    [Tips] Animator Tips and Tricks
    renderpluginsextensions
    74 Posts 18 Posters 261.4k Views 18 Watching
      Useful for magician! 😎
      • fredo6F Offline
        The picto is explicit
          Can we add a Clip (or a movement) made in a previous session to the current session where an another is yet created ?
          Say an object A (a Car) is on the screen and animated
          A ball is an object B (a Ball animated) previously made in another session, can we add it to the car ?
          • fredo6F Offline
            Any animation piece (i.e. sequence) created within a model can be integrated into a film, knowing that you can have many films within the same model. Think of a Sequence as a Component Definition in Sketchup. You can create instances of a sequence and insert them in the time line, change some parameters like duration, easing, ... (like you can scale a component instance in Sketchup). All sequences created in the model are accessible from the Insert buttons (for Movement, Cameras, Visual Effects, ....):
            Note that you can also insert a full film
            • soloS Offline
              I'm still using Thea 1.5, but I cannot get animator to work with Thea, it works perfect with straight SU output but nothing happens with Thea, at first it just rendered the 1st scene, now when I click 'render animation' it does nothing, what am I doing wrong?
              • fredo6F Offline
                Do you mean when you launch the rendering from Thea (not from Animator)?
                • MANaboutTOOLSM Offline
                  MANaboutTOOLS
                  I am using a Mac and cannot change the scale of the timeline to zoom in. When I mouse over the scroll bar it says "Use Mouse-wheel +ALT to change scale"
                  The equivalent on the Mac is the "option" key. When I push the option key and touch scroll the Mac magic mouse it zooms the model and not the timeline.
                  Kent
                  https://manabouttools.com
                  • fredo6F Offline
                    @manabouttools said:
                    Kent
                    I don't have a Mac to test.
                    Could you try with Command or Ctrl to see what happens.
                      MANaboutTOOLS
                      I tried as many combinations as possible. All just zoom the model.
                      Kent
                      • fredo6F Offline
                        Kent
                        Can you at least scroll the timeline (mousewheel, no modifier) and scroll the tracks (Ctrl + mousewheel), [assuming you have enough tracks) ?
                          MANaboutTOOLS
                          I don't have enough tracks to test that. Will try tmrw.
                            MANaboutTOOLS
                            I changed a clip to make it longer so it brought up the scroll bars. I am unable to scroll the timeline with the mouse wheel. It always zooms the model window.
                            Kent
                              MANaboutTOOLS
                              Any keyboard shortcuts to zoom the timeline? Or any settings to key in a zoom value to get around this?
                              Kent
                              • fredo6F Offline
                                Kent
                                Let's take things in order
                                1. without any modifier, putting the mouse cursor over the time, can you scroll the timeline?
                                2. with Option key pressed, and assuming you have enough tracks, can you scroll the tracks?
                                3. with Command key pressed, putting the mouse cursor over the time, what do you get?
                                  MANaboutTOOLS
                                  I can click-drag with the left button to scroll the time. I added enough tracks to test this.
                                  1. No. Hovering the curser over the bar and gesturing with the magic mouse (scroll-wheel) zooms the model.
                                  2. No. Zooms the model
                                  3. With the mouse hovering over the scroll bar the time reads (for example) 25.5 s. If I press the command key the time then reads 25.50 s. And as above, mouse wheel gesture zooms model.
                                  I hope this helps. Do you want a screen record?
                                  Kent
                                    MANaboutTOOLS
                                    Here's a screenflow capture...
                                    • fredo6F Offline
                                      Do you have a special mouse ?
                                        MANaboutTOOLS
                                        No, mouse came with the mac.
                                        • fredo6F Offline
                                          Could you open the Ruby Console when you run Animator and scroll with the mousewheel.
                                            MANaboutTOOLS
                                            Yes,
                                            I have Ruby open. No difference.
                                            Kent
                                            • 1 / 4
