!!! ๐Ÿ˜„
                            never trust a skinny cook
                            • BoxB
                              I'm pretty sure Cotty taught me that one.
                              • gillesG
                                gilles
                                ...and since it's arc you can modify the radius in entity info.
                                • BoxB
                                  Or modify it via the cardinal points.
                                  • BoxB
                                    Here's one from a while back.
                                    Follow me in Groups/Components. Follow me can be used with the 'path' separated from the 'profile'. This is a great way to build a structure of separate solids. The 'path' needs to be raw geometry but the 'profile' can be a group or component. The trick to it is to select the path, then activate the Follow me tool, then right click on the 'Profile' group and choose Edit Group, then click the profile.
                                    • cottyC
                                      cotty
                                      I've tried to teach this to my last SketchUp class, I'm sure some days after the lesson they even don't remember to have seen the "trick". ๐Ÿ˜‰
                                      my SketchUp gallery
                                      • ntxdaveN
                                        ntxdave
                                        The concept of this one is a really great learning tool. I had some problems getting the sizes of everything to work out correctly. I also had some problems getting the delete tool to work out like in your video. But again, this is a GREAT learning exercise.
                                        I wish there was a way to pause a gif. I had to watch several times to make sure I was catching all of the little tricks you were using.
                                        Press F1...thank me later
                                        • BoxB
                                          That is just triple click, shift double click.
                                          Triple click selects all, shift double click deselects the face and it's edges leaving the faces of the holes selected.
                                          • bazB
                                            baz
                                            I am learning something from every one of these posts.
                                            SketchUp is a bit like sailing. You know that you will never know it all and that you will never stop learning.
                                            Cheers Box.
                                            Baz.
                                            • 11
                                            • 1 / 11
