    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • fredo6F
      New Release: Animator - v2.3c - 18 Nov 18
      Requirement: LibFredo6 v8.6m
      Minor release
      • Bug fixing and GUI adjustments
      • Option for Transparent background for generating videos. It only works for Natural rendering and generate the PNG images with no background. I don't know if this makes its way through the video generation via FFmpeg. You need to install LibFredo6 8.6m.
      See plugin home page of Animator for Download of RBZ from the PluginStore.
      See Main Post of the Animator thread for more information.
      • P
        palphd
        Minor release
          [attachment=0:1f6ufy1r]<!-- ia0 -->Animator - Transparent Background toggle button.png<!-- ia0 -->[/attachment:1f6ufy1r]
        Thanks Fredo,
        Good news: I can now see the Transparent Background toggle button on the GUI.
        Bad news: I don't get transparent backgrounds in my PNGs when I export them with the option selected 😞
        • fredo6F
          Did you upgrade to LibFredo6 8.6m?
          • P
            palphd
            That did the trick! You're the man, Fredo!
              rong1937
              Hope to support Enscape render
              • C
                chals375
                Hello.
                First of all, I hope you understand the awkwardness of English.
                Writing on the translator.
                I used the animator 2.1a version and thea render v2.Β
                I was using it well, but after updating the animator to 2.3c, I can't turn it on.
                When I press the render button, the word "no clip defined in model" appears.
                So do files with dozens of clips.
                Everything went dead.
                I want to use version 2.1a again, but it is not possible because the period of use has expired.
                If I set my computer time to the past, I can use it, but because thea render license is not available, rendering is not possible.
                How shall I do it?
                Please help me.T.T
                • fredo6F
                  @chals375
                  1. First of all, can you play the animation interactively within Animator
                  2. Can you generate the video in natural mode (No rendering by Thea)?
                  3. Can you open the Ruby console while you are in Animator, to see i there are errors showing.
                  Finally, the best would be that you post or PM me your model so that I can have a closer look.
                  PS: do not play with the clock of your PC, as you can have many other bad side effects on other applications.
                  • T
                    Tranthanhvu
                    Can you help me.
                    https://youtu.be/eLUiA4i01Yo
                    • fredo6F
                      @tranthanhvu said:
                      Can you help me.
                      For the rotation, you need to select the two arms objects, instead of the components which includes both arms.
                      • C
                        Comial
                        @fredo6 said:
                        @chals375
                        I'm having the same issue since upgrading to v2.3. In response to your questions to @chals375
                        1. Yes, I can play the animation without any problems in Animator
                        2. Yes, I can generate the video in natural mode. Also, Thea render's animation tab can render Sketchup default animations but does not open a dialog when selecting Animator as the plugin.
                        3. Ruby console does not display any errors when trying to render from Thea Render
                        Rendering with Thea works just fine if I initiate it from Animator, but the only reason I want to render from Thea is so that I have control over what format the exported image sequence is in. If there is a way to do that from Animator then that would also solve my problem.
                        PS. I love all your plugins. Thank you for all your contributions to the Sketchup community!!
                        • fredo6F
                          I fixed the issue with the generation from Thea render in Animator 2.4a.
                          Please advise if this is ok for your now.
                          • fredo6F
                            New Release: Animator - v2.4a - 10 Jan 19
                            Requirement: LibFredo6 v8.7e
                            Minor release
                            • Extension of validity
                            • Fix a problem preventing to generate the video from Thea render
                            • C
                              Comial
                              It does! Thank you, this is really great. I appreciate you providing such great support for your plugins.
                              • OxerO
                                Oxer
                                It works fine on Mac too. πŸ‘
                                • fredo6F
                                  New Release: Animator - v2.4b - 12 Mar 19
                                  Minor release
                                  • Some bug fixes
                                    Aaronyee
                                    Minor release
                                    • Some bug fixes
                                    Hi, fredo. I want to realize how version of thea render can support v2.4b animator. Is the thea render v2.0 ok? Thank you for help me.
                                    • fredo6F
                                      I did not test with this version of Thea 2.0. I only have v1.5 on my laptop.
                                      So if you have it already, please make a test on a simple animation, opening the Ruby Console to check if there are error messages (normally you should only see traces of the execution).
                                      For Thea, make sure you use a Presto method, not interactive, with a reasonable sample/px, typically 10 to 20. This keeps the rendering under a reasonable amount of time.
                                      • fredo6F
                                        New Release: Animator - v2.4c - 14 May 19
                                        Requirement: LibFredo6 v8.7f
                                        Minor release
                                          meapiper
                                          Can I use this extension with Maxwell Render to create a rendered video? I believe I need to creates multiple scenes to bring into Maxwell.
                                          • fredo6F
                                            I have no API to Maxwell, so it is not supported in Direct mode by Animator.
                                            And I doubt that Maxwell support the reverse mode (as Thea does), because they would have contacted me.
                                            So short answer is NO.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 29
                                            • 30
                                            • 16 / 30
