    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 256.2k Views 54 Watching
      You have Raytracer by Thomthom who dropts Cpoints on Surfaces! 😉
      http://sketchucation.com/forums/download/file.php?id=53901&t=1
        darkshadow47
        OK, I feel like a complete idiot for not being able to make this work. I have the current plugin from MattC and TIGs separate triangulation plugin. After creating a polygon and selecting it, if I select Triangulate Points it will ask for a layer name, and then fail with the "No Guide Points in selection". How do I generate guide points?
        The Conic curve in a face works fine...
          ronel_12
          No Existe para Pc ? saludos y bendiciones
            No entiendo lo que quieres decir.
            Esto funciona en la PC.
            ¿Por qué crees que no lo hace?
            I don't understand what you mean.
            This works on PC.
            Why do you think it does not?
              AUTER
              i tried to install in my SketchUp but didnt work... anyone could help me with this?
              • sdmitchS Offline
                sdmitch
                What didn't work? Did not install? Installed but will not run? Runs but no results?
                Post the model or a screenshot. Open the Ruby Console and execute the plugin. Post any errors that are shown.
                http://sdmitch.blogspot.com/
                  sarkarshomit
                  Please can someone confirm that this works on Skup2016, as i cant seem to find the plugin after install.I have the conic curve in face working, but not the voronoi part...
                    Seems that works like a charm inside 2016 Make as shown on my previous post! 😄
                    Quasi all is by hand "manual" ! 🤓
                    Last Icon
                      You have Guide Points inside very practical Projection by Didier Bur
                        Lorand
                        Hello all:
                        The results look terrific but unfortunately it doesnt work for me neither in SU2017 nor in SU2016: both triangulation and conic curves work just fine but not the Voronoi XY. In 2017 it reports "Triangulation completed: xxx triangles created" without any other effect. In 2016 it does / reports nothing, just goes back to the SU selection tool.
                        All help would be highly appreciated, thank you,
                        Lorand
                        Edited:
                        Re-Hello:
                        All 3 component plugins work in both SU2016 and SU2017. I was trying to get Voronoi patterns inside a pre-established shape and I put constr. points on the edges of the shape and that kills Voronoi XY. Define your target shape (wasnt able to make triangles yet) by putting cps in the corners of it, BUT NOT ON THE EDGES, and it works nicely.
                        Hope this may help someone,
                        Lorand
                        .png much smaller than .skp
                        • E Offline
                          Einstein
                          Error loading file. The same issue in SU 2017, SU 8. The same with the version developed by the.pjt.
                            Did you download the latest version's RBZ from the PluginStore ?
                            https://sketchucation.com/pluginstore?pln=VoronoiXY
                            That RBZ contains the required file ' delauney3.rb'
                            You error message is telling us it can't be found.
                            If you install it from the RBZ the additional delauney3 RB should also be installed.
                            If you have disabled it using the SCF PluginsManager tool, or the native Extension Manage tool in newer SketchUp versions you'll get that kind of error error...
                            If you made the RBZ back into a .ZIP and took out only some files, then you haven't installed the required set of files !
                            • E Offline
                              Einstein
                              I was trying to install manually. Now, with PluginStore package it works. Thank you again 😄
                                These days, you hardly ever need to do a manual installation - the RBZ installation does it for you automatically, and getting the latest version from our PluginStore [or the EWH when we don't host it], is always recommended...
                                New versions throw up issues and the newest RBZ file are [re]written to get around these, and ensure continuing compatibility...
                                • W Offline
                                  wrensong
                                  This plugin link does not work. The extension is a .rb not a .rbz
                                    Zip the .rb file
                                    Rename .zip in .rbz
                                    and you can use it like any other file rbz! 😉
                                      Just download the later RBZ version from the PluginStore.
                                      Then install it.
                                      It includes the helper files needed too...
                                      Trying to load out-of-date RB files is a recipe for frustration...
                                        maoxx
                                        nice
                                          Pawatamit1994
                                          not getting the download link plss help
                                            Gábor
                                            Click the "Download" button at the first post of this topic. On the next page click "Download" near the description of the plugin.
                                            • 6 / 7
