    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 257.9k Views 54 Watching
      You have Guide Points inside very practical Projection by Didier Bur
      • L
        Lorand
        Hello all:
        The results look terrific but unfortunately it doesnt work for me neither in SU2017 nor in SU2016: both triangulation and conic curves work just fine but not the Voronoi XY. In 2017 it reports "Triangulation completed: xxx triangles created" without any other effect. In 2016 it does / reports nothing, just goes back to the SU selection tool.
        All help would be highly appreciated, thank you,
        Lorand
        Edited:
        Re-Hello:
        All 3 component plugins work in both SU2016 and SU2017. I was trying to get Voronoi patterns inside a pre-established shape and I put constr. points on the edges of the shape and that kills Voronoi XY. Define your target shape (wasnt able to make triangles yet) by putting cps in the corners of it, BUT NOT ON THE EDGES, and it works nicely.
        Hope this may help someone,
        Lorand
        .png much smaller than .skp
        • E
          Einstein
          Error loading file. The same issue in SU 2017, SU 8. The same with the version developed by the.pjt.
            Did you download the latest version's RBZ from the PluginStore ?
            https://sketchucation.com/pluginstore?pln=VoronoiXY
            That RBZ contains the required file ' delauney3.rb'
            You error message is telling us it can't be found.
            If you install it from the RBZ the additional delauney3 RB should also be installed.
            If you have disabled it using the SCF PluginsManager tool, or the native Extension Manage tool in newer SketchUp versions you'll get that kind of error error...
            If you made the RBZ back into a .ZIP and took out only some files, then you haven't installed the required set of files !
            • E
              Einstein
              I was trying to install manually. Now, with PluginStore package it works. Thank you again 😄
                These days, you hardly ever need to do a manual installation - the RBZ installation does it for you automatically, and getting the latest version from our PluginStore [or the EWH when we don't host it], is always recommended...
                New versions throw up issues and the newest RBZ file are [re]written to get around these, and ensure continuing compatibility...
                • W
                  wrensong
                  This plugin link does not work. The extension is a .rb not a .rbz
                    Zip the .rb file
                    Rename .zip in .rbz
                    and you can use it like any other file rbz! 😉
                      Just download the later RBZ version from the PluginStore.
                      Then install it.
                      It includes the helper files needed too...
                      Trying to load out-of-date RB files is a recipe for frustration...
                        maoxx
                        nice
                        • P
                          Pawatamit1994
                          not getting the download link plss help
                          • G
                            Gábor
                            Click the "Download" button at the first post of this topic. On the next page click "Download" near the description of the plugin.
                              Or find in by searching the PluginStore...
                              The first-post's 'Download' button is a direct link to that entry !
                              • HornOxxH
                                HornOxx
                                Hi All, I am also so dull and can't find your working download (I would like to use this tool on my private Make 2017 and, if possible, on Pro2019). So I´m looking forward to any patient help 😄
                                never trust a skinny cook
                                  Try the Download button in this post:
                                  https://sketchucation.com/forums/viewtopic.php?p=538039#p538039
                                  • HornOxxH
                                    HornOxx
                                    ... thanks again TIG 👍 your Link worked fine 😄
                                      mackbrae
                                      no puedo intalarlo..me pide el formato *.rbz ...!! ayudaa
                                        It says in the earlier post - PLEASE GET/USE THE LATEST VERSION...
                                        FROM THE PluginStore...
                                        When it is downloaded, then that is in RBZ format.
                                        Dice en la página anterior - POR FAVOR, OBTENGA / UTILICE LA VERSIÓN MÁS RECIENTE...
                                        DESDE EL PluginStore...
                                        Cuando se descarga, entonces está en formato RBZ.
                                        • Y
                                          yashmishra
                                          using voronoi is giving me error 'no guide points in selection; although i have guide point in selection
                                            Post your SKP (save as V6 for a more large audiance)
                                            and look all my videos or images "page 4"
                                            • 6 / 7
