    [Plugin] QuadFaceTools
    680 Posts 116 Posters 771.9k Views 116 Watching
    • jujuJ
      juju
      @goodwin_2203 said:
      SketchUp 2018
      kindly consider updating your profile (refer to version 2016 there) whenever changing SketchUp version
      • zooenZ
        zooen
        Could we hope for a French version of QuadFaceTools?
        There is one person who knows how to do that!
        I thank her in advance if she does it.
        Pourrait-on espérer une version française de QuadFaceTools?
        Il y a bien une personne qui sait faire cela !
        Je la remercie par avance si elle s'y adonne.
          Je ne crois pas que cela soit prévu pour recevoir l'intégration de langages mais...
          Il y a déjà la version en français du mode d'emploi! 😉
          • OxerO
            Oxer
            @zooen said:
            I translated the plugin to Spanish language manually, you have to edit some strings in the files with a text editor ( I use BBEdit on Mac), I don't know if Thomas will give support to translations in near future.
            • zooenZ
              zooen
              Thank you Oxer for your answer. I edited the file "core.rb" and translated with Notepade ++ for windows. I used google translation to translate so I will have to rework the texts in French.
                AlegoZ
                Hey there genious, im just wondering if u know why i cant get a "floating" menu i tried all i know and i can only use quad Tools from the main menu "Tools"
                • E
                  Einstein
                  Hi!
                  Recently I discovered Connect tool to be very useful. However, if I set number of Segments to 1 and "Pinch" to any value, position of connecting segment doesn't change - it sticks to the middle, regardless. I thought about a little improvement for this plugin so that Pinch would also apply to single connecting segment, altering its position along edges. This would help a looot! And push SketchUp more towards poly-modelling which I personally miss soo much.
                  An illustration of the case:
                  • E
                    Einstein
                    What about kind of "collapse edge" feature? There's a nice sub-tool "remove loops" but as stated, is removes entire loop (screenshot on the left, original quad-mesh on the right). The mesh in the middle shows how I imagine "collapse edge" would work. Only the selected edges are removed and ends are connected to surrouding quad corners.
                    • uwesketchU
                      uwesketch
                      When using "Remove Triangulation" on the below selected quads, then the triangulating edges are removed not only from planar quads, but also from non-planar quads.
                      Selected Quads:
                      QuadFaceTool Before RemoveTriangulation
                      After executing the "Remove Triangulation" command - it looks like a Swiss cheese 😉
                      QuadFaceTool After RemoveTriangulation has been executed
                      Is there are way to avoid this?
                      • O
                        optimaforever
                        Selected Quads:
                        [attachment=1:ylc5a5am]<!-- ia1 -->QudFaceTool_RemoveTriangulation_Before.png<!-- ia1 -->[/attachment:ylc5a5am]
                        [attachment=0:ylc5a5am]<!-- ia0 -->QudFaceTool_RemoveTriangulation_After.png<!-- ia0 -->[/attachment:ylc5a5am]
                        You just want to remove triangulations on planar quads? use Fixit101 script.
                        • O
                          optimaforever
                          Hello Thomthom!
                          Perhaps has it already been discussed, but I often misclick on the Live mesh analysis button instead of connect edges tool button. Not a big deal, you'll say, but as Livemesh doesn't work with Undo, I usually need several clicks to undo it manually.
                          I quasi never use Live mesh analysis because I model cleanly most of the time. But I guess some people use it.
                          Now my question is; is it possible to remove it from the toolbar? or make it unclickable or invisible? Alla Fredo6, make a customizable QFT toolbar? Some functions would still be accessible from the menus... I realize I never use the UV mapping tools, nor build corners/ends. and they eat some real estate on my screen.
                          • uwesketchU
                            uwesketch
                            Also the "Merge Faces" from "TT cleanup3" does the trick. - which seems the same in FixIt101.
                            But it would be nice if the function in QFT would work as well.
                            • O
                              optimaforever
                              I guess QFT remove triangulation’s use is different... If you want to regenerate the missing planes, you could use « make surfaces » script.
                              • uwesketchU
                                uwesketch
                                I am not looking for a work around. The intent of the post is to report a misbehaviour of the QFT function "Remove Triangulation".
                                To reproduce the issue I have attached a sketchup file.
                                The below animated gif shows how to reproduce it.
                                ![How to reproduce holes created by the QFT function "Remove Triangualtion"](/uploads/imported_attachments/a7Pe_QFT_Remove_Triangulation_Issue.gif "How to reproduce holes created by the QFT function "Remove Triangualtion"")
                                Example sketchup model to reproduce QFT "Remove Triangulation" issue
                                • T
                                  tecnomijas
                                  Aprende a pronunciar
                                  I would appreciate your help since when I install the quadface tools plugin the plugin toolbar does not appear. I have installed it in sketchup 2018 and 2019
                                  • O
                                    optimaforever
                                    Right-click an icon on the toolbar zone and check if the QuadFace Tools is checked on.
                                    • O
                                      optimaforever
                                      Thomas, is there a "drape" a quad mesh on a "target" triangulated mesh (in another group, serving as a reference) along Z axis?
                                      I'm fond of your "Flatten selection" command in Architect Tools, but I'm looking for a tool that basically "drops" all the vertices of a quad group on a target triangulated mesh group, while keeping the first group as quads.
                                      • panixiaP
                                        panixia
                                        Is something like this what you are after?
                                        • O
                                          optimaforever
                                          Impressive modeling video! 😄
                                          Not exactly what I'm looking for but impressive nonetheless!
                                          Let's say I have a simplified 3d mesh from a topographic survey (drawn from isohypse lines and meshed with toposhaper for instance). Very complex and heavy, and full tris so impossible to edit quickly.
                                          Then I have a site in quad topology modeled in 2D from CAD plans with correct projections of roads, buildings rivers, and so on.
                                          Right now, I move manually each vertice of my quad site to fit the correct height of the topographic mesh, beginning by the roads, then outlines of buildings, etc.
                                          Of course, I use separated groups to keep the quads from merging with the tris, and I regularly test if SubD works without generating errors) and save a lot.
                                          For complex sites, it takes hours. I enjoy the zen attitude when modeling sites but sometimes I realize that it's very repetitive and boring.
                                          So, what I'd like is a script that 'drapes' the vertices of my quad mesh on the topographic mesh with one click, just like the sandbox's drape tool but that keeps the quads, so I can keep subDing afterwards, and of course further editing because the project always evolves...
                                          • panixiaP
                                            panixia
                                            Oh I see. +1 one for this tool request! Sort of "conform quad mesh to target mesh" that would be really useful.
                                            maybe there is some workaround using tons of plugins..
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 31 / 34
