    [Plugin] QuadFaceTools
    680 Posts 116 Posters 713.8k Views 116 Watching
      kaas
      Have you tried mapping the uvs using Wrapr? Exporting Wrapr-mapped objects from SU (as fbx) works as intended for me.
      • O Offline
        optimaforever
        Well... I'm trying RizomUV because WrapR has too many limitations because of the SU 's own limitations. 😉
        Did you check the RizomUV's presentation? you'll understand what I mean.
          So, is it the UVs that are the issue? I can understand if that might be the issue here - as SU doesn't try to make the UV-coordinates between vertices shared. (SU saves texture position per face instead of per vertex)
          • O Offline
            optimaforever
            Indeed, this could be the issue... But I'm not techy enough to be able to confirm this unfortunately.
            I should try forcing a UVmap in max on the qft mesh before importing in rizomUV.
            Unfortunately my evaluation period expired 😞
              GoodWin_2203
              Good day! I have a problem with the make planar tool. when I select it, an unknown error is displayed. what could be the cause of this problem? SketchUp 2018
              • jujuJ Offline
                juju
                @goodwin_2203 said:
                SketchUp 2018
                kindly consider updating your profile (refer to version 2016 there) whenever changing SketchUp version
                • zooenZ Offline
                  zooen
                  Could we hope for a French version of QuadFaceTools?
                  There is one person who knows how to do that!
                  I thank her in advance if she does it.
                  Pourrait-on espérer une version française de QuadFaceTools?
                  Il y a bien une personne qui sait faire cela !
                  Je la remercie par avance si elle s'y adonne.
                    Je ne crois pas que cela soit prévu pour recevoir l'intégration de langages mais...
                    Il y a dĂ©jĂ  la version en français du mode d'emploi! 😉
                    • OxerO Offline
                      Oxer
                      @zooen said:
                      I translated the plugin to Spanish language manually, you have to edit some strings in the files with a text editor ( I use BBEdit on Mac), I don't know if Thomas will give support to translations in near future.
                      • zooenZ Offline
                        zooen
                        Thank you Oxer for your answer. I edited the file "core.rb" and translated with Notepade ++ for windows. I used google translation to translate so I will have to rework the texts in French.
                          AlegoZ
                          Hey there genious, im just wondering if u know why i cant get a "floating" menu i tried all i know and i can only use quad Tools from the main menu "Tools"
                          • E Offline
                            Einstein
                            Hi!
                            Recently I discovered Connect tool to be very useful. However, if I set number of Segments to 1 and "Pinch" to any value, position of connecting segment doesn't change - it sticks to the middle, regardless. I thought about a little improvement for this plugin so that Pinch would also apply to single connecting segment, altering its position along edges. This would help a looot! And push SketchUp more towards poly-modelling which I personally miss soo much.
                            An illustration of the case:
                            • E Offline
                              Einstein
                              What about kind of "collapse edge" feature? There's a nice sub-tool "remove loops" but as stated, is removes entire loop (screenshot on the left, original quad-mesh on the right). The mesh in the middle shows how I imagine "collapse edge" would work. Only the selected edges are removed and ends are connected to surrouding quad corners.
                              • uwesketchU Offline
                                uwesketch
                                When using "Remove Triangulation" on the below selected quads, then the triangulating edges are removed not only from planar quads, but also from non-planar quads.
                                Selected Quads:
                                QuadFaceTool Before RemoveTriangulation
                                After executing the "Remove Triangulation" command - it looks like a Swiss cheese 😉
                                QuadFaceTool After RemoveTriangulation has been executed
                                Is there are way to avoid this?
                                • O Offline
                                  optimaforever
                                  Selected Quads:
                                  [attachment=1:ylc5a5am]<!-- ia1 -->QudFaceTool_RemoveTriangulation_Before.png<!-- ia1 -->[/attachment:ylc5a5am]
                                  [attachment=0:ylc5a5am]<!-- ia0 -->QudFaceTool_RemoveTriangulation_After.png<!-- ia0 -->[/attachment:ylc5a5am]
                                  You just want to remove triangulations on planar quads? use Fixit101 script.
                                  • O Offline
                                    optimaforever
                                    Hello Thomthom!
                                    Perhaps has it already been discussed, but I often misclick on the Live mesh analysis button instead of connect edges tool button. Not a big deal, you'll say, but as Livemesh doesn't work with Undo, I usually need several clicks to undo it manually.
                                    I quasi never use Live mesh analysis because I model cleanly most of the time. But I guess some people use it.
                                    Now my question is; is it possible to remove it from the toolbar? or make it unclickable or invisible? Alla Fredo6, make a customizable QFT toolbar? Some functions would still be accessible from the menus... I realize I never use the UV mapping tools, nor build corners/ends. and they eat some real estate on my screen.
                                      uwesketch
                                      Also the "Merge Faces" from "TT cleanup3" does the trick. - which seems the same in FixIt101.
                                      But it would be nice if the function in QFT would work as well.
                                      • O Offline
                                        optimaforever
                                        I guess QFT remove triangulation’s use is different... If you want to regenerate the missing planes, you could use « make surfaces » script.
                                          uwesketch
                                          I am not looking for a work around. The intent of the post is to report a misbehaviour of the QFT function "Remove Triangulation".
                                          To reproduce the issue I have attached a sketchup file.
                                          The below animated gif shows how to reproduce it.
                                          ![How to reproduce holes created by the QFT function "Remove Triangualtion"](/uploads/imported_attachments/a7Pe_QFT_Remove_Triangulation_Issue.gif "How to reproduce holes created by the QFT function "Remove Triangualtion"")
                                          Example sketchup model to reproduce QFT "Remove Triangulation" issue
                                            tecnomijas
                                            Aprende a pronunciar
                                            I would appreciate your help since when I install the quadface tools plugin the plugin toolbar does not appear. I have installed it in sketchup 2018 and 2019
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 31 / 34
