    [Tips] Animator Tips and Tricks
    renderpluginsextensions
    74 Posts 18 Posters 278.7k Views 18 Watching
      Can we add a Clip (or a movement) made in a previous session to the current session where an another is yet created ?
      Say an object A (a Car) is on the screen and animated
      A ball is an object B (a Ball animated) previously made in another session, can we add it to the car ?
      • fredo6F
        Any animation piece (i.e. sequence) created within a model can be integrated into a film, knowing that you can have many films within the same model. Think of a Sequence as a Component Definition in Sketchup. You can create instances of a sequence and insert them in the time line, change some parameters like duration, easing, ... (like you can scale a component instance in Sketchup). All sequences created in the model are accessible from the Insert buttons (for Movement, Cameras, Visual Effects, ....):
        Note that you can also insert a full film
        • soloS
          I'm still using Thea 1.5, but I cannot get animator to work with Thea, it works perfect with straight SU output but nothing happens with Thea, at first it just rendered the 1st scene, now when I click 'render animation' it does nothing, what am I doing wrong?
          • fredo6F
            Do you mean when you launch the rendering from Thea (not from Animator)?
            • MANaboutTOOLSM
              MANaboutTOOLS
              I am using a Mac and cannot change the scale of the timeline to zoom in. When I mouse over the scroll bar it says "Use Mouse-wheel +ALT to change scale"
              The equivalent on the Mac is the "option" key. When I push the option key and touch scroll the Mac magic mouse it zooms the model and not the timeline.
              Kent
              https://manabouttools.com
              • fredo6F
                @manabouttools said:
                Kent
                I don't have a Mac to test.
                Could you try with Command or Ctrl to see what happens.
                • MANaboutTOOLSM
                  MANaboutTOOLS
                  I tried as many combinations as possible. All just zoom the model.
                  Kent
                  • fredo6F
                    Kent
                    Can you at least scroll the timeline (mousewheel, no modifier) and scroll the tracks (Ctrl + mousewheel), [assuming you have enough tracks) ?
                    • MANaboutTOOLSM
                      MANaboutTOOLS
                      I don't have enough tracks to test that. Will try tmrw.
                      • MANaboutTOOLSM
                        MANaboutTOOLS
                        I changed a clip to make it longer so it brought up the scroll bars. I am unable to scroll the timeline with the mouse wheel. It always zooms the model window.
                        Kent
                        • MANaboutTOOLSM
                          MANaboutTOOLS
                          Any keyboard shortcuts to zoom the timeline? Or any settings to key in a zoom value to get around this?
                          Kent
                          • fredo6F
                            Kent
                            Let's take things in order
                            1. without any modifier, putting the mouse cursor over the time, can you scroll the timeline?
                            2. with Option key pressed, and assuming you have enough tracks, can you scroll the tracks?
                            3. with Command key pressed, putting the mouse cursor over the time, what do you get?
                            • MANaboutTOOLSM
                              MANaboutTOOLS
                              I can click-drag with the left button to scroll the time. I added enough tracks to test this.
                              1. No. Hovering the curser over the bar and gesturing with the magic mouse (scroll-wheel) zooms the model.
                              2. No. Zooms the model
                              3. With the mouse hovering over the scroll bar the time reads (for example) 25.5 s. If I press the command key the time then reads 25.50 s. And as above, mouse wheel gesture zooms model.
                              I hope this helps. Do you want a screen record?
                              Kent
                              • MANaboutTOOLSM
                                MANaboutTOOLS
                                Here's a screenflow capture...
                                • fredo6F
                                  Do you have a special mouse ?
                                  • MANaboutTOOLSM
                                    MANaboutTOOLS
                                    No, mouse came with the mac.
                                    • fredo6F
                                      Could you open the Ruby Console when you run Animator and scroll with the mousewheel.
                                      • MANaboutTOOLSM
                                        MANaboutTOOLS
                                        Yes,
                                        I have Ruby open. No difference.
                                        Kent
                                        • jujuJ
                                          juju
                                          Yes,
                                          Kent
                                          any messages in the ruby console when scrolling?
                                          • MANaboutTOOLSM
                                            MANaboutTOOLS
                                            No. Nothing
                                            • 1 / 4
