    [Tips] Animator Tips and Tricks
    renderpluginsextensions
    74 Posts 18 Posters 279.8k Views 18 Watching
    • fredo6F
      @manabouttools said:
      I am using a Mac and cannot change the scale of the timeline to zoom in. When I mouse over the scroll bar it says "Use Mouse-wheel +ALT to change scale"
      The equivalent on the Mac is the "option" key. When I push the option key and touch scroll the Mac magic mouse it zooms the model and not the timeline.
      Kent
      https://manabouttools.com
      I don't have a Mac to test.
      Could you try with Command or Ctrl to see what happens.
      • MANaboutTOOLSM
        MANaboutTOOLS
        I tried as many combinations as possible. All just zoom the model.
        Kent
        • fredo6F
          Kent
          Can you at least scroll the timeline (mousewheel, no modifier) and scroll the tracks (Ctrl + mousewheel), [assuming you have enough tracks) ?
          • MANaboutTOOLSM
            MANaboutTOOLS
            I don't have enough tracks to test that. Will try tmrw.
            • MANaboutTOOLSM
              MANaboutTOOLS
              I changed a clip to make it longer so it brought up the scroll bars. I am unable to scroll the timeline with the mouse wheel. It always zooms the model window.
              Kent
              • MANaboutTOOLSM
                MANaboutTOOLS
                Any keyboard shortcuts to zoom the timeline? Or any settings to key in a zoom value to get around this?
                Kent
                • fredo6F
                  Kent
                  Let's take things in order
                  1. without any modifier, putting the mouse cursor over the time, can you scroll the timeline?
                  2. with Option key pressed, and assuming you have enough tracks, can you scroll the tracks?
                  3. with Command key pressed, putting the mouse cursor over the time, what do you get?
                  • MANaboutTOOLSM
                    MANaboutTOOLS
                    I can click-drag with the left button to scroll the time. I added enough tracks to test this.
                    1. No. Hovering the curser over the bar and gesturing with the magic mouse (scroll-wheel) zooms the model.
                    2. No. Zooms the model
                    3. With the mouse hovering over the scroll bar the time reads (for example) 25.5 s. If I press the command key the time then reads 25.50 s. And as above, mouse wheel gesture zooms model.
                    I hope this helps. Do you want a screen record?
                    Kent
                    • MANaboutTOOLSM
                      MANaboutTOOLS
                      Here's a screenflow capture...
                      • fredo6F
                        Do you have a special mouse ?
                        • MANaboutTOOLSM
                          MANaboutTOOLS
                          No, mouse came with the mac.
                          • fredo6F
                            Could you open the Ruby Console when you run Animator and scroll with the mousewheel.
                            • MANaboutTOOLSM
                              MANaboutTOOLS
                              Yes,
                              I have Ruby open. No difference.
                              Kent
                              • jujuJ
                                juju
                                Yes,
                                Kent
                                any messages in the ruby console when scrolling?
                                • MANaboutTOOLSM
                                  MANaboutTOOLS
                                  No. Nothing
                                  • fredo6F
                                    @carloshmejia said:
                                    First of all thank you for your amazing plugins.
                                    I am learning to use Animator. For some reason my original position changed and now it not correspond to my model. Are there a way to reset or change the original position of my clip?
                                    Probably not...
                                    There is a Positioner facility in Animator (4th icon), allowing you save and restore the position of objects. It is a good idea to save the position of objects before you start building animations.
                                    • C
                                      carloshmejia
                                      Fredo, first of all thank you for your amazing plugins.
                                      Frequently the objects that I am animating lose its connection with the movements assign to them. Timeline seems OK, when you run the sequence it shows running except the objects don't move. What am I doing wrong?
                                      • I
                                        itaipeter
                                        @fredo6 said:
                                        The picto is explicit
                                        Hello Fredo, thanks for the extension it's amazing and simple to use.
                                        I'm having difficulty using the appearance function. for some reason, it doesn't work as it should.
                                        I've messed with it in this project and suddenly as working the function refused to work with disappearing components.i've made a short video to explain.
                                        thanks
                                        • fredo6F
                                          Your video cannot be accessed. Maybe it is private.
                                          • I
                                            itaipeter
                                            it should work now. thank you
                                            • 2 / 4
