    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 256.2k Views 54 Watching
    • sdmitchS Offline
      sdmitch
      @auter said:
      i tried to install in my SketchUp but didnt work... anyone could help me with this?
      What didn't work? Did not install? Installed but will not run? Runs but no results?
      Post the model or a screenshot. Open the Ruby Console and execute the plugin. Post any errors that are shown.
      http://sdmitch.blogspot.com/
        sarkarshomit
        Please can someone confirm that this works on Skup2016, as i cant seem to find the plugin after install.I have the conic curve in face working, but not the voronoi part...
          Seems that works like a charm inside 2016 Make as shown on my previous post! πŸ˜„
          Quasi all is by hand "manual" ! πŸ€“
          Last Icon
            You have Guide Points inside very practical Projection by Didier Bur
              Lorand
              Hello all:
              The results look terrific but unfortunately it doesnt work for me neither in SU2017 nor in SU2016: both triangulation and conic curves work just fine but not the Voronoi XY. In 2017 it reports "Triangulation completed: xxx triangles created" without any other effect. In 2016 it does / reports nothing, just goes back to the SU selection tool.
              All help would be highly appreciated, thank you,
              Lorand
              Edited:
              Re-Hello:
              All 3 component plugins work in both SU2016 and SU2017. I was trying to get Voronoi patterns inside a pre-established shape and I put constr. points on the edges of the shape and that kills Voronoi XY. Define your target shape (wasnt able to make triangles yet) by putting cps in the corners of it, BUT NOT ON THE EDGES, and it works nicely.
              Hope this may help someone,
              Lorand
              .png much smaller than .skp
              • E Offline
                Einstein
                Error loading file. The same issue in SU 2017, SU 8. The same with the version developed by the.pjt.
                  Did you download the latest version's RBZ from the PluginStore ?
                  https://sketchucation.com/pluginstore?pln=VoronoiXY
                  That RBZ contains the required file ' delauney3.rb'
                  You error message is telling us it can't be found.
                  If you install it from the RBZ the additional delauney3 RB should also be installed.
                  If you have disabled it using the SCF PluginsManager tool, or the native Extension Manage tool in newer SketchUp versions you'll get that kind of error error...
                  If you made the RBZ back into a .ZIP and took out only some files, then you haven't installed the required set of files !
                  • E Offline
                    Einstein
                    I was trying to install manually. Now, with PluginStore package it works. Thank you again πŸ˜„
                      These days, you hardly ever need to do a manual installation - the RBZ installation does it for you automatically, and getting the latest version from our PluginStore [or the EWH when we don't host it], is always recommended...
                      New versions throw up issues and the newest RBZ file are [re]written to get around these, and ensure continuing compatibility...
                      • W Offline
                        wrensong
                        This plugin link does not work. The extension is a .rb not a .rbz
                          Zip the .rb file
                          Rename .zip in .rbz
                          and you can use it like any other file rbz! πŸ˜‰
                            Just download the later RBZ version from the PluginStore.
                            Then install it.
                            It includes the helper files needed too...
                            Trying to load out-of-date RB files is a recipe for frustration...
                              maoxx
                              nice
                                Pawatamit1994
                                not getting the download link plss help
                                  GΓ‘bor
                                  Click the "Download" button at the first post of this topic. On the next page click "Download" near the description of the plugin.
                                    Or find in by searching the PluginStore...
                                    The first-post's 'Download' button is a direct link to that entry !
                                    • HornOxxH Offline
                                      HornOxx
                                      Hi All, I am also so dull and can't find your working download (I would like to use this tool on my private Make 2017 and, if possible, on Pro2019). So IΒ΄m looking forward to any patient help πŸ˜„
                                      never trust a skinny cook
                                        Try the Download button in this post:
                                        https://sketchucation.com/forums/viewtopic.php?p=538039#p538039
                                        • HornOxxH Offline
                                          HornOxx
                                          ... thanks again TIG πŸ‘ your Link worked fine πŸ˜„
                                            mackbrae
                                            no puedo intalarlo..me pide el formato *.rbz ...!! ayudaa
                                            • 6 / 7
